Does fuel additives in every fill up harm the engine?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by bonanzoo, Sep 3, 2020.
  1. bonanzoo
    bonanzoo Member
    64
    34
    Los Angeles
    I have been using Lucas fuel treatments for the past 10 fill ups. 3oz per fill up. Sometimes I poured in the treatment before I went to the gas station on a near empty tank. Do you think I caused unnecessary buildup on the spark plugs? I noticed today while accelerating, there was a slight lag. I just finished the bottle on my last fill up so no more additives but I’m wondering if I should check on my spark plugs or possible change them or if you think I’ll be fine.
  2. Kenny94945
    Kenny94945 Active Member
    864
    439
    Sausalito
    2016 Prius v wagon
    Every fill up?
    That may be "over kill".
    It is possible the additives placed a varnish on the plugs.
    Only way to know is to inspect a spark plug.
    You could first do a few full throttle acceleration tests as an "Italian Tune Up" to see if the miss fire disappears.
    FWIW I usually use Techron, a full bottle to an empty tank, then re-fill the fuel tank and drive aggressively until the fuel tank is emptied, then refill and change the engine oil and filter.
    Good luck let us know what you find.
    bonanzoo likes this.
  3. ETC(SS)
    7,572
    No.
    Usually one of the good things about all of the automotive snake-oils and herbal treatments don't really 'harm' anything but your wallet.
    As far as your spark plugs go, YOU checking them won't hurt either but they probably do not have to be changed outside of the normal maintenance periodicity.
    Paying somebody to "check the plugs" is the same thing as paying somebody to change the plugs - minus the cost of the plugs.
    Me?
    I'd stay out of the potions and lotions aisle for a little while.
    Kilmer cracks me up.
    He's got some fairly goofy ideas about hybrids (an oscilloscope?! REALLY?! gimme a break!)
    BUT(!!) He's right about gas treatment.
    FWIW It's not a bad idea to add a bottle of Techron to your tank semi-occasionally, and changing the oil afterwards but I personally stopped doing so a few decades ago and I haven't noticed a diff.
    YMMV
    jerrymildred and bonanzoo like this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Absolutely, positively no GOOD reason to put any "snake oil" additive into your gas or oil or coolant all the time. NONE.
    A good injector cleaner like Techron maybe twice a year. That's it. Anything else is just a waste of money and as you are now suspecting, can sometimes do more harm than good.
    But I doubt that is the cause of your present symptoms.
    If the plugs are still the originals, now probably would be a good time to change them.
    How many miles on the car ??
    In some very specific situations......like maybe the system was just on the verge of shutting down the engine when you step on the gas, there will be a slight hesitation and that can't be "fixed". All 4 of my Prii have done that once in a great while.
    Wide painted strips on the pavement can cause it to feel like a "stumble" when the traction control kicks in too.
  5. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    Can't remember if plugs are due at 100 or 120k. They're easy in the c, relatively speaking.
    I would not expect a small amount of additive per fill-up to hurt anything.
    Given the age of your car, I would immediately suspect any performance-related problem to be hybrid battery related. Have you taken any steps to investigate that angle?
  6. PriusCamper
    PriusCamper Senior Member
    13,472
    5,439
    Pacific Northwest, USA
    Just stop using it every fill up!!! It's a waste of time and money and there's no telling how much more polluted your exhaust is with additives. If you want to use this stuff one to 4 times a year that seems reasonable, but on every fill up, that's just the doings of a cray cray...
    roadrunner and bonanzoo like this.
  7. bonanzoo
    bonanzoo Member
    64
    34
    Los Angeles
    I changed the plugs at 100k and now I am at 150k. I also did Dr. Prius and came back at 80%. However, I don’t know how reliable these readings are.
  8. bonanzoo
    bonanzoo Member
    64
    34
    Los Angeles
    I think I had the same stumble you are speaking of. I have never had this issue before in my C but once in my Gen 3. I’m currently at 150k miles. I changed out the plugs at 100k.
  9. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    Yeah, I don't know that app either. Battery fan clean? c doesn't need much for maintenance, but that one sometimes gets missed.
  10. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    Try to use Chevron as much as you can, it has Techron in it. And it works, it's proven. If you have a high mileage car put a bottle of additive in a full tank before an oil change.
  11. sam spade 2
    7,035
    2,804
    2017 Prius c
    That depends upon how far you live from a refinery.
    In most places, the gas that is delivered to Chevron stations (or any other brand for that matter) does NOT come from a Chevron refinery.
    If it comes out of a pipeline, you don't know who makes it. Whether or not it actually has all of the Chevron additives depends on the truck driver or the station operator. Station owners have been known to bypass the sediment filters on the pumps so I don't trust them much.
    I prefer to put in my own injector cleaner. That way I KNOW it is in there.
  12. ETC(SS)
    7,572
  13. bonanzoo
    bonanzoo Member
    64
    34
    Los Angeles
    I believe the culprit was fake Denso spark plugs. I purchased these spark plugs for only $18, total! I went to Toyota yesterday and picked up 4 of them for $56 dollars and you can tell the difference. The lag is GONE. The mileage is up 5mpg on average! To anyone, DO NOT buy spark plugs off eBay lol. I am so lucky the porcelain didn't shatter inside of the cylinder. The fake spark plugs said made on a continent, LMAO how did I not notice this. The real ones that I purchased said made in Japan. Here are the pics. Welp, no more fuel additives and no more fake spark plugs. I learned my lesson.
  14. ETC(SS)
    7,572
    Cheap lesson!
    Good Luck!
  15. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    Nice work. I inadvertently bought a fake Champion plug from Amazon a couple of years back and that was my intro to this category of counterfeiting.
    Since then I only buy plugs locally, no mail order. No trouble with the local inventory, just a little less convenient.
