Does anyone track their Prius?
Discussion in 'Gen 2 Prius Main Forum' started by mattbatson, May 4, 2019.
  1. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    going to attend a track day at either Lowe’s motor speedway, road Atlanta, or CMP and my biggest concern is brakes
    With the regenerative braking I’m not sure how the front brake pads will hold up at the track...not worried about the rear brakes
    Not even sure if I can find performance front pads for the car anyways... unless pads from a corolla or some such fit
    Thanks!
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    While not a Gen2, @TheChip can speak to your situation (y).
    mattbatson and SFO like this.
  3. golfmk681
    golfmk681 Active Member
    262
    105
    los angeles, ca
    Lol what the heck If one desires to track a car that handles like a refrigerator by all means go for it.
    mattbatson likes this.
  4. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    My second gen handles really well actually
    And that is with nothing more than a little over a degree negative camber and a big rear sway bar
    I’m getting another set of wheels for some sticky tires and maybe some Coilovers
  5. fuzzy1
    10,045
    I don't see why this would have any impact. Regen should hardly be used at all on the track. The standard friction brakes should not have been downsized at all compared to similar cars, since hard highway speed braking is about 95% friction before the battery fills, 100% after.
  6. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    Since I will be hard acceleration and hard braking I’m thinking the traction battery will be drained quickly...
    I guess I will find out if brakes start to fade
    Just don’t want to boil the fluid
    So I’ll have to slow down at that point...
    I might just end up having to stick to autocross with it...
  7. TheChip
    TheChip Senior Member
    386
    1,207
    Misissippi
    I'll be out on the track this weekend again with my Gen 3. Regen won't have any impact on your braking. I'll get brake fade on a short track witth a ton of corners like Talladega if I'm extremely hard on them but otherwise I've never had an issue!
    SFO, mattbatson and Raytheeagle like this.
  8. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    Stock pads and fluid?
    Running a performance tire?
    The tracks I mentioned are easier on brakes with long straights...
    Might be ok
    It isn’t racing anyways...so can dial way back a couple laps if I get fade
    Just really don’t want to boil the fluid with the difficulty in bleeding these brakes. ;)
  9. TheChip
    386
    1,207
    Misissippi
    I'm running Max Elite slotted drilled rotors, with EBC red stuff pads in back and Hawk HPS in the front. Fluid is Dot 5, I havent had them fade out badly in the past, but I did fad them on Talladega at the start, but once I learned the track I was fine.
  10. mattbatson
    mattbatson Member
    114
    82
    asheville NC
  11. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
  12. tekstyle
    tekstyle Junior Member
    48
    seattle wa
    my issue with my gen3.is when I dive into a corner hard, and bank a turn very hard, the TC will apply its own damn brakes by slamming on it and completely upset the balance of my car mid turn.
  13. mr_guy_mann
    mr_guy_mann Senior Member
    3,250
    1,358
    NJ-USA
    TC is only concerned with wheel speeds (wheel spin) unload power. VSC steps in if it decides that the car might be "steering incorrectly" (yaw and lateral G don't match the steering inputs).
    Unfortunately there's no "good" way to disable VSC. Toyota designed the system to be very conservative - to the point where some reviewers complain about "nanny mode".
  14. MCCOHENS
    MCCOHENS Member
    189
    81
    Chalfont, PA
    Another vote for decent handling in the gen2. It would benefit from more negative caster up front and bigger rear bar but stock with some decent performance tires it is a hoot. Bleed your brakes, completely so there is no old fluid at the calipers. Old fluid with moisture is a huge cause of boiling. Share your results please.
