Does anyone know the part# for backlit Door Lock Switch?
Discussion in 'Prime Accessories and Modifications' started by robAlatte, Jun 1, 2021.
  1. robAlatte
    robAlatte Member
    60
    40
    Palm Springs, CA
    Im looking to replace the door lock switch on my 21 Prime Limited with the factory OEM Led Backlit Blue door lock switch. I know this can be done on my 21 Rav4 Hybrid too, so I assume its just as easy for the Prius Prime but not sure which part to use or where to find. Any suggestions or point of reference is superbly appreciated.
  2. Bruce22
    Bruce22 Junior Member
    Coastal CA
    Buuuuump
  3. Elektroingenieur
    2,515
    3,288
    Three Touring
    robAlatte and PiPLosAngeles like this.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,976
    New England
    I don't know the parts number, but are you talking about the door lock switch panel on the driver-side door? The red arrow in the photo is from 2020 PP LE when I took the panel off to wrap it.
    PiPLosAngeles likes this.
  5. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    I think OP wants the driver's side lock switch to be illuminated like the passenger side switch. I would also be interested in this modification. I assume they're interchangeable?
    Salamander_King likes this.
  6. Salamander_King
    11,024
    8,976
    New England
    In my 2020 PP LE, I don't remember if it was illuminated with a blue LED or not, but my photo looks like the switches do have LED embedded (red arrows). Or is he talking about the illumination on the master lock (blue arrow)? I no longer have the car. I can't check how those light up. Did these switches change to no LED in 2021 PP?
  7. PiPLosAngeles
    1,551
    724
    The door lock/unlock switch. On the passenger side it's illuminated and on the driver's side it's inexplicably not lit.
    robAlatte and Salamander_King like this.
  8. Salamander_King
    11,024
    8,976
    New England
    OK, is the light where the green arrow is pointing in the photo? And this no longer exists in the 2021 models?
  9. PiPLosAngeles
    1,551
    724
    No. The actual lock icon is lit on the passenger side. I'll take a picture when my zoon meeting is over.
  10. Salamander_King
    11,024
    8,976
    New England
    Humm, I must admit, I have never paid that much attention to any of the switches. I can't remember if they were lit on either side on my 2020 and 2017 PPs.
  11. PiPLosAngeles
    1,551
    724
    It drives me crazy when I'm dropping people off at night and I need to unlock the doors. I have to turn on the dome light to see the switch.
    This is the passenger side.
    Mendel Leisk and Salamander_King like this.
  12. Salamander_King
    11,024
    8,976
    New England
    So, 2020 and earlier PP had this illuminated lock on the driver's side? Again, I don't remember how it was (or was not) lit on my 2017 and 2020.
  13. robAlatte
    robAlatte Member
    60
    40
    Palm Springs, CA
    Apparently, the earlier than 2021 Prius Primes had the backlit Drivers Door Lock Switch. It's just stupid that they did not illuminate the drivers door lock switch but they did on the passengers. If anyone knows which switch or panel to purchase, I would absolutely be so grateful.
  14. robAlatte
    robAlatte Member
    60
    40
    Palm Springs, CA
    Was it easy to pull the door lock switch plate up? Do you just use a Spudger to lift it or does the disassembly require taking the arm pad rest off?
  15. PiPLosAngeles
    1,551
    724
    I don't think the driver's side was ever lit. I don't know about the passenger side because I never rode on that side of the 2018.
  16. Salamander_King
    11,024
    8,976
    New England
    If it wasn't lit in older models, then why does OP thinks there are parts that available that will have LED inside??? Now, I am confused.
  17. PiPLosAngeles
    1,551
    724
    Because the passenger side is lit. Are they not interchangeable? If not, how much modification is necessary to make them fit?
  18. Salamander_King
    11,024
    8,976
    New England
    Driver side and Passenger side door lock buttons are not the same size as shown in my photo on comment #4. Besides, the Driver side switch is a multiple switches panel including a power window lock and four windows open/close and it has a totally different lead connection IIRC.
  19. PiPLosAngeles
    1,551
    724
    I hadn't noticed the size difference. That's a disappointment. I wonder how difficult it would be to get the driver's door button illuminated.
  20. citiprius
    citiprius Active Member
    241
    238
    51
    2018 Prius Prime
    Order the same part for 2020 PP model year, it will work.
