Does anyone else think the instant MPG gauge is useless?
Discussion in 'Gen 3 Prius Main Forum' started by phoenixgreg, Apr 12, 2010.
  1. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    I have noticed that the gauge to the right of the MPH readout really isn't too useful. It will let you know if you have a steady foot, but the CHG/ECO/PWR graphic is pretty much the same thing. I'm betting Toyota put it there to impress your passengers, but it's valuable real estate on the dash that could be put to better use.
    I'd rather see a gauge that shows the 12v battery life either as a graphic or numeric display. Since the ICE is not running full time, things like oil pressure or engine temp may not be valid as in traditional gauge packages where the ICE is running constantly. But a 12v battery readout would let you know when you should change your starting battery. What do you think?
  2. Joe166
    Joe166 New Member
    720
    96
    South Florida
    I disagree. I find that it is more helpful than any other gauge for me to see if my foot is too far down, AND if letting up a little might be a reasonable thing to do, given the traffic flow.
    2 people like this.
  3. vday
    vday Member
    312
    Israel
    I agree
    I has its use
    Wouldn't mind other gadges as well
    2 people like this.
  4. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I find the instant MPG gauge very useful--for 50 MPG and below. Above 50 MPG it's not very useful, since it's super sensitive in that range.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    I disagree as I think it is very useful as immediate feedback, especially if I have another screen other than the HSI displayed.
  6. dtuite
    dtuite Silverback
    182
    31
    Redwood City, CA
    It's the easiest way to tell you're gliding. Accelerate, come off the gas, add a little pressure back onto the pedal -- if the gauge goes to the top, you're gliding; if it doesn't, you're adding too much pressure (maybe you're on an upslope; maybe you're too heavy-footed). You can pick all that information up out of the corner of your eye, something you can't say about the other economy displays.
    Also, you can tell when the ICE is still cold, because you'll be gliding, but not reaching the top of the "gauge."
    2 people like this.
  7. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Like others, I totally agree the guage is extremely useful. I use it all the time to keep my mileage peaked. As a matter of fact, I'm right at 59.7mpg, hoping to hit 60!
    I also agree that two other gauges would be very helpful: 12V battery voltage and engine coolant temp.
  8. DickPhillips
    DickPhillips Member
    89
    58
    Mount Vernon, WA
    It is useful to me to monitor my current driving. As others have said, it shows what you are doing right now. I do wish that the accumulative MPG figures were more accurate. I record those from the car computer and then my spread sheet makes a calculation based on the actual fuel used & miles traveled and the actuals are always less than the car computer calculates. It really could be closer.
  9. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    Very useful (when using L/100Km instead of MPG) (fuel consumption: gas per distance; instead of the weird US distance per gas measurement).
    0 L/100km: Engine is off (at 72km/h or less) or not turning without burning gas (at more than 72 km/h)
    2-4L/100km on the highway, going into heretical mode
    7.5-10 L/100km: brisk acceleration without going into PWR zone
    10 L/100km upper limit: innefficient acceleration into or over the PWR zone, may be anywhere between 10 and ~35 L/100km...
    With the instant fuel consumption gauge, I can confirm very quickly when I glide: the indicator falls instantly to 0.
    Also, while coasting, I know when the engine is warming itself up (1-2 L/100km) or charging the batteries (~5 L/100km).
    Maybe it's only me, but I can't understand the concept of "infinite miles per gallon" when you glide. Totally counter intuitive.
    Due to the nature of the MPG beast (US MPG or Japan km/L). Doesn't react this way on the rest of Earth.
  10. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    I look forward to being able to track fuel efficiency as Liter per 100 km or gallon per 100 mi, just like the rest of the world.
  11. bigdog1234
    bigdog1234 New Member
    144
    23
    US
    I agree. I think the instantaneous mpg read-out is what I use most, and is also how I determine when I'm powering off of the battery and not the ICE. .
  12. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Very useful on the Prius and non-hybrid cars as well, when they are so equipped. I use it in conjunction with the HSI indication and find that combination far better than what we had with the Gen2.
  13. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    I like it. I wouldn't want something that only lights up every 5 years telling me to change the 12v battery.
  14. phoenixgreg
    1,157
    289
    66
    Phoenix
    I can see most of you are big fans of the instant MPG gauge. I did some checking and found a good article on the use of the HSI (what I called the CHG/ECO/PWR graphic). Here's the link if you'd like to get a further understanding of its use:
    HSI
    Personally, I've had instant MPG readouts on prior cars and found toggling to the AVG MPG much more useful. I know we have that below the HSI...I'm not sure if CONS. means "constant" or "consistent" MPG, but it's the same idea. Again, since the HSI tells me as much as the instant MPG, I'd rather have a gauge that told me the health of my starting battery. Without that information, you could get stuck in the middle of nowhere after a few years of 12v battery wear.
  15. jdcollins5
    5,131
    1,338
    Wilmington, NC
    The CONS means consumption.
  16. tumbleweed
    4,067
    687
    Eastern Oregon
    You may already be aware of this but in case you haven't run across it yet - the 12V battery doesn't actually start the ICE. It's function is to power things when the car is in the Acc or On modes, i.e. not in Ready. When you do go to Ready the 12V battery supplies the computer and closes the relays that apply power to the inverters from the traction battery. Once the traction battery is on-line it supplies everything and charges the 12V battery as well. The ICE is started by MG1.
    A couple of 6V dry cells in series would do the job with power to spare. In fact you could use them as a backup and just hook them to the jumper connection in the under hood fuse box.
    I will probably replace my 12V battery after 4 or 5 years to be on the safe side, I hate to be stranded also. I will most likely use one of these: 12 Volt (12v) Toyota Prius Auxilary Battery for 2004, 2005, 2006, 2007, 2008, 2009 and 2010 with installation kit The OEM 12V battery from the dealers is a rip off.
  17. Tom183
    Tom183 New Member
    652
    65
    Maine
    Yeah, like RPM - would be even more useful...
  18. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    I honestly love the instantaneous MPG meter. It helps me see how economically I am driving at that VERY moment. Lets me also see how warmed up my engine is depending on how many MPG's I'm getting. Not to mention, if I'm at highway speeds sometimes I can't tell if my engine is on or off. When I see that MPG meter at 100, I'm for sure it's off. I like it.
  19. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    The HSI is a representation of power requested, and likely a reasonably "stable" fuel flow. Thus, the same power requested at higher speeds will translate to higher MPG as you're going faster for the same fuel consumed.
    Many could do some math on it, but it's a lot easier to have a rough estimation w/ the instant gauge.
  20. F512M
    F512M Member
    415
    Laguna
    It's great. It helps me keep my foot off the pedal. :)
