Do you know what Honda Insight owners are talking about recently?
Discussion in 'Gen 3 Prius Main Forum' started by hschen, Aug 27, 2009.
  1. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    Must be nice to live on land as flat as a table and a hill is 2 ft high:rolleyes:
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Just a note that my wife always gets better mileage than I do.
    The success of any hybrid car helps other hybrids become mainstream. Putting down other hybrids only leads to fewer choices in the future.
    2 people like this.
  3. reverai
    reverai New Member
    119
    Alexandria, VA
    It's not hard to get 50 miles per galloon in a Prius. I generally get around 53 miles per gallon without even trying. Even on those short drives.....Insight owners..the two I know get around 44 miles per gallon. They both like their cars though and neither have said anything bad about my car. One like how much room in the back seats....
    Steve
  4. Bruno_S
    Bruno_S New Member
    130
    68
    My local Toyota dealership had an Insight for people to test drive together with the Prius. They also sell Ford cars so they could bring Fusion Hybrids at request. I actually tested my Prius at the Ford dealership.
    Trip B has not been reset since new and indicates 50.8 MPG. I did remove the front license plate and have +4 psi on all tires. This gave me an additional 2 MPG.
  5. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    A couple of observations about these statements:
    1. The GenII Prius has a rather small discrepency in overall gallons consumed vs. gallons estimated by MFD. In my case it is a little less than 0.8% after 28 tanks.
    2. The displayed is not always higher...certainly not on a per tank basis with the Prius bladder. It bounces around alot.
    3. If the display was perfect at measuring fuel injected and the gas pump meter was perfect at measuring fuel dispensed, one should still expect the display to read higher than the pump. Why? Because there are some unmetered losses. There will be some gasoline vapor bypassing the injectors via the vapor recovery system. There will be a small amount of gasoline vented during the fill...despite all the whiz bang bladder controls...or in some cases because of them since some folks have resorted to letting the tank vent before filling. There will be some gasoline lost as drips from the pump nozzle itself. Most of these should be tiny, but they do exist. There are likely others.
  6. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    I do not particularly drive for every last bit of mileage but my 2010 returns noticeably better interstate mileage than did my 2006. I keep it on 74 mph and the 2010 is rock steady at 54 mpg driving through the rolling hills of the NC Piedmont. My 2006 gave me 48 mpg making the same trips.
    BTW my computer mileage and actual pump mileage have been within 0.5 mpg for all three of my non dealer pumped fill-ups.
  7. MSantos
    MSantos EcoAccelerometry
    589
    260
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    Indeed.
    Of course, the obvious exception to this rule is the Civic Hybrid II which remains the only hybrid on the market that almost consistently reports lower mileage than actual (1-4 MPG lower). Quite refreshing actually.
    But having Honda reverse course on the 2010 Insight makes the optimistic reporting (2-3 MPG) seem premeditated... and sadly, a shameless attempt to match Toyota's affinity to almost always over-report. :(
    Cheers;
    MSantos
  8. patsparks
    10,664
    567
    Adelaide South Australia
    As long as you only take one passenger and not much luggage.
    The inside of the Gen I Insight is tiny, only 2 seats and almost no luggage space. If you get a chance have a look at one.
  9. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Exactly, the price difference between the 2010 Prius II and Insight EX is only $700. The LX is really stripped down.
    On this note, Hybrid Cost Analysis - Newsroom : Our Point of View Post / Toyota is Toyota's cost analysis.
  10. angelrob
    angelrob New Member
    94
    Rochester, NY
    My 95 Jeep Grand Cherokee had the same issue. I never wrote the numbers down, but it was always 1-2 MPG over (and when you're getting 18-20, that's a BIG percentage off :eek:) I just used the "real-time" read out as a rudimentary HSI and kept my own per tank numbers.
    Robbin
    P.S. I'm getting over 50 MPG calculated on my first few tanks and I hope that improves as I refine my driving even further with the better tools in the Prius :)
  11. Indyking
    Indyking Happy Hyundai owner...
    1,280
    I don't know... Indy, Chicago, Madison (WI)... it
    Good point BUT what people should really aim when thinking about buying a Prius is to use less gas, therefore help to conserve the environment, decrease our dependency to foreign oil, and be more financially responsible; as opposed to "the Prius would be a good car even without the outstanding mileage"
  12. Indyking
    1,280
    After 10 filings in my Prius and hundreds in my previous CR-V, the displayed MPG was ALWAYS higher. My neighbor also tells me that in his Honda Civic and Highlander hybrid, the displayed has been also ALWAYS higher.
  13. Indyking
    1,280
    WRONG INFORMATION!
    The base model of the Prius (model 2 as I don't think model 1 is available yet) is $22750.
    The base model of the Insight (LX) is $20500.
    The difference is $2240, NOT $1200.
    The difference in combined MPG between the 2 is: 9 MPG in favor of the Prius.
    Considering the current fuel prices at $2.45 here where I live:
    Prius: $0.049/mile
    Insight: $0.059/mile
    Difference: 0.01/mile
    To compensate for the extra $2240 paid for the Prius, one would have to drive 0.01x2240: 224,000 miles!
  14. The Beard
    The Beard New Member
    Madison WI
    I post over at Insight Central a fair amount (since I own an Insight EX). Overall people on that board respect the Prius even though they chose the Honda.
    What strikes me as ironic in this thread are two quotes from you -
    "I was amazed by the Insight owners' mind set in trying to compare and bring down Prius as a justification to their choice of Insight over Prius."
    Now read your original post,
    "After test drove Prius first, I found Insight looks cheap, has much less power (when needed) and very noisy and busy and small, but cheaper in price and has a paddle shifter. I went with Prius ..."
    The Knocking the Competition Street goes both ways.
    In regards to mileage - we have about 3400 miles on ours. We're averaging about 47 mpg. On the highway I tend to get in the mid 40s and in town can routinely get 60.
  15. blippo
    blippo New Member
    255
    VA
    Some of the Insight II drivers are getting better gas mileage than the Prius is
  16. Indyking
    1,280
    I do have to agree to some extent. I also participated in some other forums when trying to decide what to buy and I agree that the Prius chat offered to most hostile environment whenever I introduced some criticism about the Prius. It is true that some people here are extremely knowledgeable about the Prius and helped me a lot in my decision, but it is also true that some others are too passionate about it to a point where you can only carry on a decent discussion with them as long as you don't criticize the Prius. Very unfortunate...
  17. wfolta
    wfolta Active Member
    366
    146
    Washington DC
    2018 Prius
    Listen up, and we'll say it again: the LX is not even comparable to the Prius II. The LX is way stripped down. When comparing base price, for similarly-equipped cars, you need to step up a model in the Insight line, and the gap closes.
    Not to mention the things an Insight will NEVER have, like having the air conditioning run when at a stop light.
    Not to mention the Insight's cheap feel. As someone else said, the Prius is a nice car, even if it didn't get good mileage. The Insight is a bargain-basement vehicle which also gets good mileage.
    When you look at it that way -- which I did -- why "save" a bit of money on a smaller, cheaper car that doesn't get better mileage?
    Personal note: I know that I seriously considered the Insight. The ads were VERY cool -- way better than the Prius ads -- and who doesn't want to save money? Honda had the right idea: undercut the Prius, but with all the corners that they cut, they weren't able to be enough cheaper to consider them overall.
  18. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    I think what you are saying is that some of the Insight II drivers are getting better mileage than some of the Prius drivers, or perhaps that some of the Insight II drivers are getting better mileage than the EPA estimate for the Prius.
    Tom
  19. Indyking
    1,280
    First wrong information, now wrong way to think!
    The whole marketing strategy for the insight is "to make hybrid driving affordable". So, I know the LX is poorly equipped compared to the base Prius model (that’s obvious!), but you DO HAVE the option to buy it! As of right now, there is absolutely NO WAY you can buy a Prius below $ 22750, period!
  20. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Geez, guy's lets get back to beating on the oldsmobuick SUV's and recognize the Insight guys and gals for what they are, Comrades in Arms. I would have said fellow travelers, but that just doesn't sound right :rolleyes:
