Do you think winter's effect on EV is given enough attention?
Discussion in 'EV (Electric Vehicle) Discussion' started by Skoorbmax, Oct 28, 2011.
  1. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    This prior winter (starting in 2010) there were virtually no Leafs on the road and no Volts. Now that there are some I've seen a few numbers posted and the range hit while warming up the car is severe.
    For example this Leaf owner: My Nissan Leaf Forum • View topic - range/efficiency maximization with heater indicated that if he threw caution to the wind his 80% charge, which normally gave 60 miles, was projected down to give only around 37.
    At least one Volt owner here has posted some numbers, too, and they're not pretty.
    We've always taken for granted that the heat from an ICE is hugely wasted, but it's always been a superb--and "free" (rather no worse than normal--way to heat a cabin.
    Rough numbers tell me that cost per mile of a Leaf in harsh winter conditions with the heat on bust are probably fairly similar to running a Prius.
    There is no easy way around this. The Leaf and Volt have some methods by which to minimize energy while trying to improve comfort, like heated steering wheel and seats (normally a luxury item in other vehicles), but nothing makes a person feel toasty like warm air and, short of insulating the doors and windows, that requires energy.
  2. wjtracy
    wjtracy Senior Member
    11,314
    3,588
    Northern VA (NoVA)
    Last winter Consumer Reports did a prelim report on Volt and reported 2 mile/kWhr versus the normal 3 mile/kWhr in winter. I then used this number to calculate that represents quite a bit of fossil fuel burned at the power plant. My number was so ugly I will not repeat it here. Believe Leaf may not take as bad hit (at least last years version).
  3. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    The poster in that thread is in Arkansas (midwest US not terribly far north) but apparently he'll have weather like this 3 or 4 months worth out of each year. Ironically the averages for my city in Tennessee are lower than his and I don't consider it cold here.
    But as to what I think about the cold and EV use, I think some leaf owners need to readjust their thinking pattern on charging.
    Using the 120v charger instead of the 240v charger will charge slower but will ensure the battery is warm when you unplug it in some scenarios. A full charge is listed in the wiki as
    • Level 1 (120V) - 18 hours
    • Level 2 (240V) - 7 hours
    But you may not be driving to 0%. So say you make it home at 20% charge and you want to get to 80% charge, the net charge needed is 60% or about 10 hours on Level 1 or 4 hours on level 2.
    If you start charging as soon as you get home at say 7 PM the L2 charger will leave the battery pack to cool down after it's done charging in 4 hours so if you leave for work at 7 am it has 8 hours to cool off.
    Take that same scenario with the L1 charger and it isn't done charging until 5am and only has 2 hours to cool off. Go one step further start it at 20% SOC at 7PM and request a 100% charge cycle with the L1 and at 7am it'll still be charging somewhere in the 9x% range (above 90% below 100%). Since charging produces waste heat you'll have a warm battery as you pull away from the house (warmer than using the L2 charger unless you time it just right).
    That warm battery will behave better in terms of delivering power on the outward drive away from the house. If you can plug in the L1 charger at work it'll be warm for the drive home but even if you don't the warmer battery will hold charge better on the outward drive giving you better efficiency and getting you to your destination with a slightly higher SOC.
    Also, we know 80% charge is easier on the battery but if you only deal with truly cold weather for 2 or 3 months a year just change your habit to ask for 100% charge in the coldest months to offset the heater use.
    In short
    1. favor the L1 charge rate if it'll get you near 100% charge before you need the car
    2. favor 100% charge vs 80% charge in the coldest months
    It won't make the hugest difference in the world but it'll help.
  4. dhanson865
    851
    188
    TN, USA
    Oh, and I didn't address choice of EVSEs in that post. There is an in between option for those who got the wall mounted L2 EVSE
    see My Nissan Leaf Forum • View topic - Fast Low Cost Charging - All EVSE Questions Answered! for more details
    You can choose at the time of upgrade if you want it to charge at 12a * 240V or at 16a * 240V
    If you want it to charge faster you can do the 16a option. If you want to make your battery last longer (plan to keep the vehicle years down the road) you can charge at the lower amperage to charge slightly slower.
    3.84 kW (240 x 16 amps = 3840 watts, a 16-amp L2 EVSE)
    3.30 kW (220v * 15a = 3300 watts "nominal" EVSE description)
    2.88 kW (240v x 12a = 2880 watts (L1/L2 EVSE)
    1.44 kW (120v x 12a = 1440 watts standard L1 EVSE)
    In other words by choosing your EVSE you can charge slow, medium, fast or low, medium, high.
    I'm suggesting using the 12a L1 or 12a L2 vs the Nissan spec L2 or the 16a modified L2 as the slower charging will be easier on the battery long term and could help you keep the battery warm in winter conditions.
  5. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    It's time to bring back gasoline powered heaters for cars to increase EV range in the winter.:D Southwind heaters were good heaters.
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    This is, admittedly, a subject I have wondered about with my Model S only about 9 months away (hopefully). Winters can be pretty bad in SW Missouri (not terrible, just bad) with cold spells below zero for several days at a time. With the PHV Prius having no electric heat (other than the 400W PTC heaters) you either bundle up and go in EV in the cold (with seat heater) or you run the ICE for cabin heat.
    I do have a heated garage at home. I hope that that, combined with the ability to preheat the car while plugged in will make at least my commutes from home fairly comfortable without giving a big hit on range. But when I park at work it is outside/exposed and no place to plug in. Gotta think that's gonna be either a cold ride home or an expensive one (energy wise).
  7. rpatterman
    rpatterman Thinking Progressive
    756
    226
    Boulder, Colorado
    Ok, I'm a little confused here. You heat your garage with fossil fuels, but are concerned about a slight winter time hit to your EV numbers. Wow!
  8. DarkStarPDX
    DarkStarPDX Junior Member
    26
    Hillsboro, Oregon, USA
    The range reduction due to colder temperatures has nothing to do with the battery.
    The type of battery in the Leaf and Volt has an optimal operating temperature range of 0° F to 100° F. Not like a NiMH or NiCad battery that prefers to be at exactly 68° F all the time.
    The reason for reduction... The owners are using the heater more and probably driving a bit more aggressively in order to either use the heater less or to get out of the cold weather faster. :D
    After preheating from shore-power, I noticed that the heater will draw about 1.5 kW continuously with the occasional bump to 3 kW in my Leaf. Since my commute takes just over an hour (one way), that's about a 10% reduction in range. I've gotten a lot better about pulsing the heater as necessary manually in order to keep things comfortable and have reduced my additional consumption to around 5%. With some luck, the seat heaters I'm ordering next week will allow me to reduce my additional consumption to around 2% (including the seat heaters).
  9. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    He runs his EV on fossil fuels, too ;)
  10. Skoorbmax
    2,641
    264
    Western NY
    Are you sure? I know other lithium ion batteries, as most batteries, suffer a substantial loss in ability to deliver watts while cold.
  11. efusco
    19,891
    1,191
    Nixa, MO
    Not so much the EV numbers, but the actual real world range and frankly the real world comfort.
  12. efusco
    19,891
    1,191
    Nixa, MO
    I don't have an EV, so currently it doesn't run on anything.
    Probably, initially, it will run on FF, but the plan is that, once paid off (within 12 months most likely) we'll begin converting our home to a hybrid solar/wind system to accomodate the majority of our energy needs.
    It's incremental, but I'm trying to move in the right direction.
    But thanks for the snarky comments to derail the thread guys. :rockon:
  13. SageBrush
    11,627
    2,530
    Southwest Colorado
    My back of the envelope calc says that 4 season climates will end up with annual energy consumption up to (1.5*4 + 8)/12 = 17% higher than they might estimate from EPA numbers, since that test does not have a cold drive cycle.
    Smart PiP owners are going to rip the Volt (or a pure EV, for that matter) in winter driving by using the CHP ICE judiciously.
  14. gwmort
    gwmort Active Member
    985
    211
    Delaware
    I'm a Volt driver. I've seen about a 20% drop in range since I had to start using the electric heater. (27-36 mi instead of 35-45 miles).
    Pre-heating the cabin before unplugging in the morning makes a world of difference. Once the cabin temp is comfortable the system doesn't have to work as hard to maintain it compared to what it has to do to actually change the temp into the comfortable band. I also find the heated seats key in my own comfort without too much power draw (about 6% of climate system power output).
    In the afternoon I find all the glass and generally black interior tends to have the interior temp significantly higher than the ambient when I get in.
    To be honest, my main concern for this winter is devising some way to cover the plug so a snow or ice storm doesn't freeze the EVSE in place.
  15. dhanson865
    851
    188
    TN, USA
    We know the resistant heater in the leaf is the biggest draw. Ignore it for a second.
    You suggest that the leaf battery pack is practically the same efficiency at 70F it would be at 30F. I disagree with that but lets also ignore that for a second.
    Do you know that the leaf battery pack self discharges when the charger isn't active and the EVSE doesn't have any sort of trickle charge mode to maintain charge?
    Do you know that Leaf owners have set their car to charge to 80%, gone to bed and woken up to find it was closer to 70% than 80%?
    Charging at a lower rate so that it will still be charging when you wake up not only is less harsh on the battery long term, not only keeps the battery warmer in the winter, it also keeps the battery for self discharging during the period between the L2 charge ending and you actually powering up the vehicle.
    And of course the big one of charging to 90%+ if you can vs stopping at 80%.
    Again self discharge is only worth a few percent but when we are talking about winter usage I'm saying all these couple of percent here and there add up.
    Slow longer charge targeting 100% vs 80% on a faster charge could
    1 provide longer battery life in terms of years / charge cycles
    2 keep the battery warmer in winter usage
    3 reduce non charging time, reducing self discharge
    4 actually give a higher state of charge when you leave the house if your usage/charging patterns allow.
    And I'm not saying you have to do 100% of your charge at 120V x 12a. If you know you are at the edge of your range / charge time window you can charge at L2 rate targeting 80% for an hour or two, then go stop the charge process and plug up the L1 and start charging again at the slower rate targeting 100%.
    Depending on how good you are at controlling the process you could end up with a higher SOC and a battery that's in better shape to handle the conditions.
  16. hyo silver
    hyo silver Awaaaaay
    15,232
    1,562
    off into the sunset
    I would assume Nissan did extensive cold-weather testing, but real-world, average consumer experiences will be interesting. The only winter battery testing I've done is while skiing. The tunes have to go in an inner pocket, or they fade out surprisingly quickly. I hope the same doesn't happen with EVs, because that will just add another excuse for the dinosaur crowd.
  17. fuzzy1
    10,048
    While we usually take for granted that the ICE 'waste' heat is free, we do know that it really does burn more fuel in winter. And it burns more still when the cabin heat is turned up.
    When comparing costs, are folks including the extra fuel the Prius needs in winter? It is not fair to compare Leaf's winter cost to Prius' fair-weather cost.
  18. Skoorbmax
    2,641
    264
    Western NY
    Not very much, though...
    How? With an engine at normal operating temperature even with the cabin heat on bust the thermostat is still moving fluid through the radiator. Unless you're in such cold temps that the cabin heat is not allowing the car to reach normal operating temperature why would it be burning more fuel (ignoring some miniscule amount of alternator stress turning the fan).
  19. dhanson865
    851
    188
    TN, USA
    I don't know about you but for me at less than 10c a kWh (electricity is cheap in my state) the leaf is so much cheaper to use the cost per mile isn't an issue.
    If I could afford to buy a new car and if I could live with the range limitation the Leaf is the cheapest per mile cost (if you drive it regularly)
    I'm in a used Prius and will be for the foreseeable future but I hope someday to be able to grab a used Plug in Prius or Nissan Leaf that someone treated well and use it.
    I don't think it matters if the Prius drops 20 MPG in the winter vs summer and the Leaf drops range in the winter. I don't think the cost differential will be the biggest factor.
    I think range is the one thing people worry about and have to manage.
  20. fuzzy1
    10,048
    Mine consumes about 10% extra in winter -- see my two year mpg graph -- and I don't even have a 'real' winter climate. Other than extra rain.
    During my city commute, the ICE spends a lot of time turned off, and the ScanGauge often reveals a coolant temperature drop of 30-40F, despite grill blocking. In winter, cabin heat cools it off much faster, and often forces the ICE to fire up for heat while I sit at lights. Therefore I often use no heat, or turn it off at lights to allow ICE shutdown. Drivers with 'real winter' will see far worse engine cooling, even with a grill block.
    The hardcore CleanMPG hypermilers see this extra winter fuel consumption in standard ICE vehicles too, and go to great lengths to minimize heat losses.
