Do you use parking brake?
Discussion in 'Prime Main Forum (2017-2022)' started by Michael Nielsen, Feb 11, 2017.
  1. ChapmanF
    18,945
    Maybe that's the habit you should 'brake'. Or rather, just form the habit of releasing the brake before driving.
    Even if I'm in some other car that hasn't got a parking brake pedal over there, my foot will usually slam the floorboard in that corner before I drive away.
    Prius_10_inside and fuzzy1 like this.
  2. Trollbait
    12,800
    With electric parking brakes, the car might auto disengage it when the accelerator is pushed.
  3. Mendel Leisk
    42,248
    Anybody else tuck their foot under the pedal, to verify it’s released?
  4. Trollbait
    12,800
    Not with Toyota's push again to release pedals. Maybe once on cars with a separate pull release, but those were cars before I regularly used the parking brake. The Chevies had a hand brake, and the Subaru is a switch.
    Louis19 and Mendel Leisk like this.
  5. El Dobro
    El Dobro A Member
    7,102
    3,282
    My Bolts automatically set the parking brake on a steep enough incline, when you hit the park button. If you forget to release them (I rarely do) they will release when you move.
  6. Louis19
    Louis19 Active Member
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Yep I seldom use it , only when parking in a steep incline in above freezing temp. Not to crazy about the push again to release pedal. Never in winter with slushy salted roads.
  7. Trollbait
    12,800
    Starting with the 2005 Prius, I've always used the parking brake. Felt like its Park gear had a wider range of roll to it than my previous cars. Just been a habit ever since.
  8. Washingtonian
    Washingtonian Senior Member
    726
    621
    In the six years I have owned my car the only time I used it was to disengage it when picking up the car after a dealer service. Not that I am against parking brakes. I often use the hand parking brake on my 4Runner when parked on an incline.
  9. ChapmanF
    18,945
    ... and while this is a 2017–2022 forum, as long as Gen 2 is mentioned, if you have a Gen 1 or Gen 2 you had better use the parking brake regularly; that's what keeps the rear drum brakes adjusted.
  10. fuzzy1
    10,687
    Nearly always. For decades.
    Isaac Zachary likes this.
  11. sylvaing
    sylvaing Senior Member
    1,215
    514
    My Model 3 sets/release its electric parking brakes by itself. Only thing is, being a RWD, only the rear wheels are locked. I've seen videos of Model 3 sliding down a slippery driveway because of that.
  12. Mendel Leisk
    42,248
    AFAIK that’s typical, regardless of vehicle drive type.
  13. sylvaing
    1,215
    514
    Yes, but with a FWD with an automatic transmission (like the Prius), the transmission locks the front wheel so with a parking brake, all wheels are locked. In case someone mention this, with a manual transmission, the engine becomes the "brake" when in first or reverse gear.
    Trollbait and Mendel Leisk like this.
  14. Mendel Leisk
    42,248
    Ah ok. I was differentiating "locked by parking brake" vs "restrained by transmission", but I see your point.
    I'm honour-bound to always set the parking brake: my missus does not like that queasy back-and-forth shift of a car just held by the transmission.
  15. sylvaing
    1,215
    514
    Lol, just like my wife doesn't like when I press the park button on the Models 3 and the car still have some momentum. Dead stop in a few inches.
  16. Trollbait
    12,800
    While cost was is big reason, the parking brake is another reason for drums in the rear. Parking is one of the few things disc brakes aren't better at, and many rear discs have a small drum build into them for that reason. Others have additional clamping mechanisms for the pads. Perhaps these are no longer needed with electric parking brakes.
    Does Tesla, or any EV, have a parking pawl or similar in the drive unit?
  17. Mendel Leisk
    42,248
    I was replacing the the rear (disc brake) pads on our son’s CX-5, has electronic parking brake, and getting nowhere trying to retract the caliper pistons. Finally googled and found there’s a chicken-dance involved, and then they just push in.
    gggGary likes this.
  18. El Dobro
    El Dobro A Member
    7,102
    3,282
    The Bolt has a pawl.
    Trollbait likes this.
  19. fuzzy1
    10,687
    Coming from a line of mostly manual transmissions, I've experienced an old engine having not quite enough compression and friction to hold on some hills, and a transmission that would pop out of first gear in certain conditions. And a relative distracted by unexpected visitors so not immediately noticing a flubbed shift on a 4WD transfer case, causing it to pop into neutral after stepping out.
    Still having multiple manual transmissions around, the parking brake is one of my ingrained habits.
  20. sylvaing
    1,215
    514
    Not Tesla. They have electric motors pushing the pads against the discs.
