DOE eGallon tool
Discussion in 'Prime Fuel Economy & EV Range' started by Marine Ray, Oct 29, 2019.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
    Useful eGallon tool on Department of Energy website. Here's my state, Nevada. Almost two thirds of our electricity is produced by natural gas.
    eGallon | Department of Energy
  2. Marine Ray
    1,139
    949
    Sparks, NV
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    Interesting. But they must be using average gasser vs average BEV number to come up with the difference in cost. Unfortunately, if you compare HV vs EV on PRIME, the number is not as optimistic as shown on this site for some states. For me, HV and EV cost/mile are currently dead even to slightly more on EV.
    #3 Salamander_King, Oct 29, 2019
  4. Marine Ray
    1,139
    949
    Sparks, NV
    Is it because both your cost of electricity is high and gas is low?
  5. Salamander_King
    11,024
    8,977
    New England
    That could be true compared to the state average. But it attribute more to the PRIME's efficiency on HV mode. Average gasser they used to calculate the number is probably 25-30mpg. But as I and you know very well, PRIME is capable of getting 54 mpg EPA rating on gas alone, and if you drive conservatively, it can easily get over 60mpg closer to 70mpg. Even the best BEV on market is around 4.5miles/kWh EPA. Average likely to be lower than that.
    #5 Salamander_King, Oct 29, 2019
  6. Salamander_King
    11,024
    8,977
    New England
    From the linked doc on eGallon:
    For instance, if the average 2015 passenger car adjusted combined fuel economy, mi/gal is 27.9 mi/gal and the average efficiency for the top selling U.S. EV brands in 2015 is .326 kWh/mi, the price of an eGallon would be:
    27.9 mi/gal * .326 kWh/mi * .1269 $/kWh = $1.15/gal
    Now, you do the same calculation but substitute the PRIME (or Gen4 Prius) as a gasser on HV mode for 54mi/gal and use the US EV brands average .326kWh/mi (BTW this is equal to 3.06miles/kWh), and my current residential electricity cost of .195 $/kWh
    54.0 mi/gal * .326 kWh/mi * .195 $/kWh = $3.43/gal
    Current gas price around my area is $2.45/gal.
    eGallon cost is quite bit higher than actual gas Gallon.
    If I do this calculation with the real life numbers on my PRIME using 65mpg and 4.5miles/kWh (=0.222 kWh/mi)
    65.0 mi/gal * .222 kWh/mi * .195 $/kWh = $2.81/gal
    eGallon cost is still higher than actual gas Gallon.
    #6 Salamander_King, Oct 29, 2019
  7. Marine Ray
    1,139
    949
    Sparks, NV
    Darn the Prime for being so efficient both MPGe and MPG !
    Salamander_King likes this.
  8. Zythryn
    Zythryn Senior Member
    6,409
    4,409
    You can’t take a generalized statistic and fault it for not being the same numbers you get for your personal transportation.
    If you drive more efficiently on gas, you will get better than average annual fuel costs. That doesn’t mean the car sticker that shows the annual fuel expense is useless. It, like the MPGe stat is a valuable baseline.
    Marine Ray likes this.
