does 2010 prius have more power than 2009 prius?
Discussion in 'Gen 3 Prius Main Forum' started by tuzik1978, Jun 14, 2009.
  1. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Don't forget, past the 50% point on the pedal, Eco, Normal, and Power have no difference in response.
  2. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    Right. As though someone would ever press a pedal that far!!
    (Your foot would go right through the floor, right?):eek:
  3. taftjr
    taftjr New Member
    72
    Marlborough, MA
    I think EV mode gives you better acceleration without using the ICE in the 0-25MPH range vs. EV off.
  4. stefcat
    stefcat New Member
    102
    maryland eastern shore
    the 2010 does have more power than the previous prius.. The prius is not a car that's for revving up. I know when I'm driving mine. I can hit 70 and not realize it.. mine second-generation... I have got a chance to drive the 2010 and I feel little bit of difference... it's been stated to read other threads. 100% agree. I have learned so much from this group..thanks stefcat:cheer2:
  5. Mr. Nelsby
    Mr. Nelsby New Member
    37
    Chelsea, MA
    Just so we are clear... you don't really "rev up" a hybrid. Because the engine(s) work on an algorithm which determines the optimal performance of the electric and fuel engines, there are times were you can be running silent...
    ... if you are looking for a car that you can make noise with, this might not be the car for you.
  6. Steve Cebu
    Steve Cebu New Member
    523
    59
    Concord, NH
    That's possible. :)
    It's kinda tough to balance it out if there are any hills. It doesn't take much of a grade to need enough power to shut off EV mode.
    But for parking lots or any flat areas like at the beach (not on it) :eek: it's great fun to use it. :D
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    The Prius uses a planetary gear based transmission to split and utilize power from the engine and electric motors. It simulates a CVT transmission in operation which means there are no "gears". So if be "Rev Up" you are meaning the jerk and accelerate or clutch and shift that people are use to in conventional automobiles you won't ever get it in a Prius.
    As always your best bet is a good test drive just to feel if you can be happy with the operation of the vehicle. The 2010 has a bigger engine and the available power mode but it still doesn't have a conventional transmission. You'll either be happy with it, or not be able to get used to it.
