Do You Have the USB Startup Bug?
Discussion in 'Prius v Audio and Electronics' started by Rebound, Dec 10, 2012.
Thread Status:
Not open for further replies.
  1. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    I have a Base model 2012 Prius Plug-in. It has a radio system called "Display Audio with Navigation and Entune," which also ships on the Prius v Three and Five 2012 models. I keep a USB thumb drive plugged into the USB port at all times.
    Here's the problem: When I start the car, it will start playing the last-used audio source, and after several seconds, it switches to the USB thumb drive. This occurs about 1/3 of the time. This is very annoying to me. I called Toyota and they said they've never heard of this issue.
    Please chime in if you've experienced this. Or, if you don't have this problem, I would like to know. Maybe it is the kind of drive I'm using. But two key things:
    • 2012 Display Audio with Entune (Prius v Three and maybe Five)
    • USB thumb drive plugged in at all times
    With enough data, I can convince Toyota to fix this. Thanks!
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
Thread Status:
