Does actual capacity of traction battery decrease linearly with age?
Discussion in 'Gen 3 Prius Technical Discussion' started by briank101, Nov 11, 2014.
  1. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Problem is sealing the modules after refilling with distilled water.
    How do you do that?
  2. Mendel Leisk
    42,376
    Put some fresh tape on?
  3. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    What sort of tape you're talking about?
  4. Mendel Leisk
    42,376
    What sort of battery are you talking about; that could be causing confusion? I meant the 12 volt (and any sort of tape, say electrical), maybe you're talking about the big battery?
  5. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I'm talking about the traction battery.
    If you go through the comments of Bill, at the beginning of the thread, you'd see where he talked about his experiment with a traction module, where he added distilled water, and the cells came back to life.
    The problems a lot of people had with topping up the modules, were how to seal the openings back.
  6. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Thais is in reference to the quotes above by Bob.
    So, @Mendel Leisk . tapes or electrical tape can never work.
  7. Mendel Leisk
    42,376
    Apologies, I'm not following this thread closely. I saw this:
    And jumped to conclusion your question was regarding the 12 volt.
  8. bisco
    52,891
    same. actually was more of a step than jump :)
  9. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Yeah, .y mistake too, Mendel! So sorry.
    A whole lot of mix up here then.
    Mendel Leisk and bisco like this.
  10. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Yeah, my mistake Mendel, a lot of mix up on my part.
    CR94, Mendel Leisk and bisco like this.
