Do you think the Prius rear suspension is too low?
Discussion in 'Gen 2 Prius Main Forum' started by silentak1, Oct 24, 2006.
  1. silentak1
    silentak1 Since 2005
    893
    28
    LA
    Am I the only one who feels that the Prius has a low rear suspension? I have the mudguards and coastaltech hitch and I feel that sometimes they are danger close to the ground. I really try to stay away from carrying more than 4 people (including myself) in the car or else I feel like the rear is heavily sagging.
    I could take out the mudguards and hitch, but that's not really the issue. The car looks ackward when fully loaded with passengers and gear.
  2. Tideland Prius
    16,158
    Yeah, I've bottomed out with 3 people in the back. I would say it's to do with the ground clearance. I'm sure my Camry would lower just as much but will have a smaller chance of bottoming out because of the slightly higher ground clearance (except for that oddly protruding exhaust pipe....)
  3. Oxo
    Oxo New Member
    533
    Oxfordshire, UK
    <div class='quotetop'>QUOTE(silentak1 @ Oct 24 2006, 10:51 PM) [snapback]337803[/snapback]</div>
    Yes, I've found it much too low. There's a speed hump in a road near here and if I have only one passenger in the back I always hear a nasty bang on the floor when I go over it, even at 3MPH. I would hesitate to drive this car on a very rough road with deep depressions in it, but I've never had the same problem with any other car. It's my biggest criticism of the Prius.
  4. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    I want an adjustable Citroen style suspension on the next model.
    Bottoming and snow clearance are real problems.
  5. afternoonnap
    afternoonnap New Member
    33
    Ontario, Canada
    <div class='quotetop'>QUOTE(tomdeimos @ Oct 25 2006, 07:06 AM) [snapback]337878[/snapback]</div>
    Me too! Hope Toyota is listening, or someone finds an aftermarket solution.
  6. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    The TRD kit, although it makes the car lower, bottoms out less due to a stiffer ride. The stock suspension has a lot of give for ride comfort.
  7. Tideland Prius
    16,158
    <div class='quotetop'>QUOTE(Presto @ Dec 3 2006, 02:27 PM) [snapback]357111[/snapback]</div>
    Yeah but it's not exactly comfortable to begin.
  8. medusawoman
    medusawoman New Member
    <div class='quotetop'>QUOTE(Oxo @ Oct 25 2006, 04:37 AM) [snapback]337861[/snapback]</div>
    I've also found it way too low, especially on the rarely repaired Western MA roads I travel. One bump I avoided almost all the time nearly took out my exhaust system one very snowy day. Luckily, the skilled repair shop near here welded it, saving me many $$$ in replacement costs...
    Still having fun with my 2001 - 109,900 miles and counting....
  9. Technogeek
    Technogeek New Member
    142
    Seattle, WA
    I wonder if there are any air shock kits or adjustable height coil-over kits that could be adapted to the rear suspension.
