Does anyone know the weight distribution?
Discussion in 'Gen 4 Prius Main Forum' started by Chippingawayatlife, Mar 27, 2017.
  1. Chippingawayatlife
    Chippingawayatlife Active Member
    159
    116
    San jose
    Did anyone figure out the weight distribution for the gen 4? Understandably, there may be a slight difference across the trim levels with the battery and spare tire differences.
  2. Tideland Prius
    16,684
    56:44 according to Toyota
    RCO likes this.
  3. Chippingawayatlife
    159
    116
    San jose
    That's quite a change from the gen 3. Do you have a link I could take a quick read? I tried Google but had no luck.
  4. Tideland Prius
    16,684
    That's correct. The Gen 3 is 61:49 (more front-heavy than the Gen 2 at 60:40).
    I do not have a link. It's from the notes I took at the Las Vegas reveal when I spoke to the chief engineer (translated through the chief designer).
    RCO and Chippingawayatlife like this.
  5. Tideland Prius
    16,684
    RCO likes this.
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Toyota may measure with passengers while C/D measures without, I just had a third party measurement.
    Notice that much of the Eco weight savings is in the back. (rear wiper motor, spare tire?)
    Tideland Prius and RCO like this.
  7. Tideland Prius
    16,684
    Huh.... interesting. You'd think it's standardized. I'm fool to think otherwise. Now I'm curious about the Prime. I was told 53:47. An independent party therefore may measure differently? I guess it makes sense to have a driver in the car. That's ultimately what the weight distribution will be.
    And also the Li-Ion battery.
    RCO likes this.
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  9. Tideland Prius
    16,684
    Chippingawayatlife likes this.
  10. Chippingawayatlife
    159
    116
    San jose
    A lot of interesting specs here. Thanks! I didn't know they released their track sheets online. What's with the left to right weight distribution? About 50 lbs heavier on the left. This has to be with the driver off the vehicle since it's a curb weight, especially since there is no standard driver weight. I'm guessing this is because the motor generator is on the driver side. Other cars have a pretty even left to right weight distribution while the Prius is all out of wack. Does this affect driving feel or anything?
  11. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    If Toyota's quoting their numbers with driver, a Prime has a lot more weight behind the rear axle, so a driver will affect the distribution less than they would in a Gen 4.
    (I know, old thread, but I found this looking up other stuff.)
    Tideland Prius likes this.
  12. Tideland Prius
    16,684
    Wouldn't it make more sense to quote with a driver on hand? The car isn't driving itself around (yet) so it would make sense to include a "standard" driver weight. (Although I guess quoting with one means you can add the weight of yourself on your own to calculate your own weight distribution)
  13. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    The problem is that you need to know where you sit in the car to get that accurately.
    In Europe, the "standard driver" is 68 kg, so there is that that could be used in that market.
  14. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Well what d'ya know. I'm well above average for a European!!!! :ROFLMAO:
    krmcg likes this.
