Does anyone have a link for the mini vci driver?
Discussion in 'Prius OBDII Third-Party Apps' started by RathlinPhil, Nov 9, 2020.
  1. RathlinPhil
    RathlinPhil Junior Member
    Rathlin Island, Ireland
    2001 Prius
    I
    I've got the cable without the software, I have successfully installed techstream though it cannot find/communicate with the vehicle. When I first plugged the cable in, the computer said it was obtaining and then successfully installed the drivers from windows updates. Does it have them or do I need another driver?
    cheers. Phil.
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,997
    4,738
    Texas Hill Country
    Its tricky and the instructions are cryptic. Of course you have to do registry changes as well. I installed on Win7 Pro 64 bit. These are the links I received:
    V13.00.022
    64bit: MEGA
    32bit: MEGA
    winRAR32bit MEGA
    winRAR64bit MEGA
    "Please confirm your computer system first ,32bit or 64bit , then download and unzip the right version by winrar or other programs , you will get a folder with all files,Just follow the instruction step by step." [From supplier]
  3. RathlinPhil
    2001 Prius
    I
    Thanks alot , I'm using windows 7 32 bit. I was reading about loads of people going out looking for an old laptop with that setup for techstream but it just happens that's the only computer I have . Had it for donkeys years..cracked version of Windows 7... Never gives any bother...
    I'll try and stick these files on and follow the instructions.
    I'm trying to get to the bottom of inverter trouble and I need techstream.
    Cheers for the links.
  4. rjparker
    7,997
    4,738
    Texas Hill Country
    I would read the instructions carefully. Uninstall previous attempts. After installation, shutdown and restart. Don't expect techstream to fix or recalibrate an inverter problem especially on an 01 Prius.
  5. RathlinPhil
    2001 Prius
    I
    Thanks I will....
    No I just need to read the sub codes to know where the problem lies, I have replacement inverter but I want to be sure the problem is in there.
    Ps.
    Did you mean uninstall the techstream software ? Or the windows mini vci drivers?
  6. rjparker
    7,997
    4,738
    Texas Hill Country
    Everything
  7. James Willis
    James Willis New Member
    Rockdale, Texas
    Got my mini vci cable with software for TS ver 12, 13, and 14 but no driver for windows 10, 64 bit. The seller sent me a link to the file on a google site but the site claims its a virus and will not allow mw to download. Desperately need a win 10 64 bit driver as the chinese national I am dealing with is apparently clueless. The files listed in an above post no longer exist on that site.
  8. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Welcome to PriusChat!!
    Which browser are you using?
    This site may be helpful for techstream and installation : https://blog.obdii365.com/
    If that doesn't help, then try this search : mvci driver win 10 at DuckDuckGo
