Do You Have the USB Startup Bug?
Discussion in 'Prius c Audio and Electronics' started by Rebound, Dec 10, 2012.
Thread Status:
Not open for further replies.
  1. Rebound
    Rebound Senior Member
    3,964
    2,615
    Portland, OR
    I have a Base model 2012 Prius Plug-in. It has a radio system called "Display Audio with Navigation and Entune." This unit also ships on the Prius c Three and Four 2012 models. I keep a USB thumb drive plugged into the USB port at all times.
    Here's the problem: When I start the car, it will start playing the last-used audio source, and after several seconds, it switches to the USB thumb drive. This occurs about 1/3 of the time. This is very annoying to me. I called Toyota and they said they've never heard of this issue.
    Please chime in if you've experienced this. Or, if you don't have this problem, I would like to know. Maybe it is the kind of drive I'm using. But two key things:
    • 2012 Display Audio with Entune (2012 Prius c Three or Four)
    • USB thumb drive plugged in at all times
    If I get enough responses, I'll be able to convince Toyota to fix it. Thanks!
  2. krneidigh
    krneidigh Junior Member
    70
    17
    Pensacola
    Not as frequent as yours, but enough. It also does it with my Bluetooth. For USB I use iPod and some of the tracks lock the controls if they are playing and I turn off the car. There is a post about that too.
  3. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
Thread Status:
