Does 2010 Prius NEED wheel covers???
Discussion in 'Gen 3 Prius Main Forum' started by Stealth Prius, Nov 10, 2011.
  1. dz302
    dz302 Prius Rookie
    South Carolina
    That looks great. Any tricks to get the wheel covers off easily? Also, did the tabs on the wheel covers leave any scratches on the wheel?
    Thanks.
  2. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    Thanks - some here have also gotten Toyota emblems that they attached to the finished face of the knockouts. Me, I don't need to overstate the obvious and just went plain-Jane.
    Nope - there were no scratches left by the original covers that I could find and they pry off fairly easily.
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Just grab roughly opposing spoke on the wheel cover and give it a yank. No tools required
    I didn't notice any marks on my wheels.
  4. Tideland Prius
    16,634
    Well each cover has an area where you can wedge a flat-blade screwdriver if you wish but I usually just grab two of the spokes and yank it out.
    Just don't let the service technicians pull it out (e.g. tyre rotation or swapping tyres). They use the same tool they used to remove the wheel covers off steel rims but the difference is that they leave a mark on alloy wheels.
  5. dz302
    dz302 Prius Rookie
    South Carolina
    Thanks guys, I appreciate it.
  6. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    The bare 15" alloy wheels have an obvious look that they are designed to have hubcaps on them (the groove near the edge of the rim). I suppose the basic advantages would be -
    Don't have to remove hubcaps to clean the wheels.
    Much easier to unscrew valve stem caps (which can only turn with fingertips)
    disads -
    Hit a curb and you've scraped the wheel
    Have to put in center caps
    w/o center caps, they look pretty bad.
  7. Tideland Prius
    16,634
    Yeah it's double the work for me with the covers on - I have to clean both the covers and the rim itself. I tend to leave it off during the winter because it can get pretty dirty behind the covers if I had them on with the sand and salt and so forth. It's a little easier to maintain in the summer so I put them on whenever I feel like it or if I take a road trip (why not maximise mpg while i'm at it, eh?)
  8. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I'm attaching some piccies with the oem centre caps. yep they were $86.00 AUD but I don't spend much on frivolities usually.
  9. Yogi56
    Yogi56 New Member
    156
    26
    Escondido, CA
    Has anyone swapped the 15" OEM's with a chrome exchange company? Just looking for some pictures to see if it's a good look or not. Love the 15's ride with more air between the road and the seats but the 17" look is nice.
  10. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I saw a Gen III Prius with chromed 15 inch wheels a few days ago so they exist.
    My personal dislike of chromed aluminum wheels side... Chrome tends to make wheels look smaller. If you scrape a chrome wheel on a curb it's basically trashed. If it's polished aluminum or painted you can repair it and have it look like new.
  11. dz302
    dz302 Prius Rookie
    South Carolina
    Ok, I bought 1 1/2" covers and they are way too small. Looks like it will take 2" covers. I have a '12 Prius v with the larger wheels so I guess that's why. I should get them on later tonight and I'll post pictures.
  12. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    The wheel covers enhance the Prius's stealth. If you want a stealthy Prius you should leave them on. Just Kidding on or off its your call. If you do remove them please get some center caps.
  13. dz302
    dz302 Prius Rookie
    South Carolina
    Took off my covers and put on center caps today.
    The new v takes 2" covers.
  14. swoodchuk
    swoodchuk Junior Member
    Bel Air MD
    If you remove the hub caps on your Prius, does this affect the dealer's Warrenty in any way?
  15. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    No.
  16. Jrz
    Jrz New Member
    Annapolis, Maryland
  17. Jrz
    Jrz New Member
    Annapolis, Maryland
    I removed mine and am now hearing a lot of road noise from tires at about 55 mph - 65 mph. I believe this is cause. I'm putting mine back on to check and see if noise stops
  18. EddieDesigns
    EddieDesigns Junior Member
    78
    42
    16
    Hilliard, OH
    Mine:
  19. phickson
    phickson Tron Pod Occupier
    89
    31
    Maryland
