Do you have to use Toyota coolant?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dale Earnhadrt, Apr 22, 2015.
  1. Dale Earnhadrt
    Dale Earnhadrt Junior Member
    chicago
    Wow! 32 bucks for an undiluted gallon of coolant from the toyota dealer. I think it was the SLLC. Is there any other coolant rated for a prius that has a more Earthly price?
    52,863
    think of it this way, it's only once every hundred thousand miles.:) and you're saving a fortune doing it yerself!
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    as far as I know most here use it and those who do not tend to regret it...I am sure we have a few renegades but I am talking the general masses here
  4. Mike500
    Mike500 Senior Member
    2,593
    767
    Zerex makes an "Asian" car coolant that is totally campatible. Toyota might even buy it from them and rebrand it.
    It's about $15 a gallon.
  5. bisco
    52,863
    if mikes good with it, i'm good with it. ^^^
    Mike500 likes this.
  6. Mendel Leisk
    42,355
    Unless I'm not mistaken, it's 50/50 mix. It is up here: just bought one, to top up the reservoirs. That took about 8 oz, lol.
    Personally I'd stick with the kosher stuff, but I'm kinda uptight.
  7. Mike500
    2,593
    767
    I compared the tecnnical specs of the two and the MSDS's. They appear to be the same.
  8. bisco
    52,863
    someone has to make toyota's, right? they can't make everything.
  9. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    FWIW, Toyota's SLLC is $28.50 on Amazon, Subaru's is $29.90, Mitsubishi's $30.95, Nissan's $28.80 and Beck Arnley's $32.75. Zerex has some extended life (5 yr/150k mi guarantee) for Asian vehicles for only $13.69, but I have no idea if it's compatible with the Prius, etc. I found some SLLC for $21.95, but then shipping was $6.95. Personally, I don't cut corners unless I'm absolutely sure of compatibility and everything I've read here seems to indicate Toyota's prices for most things are pretty competitive, even for the DIY crowd.
  10. Mike500
    2,593
    767
    Right. In the US, Federal Law states that, if a manufacture requires the prchase of ONLY their brand to maintain the warranty, it must be supplied to the owner at no cost.
    I use SLCC in the inverter coolant loop. It uses very little. Failure would be a major expense.
    On the other part of the cooling system, I use the Zerex and change it every three years.
  11. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ...sounds like the specific Zerex might be a valid equivalent if you want to go that way, but it's got to be either the Toyota or exact equal third party substitute and not just anything off the shelf.
  12. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    I really have no opinion, I'll probably trade before I need a coolant change anyway. :) I see nothing wrong though with using whatever coolant is compatible and was just offering the prices I found. There are those who use regular oil instead of synthetic and then change it more frequently, IMHO it all comes out even in the end. As I see it, it's 10 yrs/100k miles for $30 vs 3 yrs/X miles for $15. Some people just don't like to go that long and there's nothing wrong with that.
  13. JC91006
    16,936
    8,647
    this statement contradicts what you said about both products being the same.
    SageBrush uses the Asian formula from Zerex, you guys can ask him what he thinks of it. I personally think either can be used.
  14. Mendel Leisk
    42,355
    Maybe there's alternatives that work, I just don't feel comfortable experimenting with it.
    I'm just as concerned with colour: is the alternate stuff pink? If not, forget it, lol.
  15. Dale Earnhadrt
    chicago
    I'll check the container, but the parts guy at the local dealer said the 50/50 was $24 a gallon and the 100% strength that has to be mixed with distilled water at a ratio of 1:1 was $32. I think Toyota now sell pre-mixed and full strength stuff.
  16. JC91006
    16,936
    8,647
    The pink SLLC is prediluted. The red long life coolant is not diluted.
    The pink stuff can go 50k miles. whereas the red stuff only is good for 30k miles.
  17. qdllc
    qdllc Senior Member
    1,377
    400
    Most aftermarket stuff that's branded to be compatible should do fine. My dad had a similar issue with his Highlander, but at least its not hard to drain and fill it if he decides to do it more often. If you want to drain and fill the Prius as the schedule says, going with Toyota's brand at least assures you'll get the miles with no issues. If you use something that claims to be as good, you might have to do it more often to feel you're getting the same protection.
    Honestly, there's rarely an issue with the ability of something to keep the engine temp where it should be...you're more concerned about it preventing damage from corrosion, oxidation, etc. going on in the coolant system.
  18. Dale Earnhadrt
    chicago
    I believe you are correct, sir. I looked at the label last night in my shop and it's not the same as SLLC. I guess you could call the stuff I got LLC. The jug say "Long Life Coolant" but it's not super. Because it's not super, the fine print says that it is NOT able to leap tall buildings in a single bound...
    So I think it's 30k miles for this stuff and 50k miles for the SLLC. So I think I'll pony up and get the SLLC because when 30k rolls around I'll be kicking myslef for being penny wise and pound foolish.
  19. ETC(SS)
    7,568
    This is a wobbler for me.
    I'm normally skeptical when an OEM tells me that I have to use THEIR stuff, but for this application I think that I would DIY the coolant changes and get Amazon to deliver the OEM coolant, probably for less than their asking price and "definitely" without having to deal with the sniveling weasels down at the dealership.
    As Mike pointed out:
    Your call.
    The difference between $30 and $15 is significant, but not if you spread it out over 100,000 miles.
  20. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Not sure where a dealer said someone has to use Toyota coolant, it seems to me that all manufacturers recommend using their products.
    The difference between $30 and $15 is not significant if those who use the cheaper stuff change it more frequently. From what I've read, the first recommended coolant change is 10 years or 100,000 miles. At least one here is changing it every 3 years, turning that $15 into $45 during that period. Of course, there is a difference between recommended and actual, and many simply don't feel comfortable with the extended lifespan of today's products. I cringed when my daughter didn't change the oil in her 2007 Honda Pilot at the 3,000 mile mark like I've always done. She drives it until the maintenance display tells her to change it and it's been trouble free. The Toyota manual only says to use a ethylene-glycol type coolant and that the recommended service interval is based on using Genuine Toyota SLL coolant or similar high-quality coolant.
