Does anyone know the part# for backlit Door Lock Switch?
Discussion in 'Prime Accessories and Modifications' started by robAlatte, Jun 1, 2021.
  1. citiprius
    citiprius Active Member
    241
    238
    51
    2018 Prius Prime
    Correct. 2021 model they just make 1 button illuminated (driver side window up/down), cost saving?
    Here is how it looks for 2020 model:
    2020/2021 comparison
  2. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Is it a drop in replacement?
    Bruce22 likes this.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,976
    New England
    @Elektroingenieur linked to his comment on the parts number. If you are sure that earlier than the 2020 model had the illuminated switch panel then 84040-47070 or 84040-47090 should work.
    • 84040-47070, through December 2018;
    • 84040-47090, from December 2018 through July 2020; and
    • 84040-48210, from July 2020.
    Yap, it's just snap on. IIRC, you will need to remove the armrest pad to release the panel, but the pad is also just clip-on,
    Bruce22 and PiPLosAngeles like this.
  4. PiPLosAngeles
    1,551
    724
    Can someone confirm that the lock/unlock symbols are lit on part #84040-47090? My recollection of my 2018 was that it wasn't, but I'm not positive. That would mean the other two part numbers are not illuminated and only 84040-47090 is illuminated. Bonus if all the window buttons are illuminated.
  5. Salamander_King
    11,024
    8,976
    New England
    @citiprius commented on #21 showing the photo of the 2020 model with the lit door lock button. You may be correct that prior to 2018, it wasn't lit, but I don't remember noticing the difference between my 2017 and 2020. I never paid that much attention to the button. I rarely do nighttime driving and almost never needed to manually lock or unlock the door using that button.
  6. PiPLosAngeles
    1,551
    724
    It might be my old eyes, but it's difficult to tell in that picture if they're illuminated or just a tad overexposed. If they're illuminated I'm going to grab one. Here's to hoping I don't break anything disassembling. I've never taken apart those pieces so I hope they can just be carefully pulled off using enough force, gentle of course.
  7. Salamander_King
    11,024
    8,976
    New England
    Plastic ply tool will help, but any strong flat piece will do the job. They are all just snap-in. No screws or bolts.
  8. PiPLosAngeles
    1,551
    724
    I found a part from a parted-out 2020 for $89. Let's see how this goes.
    Salamander_King likes this.
  9. robAlatte
    robAlatte Member
    60
    40
    Palm Springs, CA
    I was following this thread from Rav4world , hoping to do the same thing with the Prius, as long as we can pull the part from a backlit pad, which Toyota does seem to use commonly, across their lineup, it should plug and play.
    Thank you so much!!!
  10. Salamander_King
    11,024
    8,976
    New England
    From @PiPLosAngeles observation, pre 2018 PP did not have the lit lock button either. So your choice is 84040-47090. @PiPLosAngeles said he just ordered used from a junked PP. You can wait to hear from him about the result of the swap.
    robAlatte likes this.
  11. robAlatte
    robAlatte Member
    60
    40
    Palm Springs, CA
    Do let us know when you get it :) Thank everyone here for getting to the bottom of this!
  12. PP2020LE
    PP2020LE Junior Member
    17
    NY
    2020 Prius Prime
    Just confirmed on my 2020 LE that the driver side lock/unlock are illuminated.
  13. PiPLosAngeles
    1,551
    724
    Glad to hear it. I should have the part early next week. As long as it's not scratched or damaged I'll probably install it within a day or two. I'll post pictures.
  14. PP2020LE
    17
    NY
    2020 Prius Prime
    Shouldn't it be covered under warranty?
  15. PiPLosAngeles
    1,551
    724
    It's not lit on purpose.
  16. PP2020LE
    17
    NY
    2020 Prius Prime
    Got it, misread some of the posts.
  17. PiPLosAngeles
    1,551
    724
    Part came today. Installed it in 5 minutes. The only problem I had is that one of the little yellow clips on the original switch assembly came off and fell down inside the door panel during disassembly. If fell down in where it cannot be seen from the top. I'm going to open the bottom and see if it will just fall out without having to remove the whole panel.
    1. The pathetic 2021 switch assembly in the "lit" state.
    2. The pieces unsnapped.
    3. The "twins" meet for a moment.
    4. Assembled
    5. The 2020 assembly in the "lit" state.
    There are two electrical connections that are pretty self-explanatory. All functions appear to be working well.
  18. Salamander_King
    11,024
    8,976
    New England
    Congratulations. Now, all we need is someone with the 2017-2018 PP model to confirm that the lock icons were not lit. It seems odd that Toyota switched from unlit in 2017-2018 to lit model in 2019-2020 then switched back to unlit in 2021.
  19. PiPLosAngeles
    1,551
    724
    The price difference at the dealer is over $200. The 2020 part is ~$360 and the 2021 part is $150. The 2018 part is in the middle at ~$235.
  20. PiPLosAngeles
    1,551
    724
    According to my sister with a 2018 none of the buttons light up. This is with the headlights on.
    Looks like there aren't even places for a lighted window switch on any of them.
