Does battery tender charge hybrid battery?
Discussion in 'Gen 4 Prius Main Forum' started by Jburner, Mar 13, 2022.
  1. Jburner
    Jburner Member
    68
    44
    Wisconsin
    I’ve had this happen several times and I’m wondering if it’s coincidence or if it’s happening because I charge my 12 v battery overnight with a battery tender. Each morning after leaving the 12v battery on the tender, my hybrid battery is almost full on startup. Does charging the 12v battery also charge the hybrid battery?
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    No. It can't. When you shutdown the system, that 12-volt battery is used to disconnect the battery-pack. (It flips a relay.)
    If you truly want to know state-of-charge level, you'll need to use an aftermarket app. The dashboard display is only a generalized depiction.
    52,878
    what is the hybrid battery level when you shut down at the end of the day?
  4. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    Changes in temperature will also change the amount of charge the hybrid battery has and can hold. Since spring is rolling in, the battery will start to be able to hold more charge than the winter.
  5. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    I once a couple times a year charge my 12v battery and it always seems I get better MPG after doing so. No scientific reasoning here, just my personal judgement.
    FYI: I always personally try to charge my battery to 80%, or at least 50% if leaving it overnight or a few days. For me its not too difficult, just keep the car from using the hybrid battery to cruise down my street and then slow down to charge it before pulling into the driveway.
  6. bisco
    52,878
  7. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    If I understand the hybrid system explanation by The Car Care Nut and others on YouTube (for what that’s worth) there is no physical connection between the two when everything is shut down, so it shouldn’t be possible. Plus, considering the size of the traction battery, the battery tender isn’t capable of charging it to that level overnight unless it putting out a lot more amps than I understand them capable of at the tender setting.
