Does anyone use 12V carjack/inflator/wrench kit?
Discussion in 'Prime Accessories and Modifications' started by dtsexpert, Jun 15, 2021.
  1. dtsexpert
    dtsexpert Member
    167
    San Francisco
    Just wondering if anyone use this 12v carjack/inflator/wrench kit or similar one?
    Found some one amazon
    This should help to take off the tires for quick repaire.
  2. ChapmanF
    15,616
    Looks kind of bulky and heavy to have in the car all the time. And then she already has it out and doesn't help the dude.
    chickenhawk and dtsexpert like this.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,173
    2,213
    Taylors, SC
    I prefer this cheap 18 pound floor jack with my dad's friend's custom adapters for both the front and rear jacking points for my Gen 3 Prius v.
    Hyper Tough 2 Ton Trolley Jack Red/Black - T82011W - Walmart.com - Walmart.com
    The adapters allow raising the tires above the ground when they are fully flat and when jacked up, they are fully off the ground.
    Many users are surprised that the jack shown will be too high to get under the car when the tire is flat and only find out in an emergency.
    #3 Georgina Rudkus, Jun 15, 2021
    dtsexpert likes this.
  4. pghyndman
    pghyndman Active Member
    498
    465
    CT shoreline
    Good point!
  5. Mendel Leisk
    38,726
    Toyota supplied scissor jack is compact, and will work. My only beef: the "eye" that the torsion bar hooks through is a single-eye casting, and the torsion bar's hook dances around with every rotation. Plus the casting is crap-quality, sheds flakes of metal with every turn. Here's some examples:
    Toyota style (single eyelet casting, unstable):
    Honda style (double eyelet, bent plate, much more stable):
  6. Georgina Rudkus
    3,173
    2,213
    Taylors, SC
    I installed this and use a 21mm ratcheting Gear wrench.
  7. brenthon
    brenthon Junior Member
    GA
    I also use the Toyota scissor jack. Then I have a 12v tire inflator that I got from HF.
