Does ECO mode hurt the engine in the long run?
Discussion in 'Gen 4 Prius Main Forum' started by FuriousPrius, Jan 1, 2022.
  1. FuriousPrius
    FuriousPrius New Member
    2022 Prius
    That's another thing that worries me. Right now it's 21F outside. If I start driving with the climate control off, it will be in EV mode as you mentioned, The problem is, when it does decide to kick in, I'm already in traffic! It's not going to be warming up in idle like other ICE engines as I'm already out on the road and I may be entering a freeway by that point!
    This _can't_ be good for the engine.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    IF......you have a conventional hybrid, versus a plug-in, it should NOT work that way.
    My C kicks the engine on sitting in the driveway while I am finding sunglasses, adjusting the mirrors, etc. about 30 seconds after I "start" the vehicle. Regardless of climate control settings or outside temp.
  3. ChapmanF
    19,042
    Even when it starts the engine, that doesn't mean it has to immediately thrash the cold engine by shifting all the load to it.
    Even when the engine starts in your driveway, you'll usually notice as you're driving off that the engine doesn't rise above idle much, and the car moves off mostly on electric. The car gradually adds load to the engine as the engine comes up to operating temperature. Sometimes if you mash the go pedal far enough, you'll override that and for that moment it will demand more power from the engine, then go back to babying it until it is warm.
    So unless your driving conditions for some reason regularly force the cold engine to be thrashed, it isn't likely to happen often enough to fret about.
    alanclarkeau and jerrymildred like this.
  4. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Fortunately, that isn't how warm-up actually works. The battery & motor provide a buffer so the engine doesn't have the burden of a full load, preventing strain.
  5. Mendel Leisk
    42,364
    4th gen Prius programming maybe allows more electric-only on start up?
  6. bisco
    52,878
    please don't poke the bear
    Tyfly and Mendel Leisk like this.
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    Let's try to clarify what others have said:
    Just because the engine is RUNNING, does not necessarily mean that it is carrying a significant load......or maybe not any load at all if it is sitting still.
    SO......the answer is: NOTHING that the engine is programmed to do on it's own will "hurt" it in the least.
    With all of the really NASTY stuff that is going on all over the world these days, it is really kind of amazing that people have the time to worry about insignificant crap like this. :eek:
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    I get a little amused at just how many people fret about this. It's like the engineers who designed the most reliable car in the world were dummies. :D
    As @ChapmanF and @john1701a pointed out already, the Prius really babies the engine when it starts up. To get an idea what's going on, make use of the split screen display on the speedometer and select the instantaneous MPG bar. Note that while the ICE is warming up, the car is getting close to or even over 100 MPG. That indicates that the electric part of the hybrid system is doing much or most of the work. I think this is mostly to minimize emissions since modern multi viscosity oils like the 0W16 in your car flow about like water in cold conditions. So, as far as wear and tear on the cold engine, I wouldn't worry anyway.
    Also, the Prius routes the engine coolant through the catalytic converter so that the engine warms up incredibly quickly, again with the goal of reduced emissions.
    pilotgrrl and alanclarkeau like this.
  9. ChapmanF
    19,042
    ... well, routes the coolant through an exhaust heat exchanger thingy, just abaft the (two) catalytic converter(s).
    Tyfly and jerrymildred like this.
  10. jerrymildred
    11,517
    14,171
    Tampa, FL
    Right. I assumed a heat exchanger since just pumping it in there would be ... messy. :D
    That's a GREAT picture, btw. Thanks.
  11. bisco
    52,878
    they're probably frightened by the engineers yeoman duty on the gen3 engine
  12. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Only in the bad-old-days when you had to get a car idling smoothly - by balancing the choke and some judicious jabs at the accelerator did you have to idle before driving off.
    Today - the recommendation by most manufacturers is to start the car, and drive off immediately - but don't load it excessively. In the case of a PRIUS, it won't over-rev as it's a fairly slow-revving engine, and some of the load is taken by MG2.
    Idling on start will only risk glazing the bores.
    jerrymildred likes this.
  13. alanclarkeau
    7,045
    7,593
    It's not on all PRIUS - even in USA by the looks of it. We don't get it here.
  14. jerrymildred
    11,517
    14,171
    Tampa, FL
    alanclarkeau likes this.
  15. sam spade 2
    7,035
    2,804
    2017 Prius c
    But only if you live in Australia, where the pistons run upside down all the time. :ROFLMAO:
    Sorry but I think that is a ridiculous statement. Where did you pull that out from ?
  16. ChapmanF
    19,042
    In some threads, it's the bores who leave the rest of us kind of glazed.
  17. orangecones
    orangecones Member
    46
    28
    NZ
    Wow - 6 months! I think it took me like 3 days of Eco, before I got angry at it and went back to just keeping it in Normal.
    MIkeDr and Mendel Leisk like this.
  18. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Interesting thread. Did Prius always have Eco mode since Gen1? I have never driven Gen1 or Gen2, so I don't know for sure. But I know for sure it had Eco mode in Gen3. If driving in Eco mode all the time did cause bad things to the engine, I am sure we have heard of a class-action lawsuit by now. I for one, always drive on Eco mode. I don't think I have ever switched it to other modes except for the very first few times after buying my first PP.
  19. FuriousPrius
    2022 Prius
    There's only so much the electric motor can handle before having to rely on the gas engine no? If the battery levels were already low during cold start and you're going uphill, whether the battery is warm or not, it will switchover to gas the primary means of locomotion right? And if the engine hasn't run during the initial mile or so of driving, the moment the engine first kicks in is also the moment it's being asked to generate a lot of torque to climb a hill. I cannot see this being in any way healthy or "good" for the engine.
    Yes, it's designed this way, but that doesn't mean it has no deleterious effects on the life of the engine with this kind of extreme heat cycling.
  20. jerrymildred
    11,517
    14,171
    Tampa, FL
    The Gen 2 did not have ECO, PWR, etc. I can't be sure, but I'd be surprised if the Gen 1 did. It was introduced in the Gen 3.
