Do you Folks have enough drivers legroom?
Discussion in 'Gen 2 Prius Main Forum' started by CarGuy60, Jul 22, 2008.
  1. CarGuy60
    CarGuy60 New Member
    50
    Boston
    We ordered a Prius from a local dealer in Hanover Mass, low key approach, down payment given five weeks ago and we just got the call its almost here. My question, the legroom for the driver, particularly the divers left leg seems very skimpy. The dealer let us tale a long private road test, love the car but the drivers leg room is in the back of my mind. Did anyone have and thoughts or concerns with drivers legroom?
    Thanks
  2. Patrick Wong
    18,192
    6,415
    I understand that Prius was intended to fit male drivers up to 6' 2" height. If you are at or beyond that height; or if your legs are longer than normal, then you will be justifiably concerned about legroom.
    In that case, maybe the Camry Hybrid or Highlander Hybrid would fit your needs better.
  3. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    16
    At 6-1, I don't have any problem with leg room. Did you adjust the seat all the way back? I don't drive it that way.
  4. 08 mag grey
    08 mag grey New Member
    34
    Tucson AZ
    I've had our Prius for three week and have taken a few 200 mike trips.
    I'm 6'3" and the leg room seem to be okay. The only small problem I see is the the seat has to be all the way back which means my arms are extended quite a ways to reach the steering wheel. So far I've learned to live with it.
  5. 100 Miles a day
    100 Miles a day New Member
    Texas City, Texas
    I am just a hair under 6'2" and pretty heavy - I have no problems. In fact, I drive over an hour each way and find it comfortable.
  6. Boo
    Boo Boola Boola Member
    5,051
    479
    97
    Flushing, NY
    Patrick is right. There are stories all over this board about taller people who find the legroom insufficient, and who try to modify the seats by either extending the seat rails and/or lowering the seat height. But there are also stories on this board of people 6'5" and taller who get by with the seats the way they are.
    By the way, nyprius found a shop in Massachusetts which modifies car seats for the disabled and the Boston Celtics, and which modified his driver's seat by extending the seat rails 3 inches. I'll dig up the info for you in a couple of minutes, and post it.
  7. CarGuy60
    CarGuy60 New Member
    50
    Boston
    Thank you all for the quick informative replys. My problem is i have had large cars with great legroom , an Avalon and now a Buick Lucerne . Will be a bit of an ajustment i'm sure :)Boo, i did see the post about the Mass fellow making modifications, I wonder if that would negates insurance claims, due to being that much farther from the air bag. Once again, thank you to all
    Joe
  8. Boo
    5,051
    479
    97
    Flushing, NY
    Here are some quotes of nyprius regarding his extending of the seat rails:
    And in the following thread, there are 3 pictures of nyprius' extended seat rails:
    http://priuschat.com/forums/prius-modifications/44287-custom-extended-seat-rails-group-order-9.html
    Good luck.
  9. McDonald
    McDonald New Member
    264
    Boston, MA
    I am a 130 lb 5'11 woman, and the leg room is plenty. The only thing I would change about the driver's position is to add a telescoping wheel, and height adjustment to the seat (up/down).
  10. JimboK
    JimboK One owner, low mileage
    2,817
    186
    49
    Chesterfield, VA
    I'm 6'4" with a 34" inseam. The leg room is adequate, even on long drives (including a 2000 mile round trip last summer) as long as I take a break every couple of hours. My only complaint is lack of thigh support. Height and angle adjustments for the seat bottom would help. Lacking that, I use an Obus Forme seat support.
  11. greylar
    greylar New Member
    283
    38
    Montana
    I think the inseam is really the key. I am 6'3" but have pretty long legs 36"+ inseam and find the leg-room a bit lacking. I can't really straighten my legs all the way. One tip... take off your shoes on long trips. That gets me the extra I need.
    Jim I agree.. height adjustment on the front of the seat would be nice as well. I used a rolled up towel for awhile but found it too much hassle.
    G
  12. VaPrius
    VaPrius New Member
    150
    Virginia Beach
    I'm 6'1" and there is plenty of leg room. I've taken long trips, commuted two hours a day for three years. No problem at all.
  13. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    2008 #2 already has height adjustment. There should be a lever under the steering wheel. It is easy to forget it is there. :)
  14. F8L
    19,011
    4,076
    50
    Grass Valley, CA.
    Agreed, inseam is the issue as height only gives general indications. :)
    At 6'3" (34" inseam) I feel I have plenty of room. My roomate is 6'5" with a 36"+ inseam and his giant knee touches the shift knob.
  15. doubleg2005
    doubleg2005 Member
    236
    i could be wrong, but i assume you are referring to the height adjustment to the steering wheel? they are referring to the lack of height adjustment to the seat... sorry if i ASSumed incorrectly
  16. Jack66
    766
    Stafford, Virginia
    Its also easy to forget how tired I am! Oops! :D You are correct - telescoping wheel and height-adjusting seat.
  17. pewd
    pewd Clarinet Dude
    331
    Dallas, Texas
    what jim said - thigh support could be better.
    i'm 6'5". my right knee was a problem hitting the shift lever when i first got the car. it no longer bothers me , i guess i've learned to keep my knee out of the way. it took me about 2 months to adjust, now the space seems fine.
    it gets better every time i drive past a gas station without stopping....
  18. kazots
    kazots LifesaBeach
    262
    CALIFORNIA
    I'm not happy that I don't have that problem. Kinda short, but I agree about the tilt steering wheel. It would be nice to change the position for a more comfortable fit.
  19. nerfer
    nerfer A young senior member
    2,474
    208
    28
    Chicagoland, IL USA, Earth
    Enough legroom, but a telescoping steering wheel would sure be nice. Had to move my seat to a comfortable position for my legs, but then I had to stretch out my arms more than I was used to. If my arms are close in like normal, then my legs are bent.
    But I got used to holding the steering wheel a little farther away than normal. Now I don't think about it. I've gone on a few long trips of 600 miles each way. (5'10+, 33" inseam). Seat height and support is fine for me.
  20. Zythryn
    Zythryn Senior Member
    5,725
    3,748
    The Buick has front legroom of 42.5.
    The Prius comes in at 41.9. I bet you will hardly notice:)
Loading...
