Do you run fog lights all the time (factory or aftermarket)
Discussion in 'Gen 3 Prius Main Forum' started by Jonny Zero, Nov 22, 2012.
  1. Yes, I run them any time the low beams are on, as a cosmetic toy
    13.5%
  2. Yes, I run them any time the low beams are on, to supplement the low beams
    18.9%
  3. No, I only run them in foul weather
    35.1%
  4. No, not ever, they are useless for seeing
    8.1%
  5. No, not ever, the extra power use will drop my MPGs.
    5.4%
  6. I don't have fog lamps on my Prius.
    18.9%
  1. DoPeY5007
    DoPeY5007 Member
    122
    17
    I must have missed that option, LOL
  2. Vas25tl
    Vas25tl Member
    268
    77
    Milwaukee
    Mine are always on if my headlights are on. For visibility, and it looks nice :)
  3. Air_Boss
    Air_Boss Senior Member
    4,197
    1,183
    New Yawk
    I'd like a 55W equivalent halogen lumens H11 LED replacement bulb...
  4. Former Member 68813
    3,524
    983
    US
    NONE of the answers is correct. Fog lights are for fog use only. People who use them all the time are very inconsiderate to other drivers. They produce lots of glare on wet roads.
  5. El Dobro
    El Dobro A Member
    7,088
    3,270
    Even when I had cars that had them I wouldn't use them.
  6. Air_Boss
    4,197
    1,183
    New Yawk
    In which case they still function well as stone catchers...
  7. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    <rant on>
    In North America Fog lamps can only be on when the headlamps are on. Check your laws and you'll find this is the case.
    The -reason- we invented "fog lights" was that head lamps reflect off the fog back into the drivers eyes, making it difficult to actually -see-. Fog lights are most effective in yellow, as that colour reflects least in fog.
    But our illustrious lawmakers were worried we would use the fog lamps as headlamps. So they make them useless, BY LAW.
    <rant off>
    Pearl had them and I tried them as driving lights (they were white not yellow). They were useless other than they helped me to see what I was about to run over (they only illuminated about the first 20 feet of highway).
    Pearl S doesn't have them, and with the way the law is I don't intend to add them.
  8. Air_Boss
    4,197
    1,183
    New Yawk
    At less than 100% intensity, they do however make great, legal (in New Yawk, at least) solo DRLs .
  9. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Your v has 55W bulbs? Mine Liftback Five has 19W H16 bulbs for fogs.
  10. Air_Boss
    4,197
    1,183
    New Yawk
    The v Five has 55W H11 fogs.
  11. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    When I installed the fogs on my III I used the marker lights as a signal source for the relay so the fogs can be used with or without the headlights both high or low beams. This was explained in the install thread and where I got the idea. Like I said before I don't use mine other than in Fog or Heavy snow as I run HID bulbs in them and when not in fog or heavy snow are way too bright for other drivers. on my Gen II the driving lights had LED bulbs and just looked cool they didn't make for any problems for other drivers since they put out very little light. I say driving lights as that is what NYS calls the lower mounted "white" lights. They define a fog light has having a yellow lens or producing a yellow light.
