Does anyone use the scan guage II to max regen energy?
Discussion in 'Gen 2 Prius Fuel Economy' started by SLO Cat Wrangler, Jul 29, 2008.
  1. SLO Cat Wrangler
    SLO Cat Wrangler Junior Member
    96
    San Luis Obispo, CA
    Can the scan gauge II be used to maximize current to the battery when breaking?
    Steve
  2. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    um no. and welcome to PC! The SGII measures what is going on but does not add to it or change the readings.
  3. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Well, you don't want to *maximize* regen current going to the
    battery, but you do want to control it. There is an XGAUGE to
    read hybrid battery amps, which should help keep those braking
    events at peak capture efficiency without heating the pack too
    much or falling to the physical brakes.
    I've got an analog gauge which I prefer to having to read a
    number, and I use it *all* the time to try and keep things
    under 50 amps when possible. Often, it isn't, but that's life
    on the road.
    _H*
  4. bwilson4web
    15,528
    Is there a scan gauge widget to read the traction battery temperature?
    I've been able to do a a temperature vs forced-charge graph using my Graham scanner and was wondering if the NHW20s suffer a similar temperature rise.
    Thanks,
  5. brick
    brick Active Member
    1,083
    78
    Upstate NY
    Dan deciphered two temperature gauges, one for the highest reading and one for the lowest (I guess so you can see what kind of delta exists across the pack). No doubt it heats up if you put enough current through it, as I've watched mine head north of 45C in heavy city driving on a warm day without the A/C running. Needless to say I avoid doing that.
