Does Higher Tire Pressure Shorten Tire Life?
Discussion in 'Newbie Forum' started by PriusNeckBeard, Jan 11, 2018.
  1. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    I just put Pirelli P4's on my rear tires.
    The tire employee said that running tire pressure higher than what's on the door jamb will decrease tire life significantly.
    What's true?
    Thx
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    That depends on how much. I've got just over one year and 17,000 miles on my Yokohama Avids and they look very even to me. I haven't measured, though.
  3. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Not to my knowledge. However, lower tire pressure will trash your MPG. I run 41psi in both my 2004 and 2010 Prii.
    RCO, William Redoubt and jerrymildred like this.
  4. Prodigyplace
    12,720
    11,852
    Central Virginia
    Years ago, I was told by my tire dealer that the door jamb numbers are designed for comfort, not tire wear. Running higher pressures can extend tire life.
    Notice on Gen 4, they specify higher door jamb pressures for the same tire to help increase their mpg rating.
    Trim Two: 36 front 35 rear
    Trim Two Eco: 39 front 36 rear
    I am running 39/39 on my 2017 Trim Two. Max psi on my tires is 44 so I do not want to go much higher.
    RCO and WilDavis like this.
  5. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Consider what motivation the tire employee might have had in telling you that. My advice is to read all you can about tires and inflation and wear, and extending their life and make up your own mind. PriusChat is a great resource since most of the folk hereabouts are not only knowledgeable, but don't have a vested interest and are only to willing to demonstrate their superior knowledge! "search" is your friend. Good luck, and hope this helps - Wil :)
    Montgomery, RCO and jerrymildred like this.
  6. padroo
    padroo Senior Member
    2,763
    2,253
    Never over inflate a tire beyond the maximum on the sidewall of a tire. Under inflation will wear a tire out faster because it generates more heat than an over inflated tire. Just don't go crazy with it. lol
    He was probably talking about over inflation wearing out the center of the tire but the max pressure should be fine.
  7. fuzzy1
    10,722
    Plenty of hypermilers using higher pressure find increased tread life. In my case, on a past car, the door jamb label turned out to be too low for both hydroplaning and tread edge wear, higher pressure helped.
    That center wear issue was on old technology bias ply tires. Virtually all passenger cars have been on steel belted radial tires for a very long time, and they very rarely suffer this problem. Those steel belts under the tread have almost eliminated center 'ballooning' under pressure.
    milkman44 likes this.
  8. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    In a word: NO.
    Quite the opposite. Low pressure will reduce the life.
    But it depends on how MUCH higher.
    Adding up to 4 PSI won't hurt the tire life.
    Jacking it up 10 PSI or more might.
    Why were the two of you discussing the subject in the first place ??
  9. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    The oem tires are not steel belted, the pressure on the sidewall is 1/2the bursting strength, the car will start and stop better with 38-39 lbs, turn better, track better, and smile more.
    This web site sucks using an iPad , it redirects every time I touch the screen
  10. Diemaster
    Diemaster Active Member
    302
    265
    so. cal
    i haven't touched my tires on my 2.5 month old prime. should i bump up to 39psi? also i heard in another thread that the tires are factory filled with nitrogen. should i bump to 39psi with a air compressor or a shop with nitrogen? if the tires are filled with 100% nitrogen, i dont want to introduce yucky oxygen :D
    and dont apple. maybe surface?
  11. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I've been running 42lbs. front and 40lbs. rear since my first 2004 Prius. My original Prius tech back then said to do it for better mpg's and since the Second Gen. Prius eats tires. Just got 60k. miles on Avid Envigors running that Pressure on my 2012 Prius and there was still plenty of thread left. they were down to 3/32.
  12. bisco
    52,888
    i got 50k out of my oems at 42f/40r and there was still plenty of tread left. 'tire employee' says it all, i think.
  13. Lucifer
    1,014
    486
    Nh
    Oem tires are not nitrogen filled unless a dealer did it, some have found the factory pressure to be very high, a good pressure gauge is a great investment, checking monthly is wise, air is always seeping, especially when tempurtures swing.
  14. Prodigyplace
    12,720
    11,852
    Central Virginia
    Factory pressure is high to prevent flat spots during transport. The dealer is supposed to set them as part of the vehicle prep.
    RCO likes this.
  15. padroo
    2,763
    2,253
    If you top them off with air you are putting 78 % nitrogen in the tire anyway. If it makes you sleep better go for it. lol
    If it's good enough for me to breath (cough cough) its good enough for my tires. By the way they use nitrogen in airplane tires.
    Mark57 likes this.
  16. 12voltman
    12voltman Member
    124
    93
    42F/40R here on my 2010. Great mileage, handling and tread wear .
    Bill the Engineer likes this.
  17. Bill the Engineer
    1,048
    2,278
    467
    Even with always running 40F/40R on my 2010, the tire dealer still complains that I run them under-inflated. They just can't wrap their heads around the fact that I get heavy cornering wear the way I drive. Don't pay too much attention to what the tire dealer says.
    RCO likes this.
  18. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    Was the employee a PhD in mechanical design with experience in finite element analysis, or a guy named Goober with a lip full of chew, a plaid shirt, pointed-toe cowboy boots and a massive exposed butt crack? Just sayin'! because one of these dudes isn't like the other.
    RCO likes this.
  19. Sam Spade
    2,036
    1,024
    2017 Prius c
    Morons. You need a different "tire dealer".
  20. William Redoubt
    1,228
    1,174
    The one thing that I have positively determined is that what is the most common issue that leads to tire wear is driving. I keep 'em pumped, and pumped high. Check them every week and throw a plug in them unless the puncture is in the vertical part of the sidewall. They still wear out. Because I drive on them.
