Do you change your oil every 5000 or 10000?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by iskoos, Jan 1, 2020.
  1. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    Walmart rotates tires for free(if purchased from them) at every 5000miles. I could do it in my garage but I will try them first. They will also give me free balancing.
    fuzzy1 likes this.
  2. iskoos
    415
    254
    Orlando, FL
    This is what I am leaning towards. I used to do 7500mile change for my BMW back in days.
  3. tonynap
    tonynap Member
    43
    38
    NY
    5,000 miles with Pennzoil Platinum full synthetic 0W-20 and any filter.
    douglasjre and m.wynn like this.
    51,948
    my message just says 'maintenance required'
    maybe they finally reprogrammed it.
    Raytheeagle and Mendel Leisk like this.
  5. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Mine is the same. No other messages about oil ever.
  6. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    I wonder if that changed with the 2012 refresh.
  7. bisco
    51,948
    could be. didn't the oci change after gen 3 was in production?
  8. fuzzy1
    10,454
    It changed about late 2009, about six months after the Gen3 began selling in North America.
  9. bisco
    51,948
    thanks!
    so they probably had to wait for a revision to revise the message.
  10. Mendel Leisk
    41,463
    Canadian Prius don't say anything, no message. We improvise.
    Raytheeagle likes this.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    How do you know what to do without a message.
    Livin’ on the edge(y).
  12. Mendel Leisk
    41,463
    Look at the calendar (sometime mid-April and mid-October), and try to ignore the ridiculously low miles.
    douglasjre and Raytheeagle like this.
  13. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    What’s the km count on the garage queen:whistle:?
    I’m already over 16k miles on our Prime we bought in April:cool:.
    It would’ve had 1k more, but the wife wanted to take the RX on our southern trip this year:).
    The cooled seats were a welcomed change to that 6 hour drive(y).
  14. Mendel Leisk
    41,463
    85K kms
  15. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    That’s like 50k miles:).
    She’s been pampered;).
    When do you buy the Prolong Charger:whistle:?
    That’s the last piece to the preventative maintenance puzzle(y).
    m.wynn and Mendel Leisk like this.
  16. iskoos
    415
    254
    Orlando, FL
    Wow. I really didn't know that. Yes then, they definitely changed something (in a good way).
    Mine is 2010 but it is manufactured in August of 2009 and it does say "Oil Maintenance Required"
    I have a friend with 2010. I will check his and see what his message says and will check the production date of his Prius.
  17. ASRDogman
    ASRDogman Senior Member
    7,597
    3,916
    My Prius date is June 2009.
    I believe it just says Maintenance Required. I don't remember seeing the oil.
    I will check it in about 3500 miles....
  18. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Referring to car’s manual is not an option?
  19. ASRDogman
    7,597
    3,916
    Nope, it's not.
  20. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    I change at roughly 8500 miles. Typically that's about half trips of over 200 miles one-way, and most of the remainder trips of 10-30 miles one-way. I avoid shorter trips by using a bike for those.
    A good alternate plan would every time it burns as much fuel as it would burn in 10,000 miles under near-ideal conditions.
    I usually use Pennzoil Platinum (synthetic) 5W-20. Only the specified 4.4 quarts which is not enough to reach the full mark on the dipstick, checking cold.
