Do you park then turn off car or turn off without park
Discussion in 'Gen 4 Prius Main Forum' started by Will_Prius16, Sep 3, 2016.
  1. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    I read the "Quick Reference Guide" again (and the first part of the owner's manual) and if I understand correctly, it says to apply the foot parking brake first, then the "P" button. Then Power Off.
    Especially important on a hill, parking brake first, otherwise the car will be resting on the transmission gear?? Something like that. (But, whatever works :). I forget to turn the dang power off half the time!)
    Prius Maximus, grape808 and RCO like this.
  2. Mendel Leisk
    41,467
    Other than to standardize your routine between a Prius and another vehicle with conventional shifter, I can't see a reason to push the Park button when shutting down. Shutting down puts it in Park.
    Keep right foot on the brake pedal, power down, left foot push down parking brake, all done.
    RCO likes this.
  3. Coast Cruiser
    2,267
    2,571
    ....but before the 3 P's, I have to turn off the DRL's, and the AC, and the radio. Then put up the Heat Shields... It takes me about 10 minutes to exit my car. ;)
    RCO likes this.
  4. Coast Cruiser
    2,267
    2,571
    "Anybody that knows me, knows that I'm a book man. I believe everything was put in the book for a purpose. Deviate from the book, and you'd better have half a dozen good reasons... and you'll still get an argument from me. There's the right way, the wrong way, the Navy way, and MY way."
    -Captain Phillip Francis Queeg
    "The Caine Mutiny"
    KrPtNk, RCO and Mendel Leisk like this.
  5. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    I don't know why, but I always use the parking brake. Even when I'm parked for only a minute.
    I always press start to park and turn the car off. Much quicker.
    Mendel Leisk and RCO like this.
  6. cabecker01
    cabecker01 New Member
    Southern Illinois
    I just pull in the garage and press the power button. I only use park when I plan to leave the car running.
    RCO likes this.
  7. dstahre
    dstahre Member
    74
    35
    Cahokia
    Four Touring
    Been there, done that. I accused my girlfriend of leaving her purse (and thereby her fob) in the car because the car was warning me that something was wrong when I tried to lock it! o_O
    RCO likes this.
  8. Frederickdawg
    Frederickdawg Active Member
    596
    335
    Florida Unfortunately
    Pull into garage depress parking brake and then press P then start to shut down.
    SM-G928T
    RCO likes this.
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Encore un fois, et encore!
    krmcg likes this.
  10. grape808
    grape808 Active Member
    150
    153
    Hawaii
    Parking brake, Park button, Power button, exit car, lock door, sit and read manual for 10 minutes while listening for beeps and looking for errant lights.
    RCO and krmcg like this.
  11. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    Yes! If on a hill, it's best to use the parking brake first, ensure the car doesn't move, then place in park. You don't want to have pressure on the transmission. Years ago if there was too much pressure on the tranny, it locked up the steering and it was difficult to get into drive and go the next time you started.
    I rarely hit park first. 13 years of Prii, and 99 times out of 100 I just hit the power button. But I live in the flatlands, so I never really need the parking brake. I also have never developed a habit of using the parking brake because way back when with drum brakes, the drums would warp under the pressure, especially if it sat a couple days without use.
    RCO and grape808 like this.
  12. zhaofei
    zhaofei New Member
    Ontario, CA
    In 2017 Prius manual, it say if you turn off power when in D / B / R gear, Prius will going into P automatically.
    I try on my 2017 Prius Touring(Canada), the P LED will turn on for about half second when I power off from D
    RCO likes this.
  13. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    My UK Biz edition, (similar to US 3 model) also goes to park if I press the Power button before the Park button and then turns off. Found this out a couple of times, so all the tuition I've received from you good guys has completely gone to waste :LOL:
    krmcg likes this.
  14. gvp1995
    gvp1995 Active Member
    199
    141
    Three Touring
    My routine is:
    1. While the foot is still on brake, press "P"
    2. Apply parking breaks
    3. Power button.
    The reason for this slightly reversed sequence is the fact that "P" is only illuminated when the headlights are ON. So when I go in the pretty dark garage (I use headlights on AUTO) there is a delay maybe half a minute or so before the headlights are switched ON and I can see where the "P" button is. This dark dashboard (together with the fact the "P" was in completely different place in Gen 2) was enough for me to press something else thinking it was "P" in the dark, and since the parking brakes was already applied (as I did in the beginning), the car did not move but in was still in "D"!!! I guess such sequence was the main reason the parking brake issue was discovered, and led to recall.
    The "P" button must be illuminated at all times in my opinion.
  15. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    In UK my Park button does light up whenever selected and if I Power off before selecting Park whether the headlights are on our not..
  16. gvp1995
    199
    141
    Three Touring
    In the US it is also lights up WHENEVER SELECTD. But not before it is selected. The problem is to select what you don't see.
    When the headlights are ON then the "P" button is illuminated with a blue light. When you press it, additional green light appears on the button. When the headlights are OFF then there are no lights are on "P" button, and this is a problem when it is dark.
    RCO likes this.
  17. gvp1995
    199
    141
    Three Touring
    Valid message
  18. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Why don't you keep your lights on till after you've selected Park? I don't think that should prove too difficult if locating the button at night is the problem.:)
    Prodigyplace likes this.
  19. gvp1995
    199
    141
    Three Touring
    In the night there is no problem as the headlights are ON and Park button is illuminated. The problem for me starts when during the day I go into rather dark garage and cannot see any of the button on the dash board. I use my headlight on AUTO. (Why - is a topic for another discussion). First when I read that there is a problem with the parking brake, and it can disengage if the car is not in the "P" mode, I thought only idiots could do it. But after doing it myself a few times I realized there is a systemic issue here. Then I started consciously looking for "P" button before I do anything else. Otherwise if I apply parking brake first, I could end up having the car in "D" mode without knowing it.
    BTW, some other people reported similar issue on this forum but during the very bright day!
  20. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Strange! Mine sounds an alarm if I accidentally try to power off before going to neutral and won't let me. With the greatest respect, may I suggest you either use a small torch, or develop a routine (with a checklist of necessary), where you turn the side lights on in order to see the Park button illuminated before you shut down. However, in tempted to think you are overthinking this INTO a problem that doesn't actually exist.
    krmcg likes this.
