Does EV Auto utilize brake charging?
Discussion in 'Prime Fuel Economy & EV Range' started by Refurbmike, Apr 8, 2021.
  1. Refurbmike
    Refurbmike Junior Member
    I haven't found this exact question answered, but does EV Auto take advantage of brake charging? I know it can run in hybrid mode, but it seems like the language is worded that only pure hybrid mode utilizes brake charging.
  2. Tideland Prius
    16,558
    I assume you mean regenerative braking? Regenerative braking occurs when you lift off the accelerator or when you press the brake pedal (up to a certain point, then the brake pads take over if more braking power is required).
    Regenerative braking is independent of EV/HV/EV Auto and independent of Eco/Normal/PWR modes. It's dependent on your driving and how hard you brake.
    51,937
    can you quote the wording, or post a pic?
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    As long as it's not in neutral, it'll regenerate as you brake. That's assuming that you aren't slamming on the brakes in a panic stop. Then it just won't have time to regenerate enough to amount to anything.
