Does motor oil brand make any difference for the Prius?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Preeeus, Jan 27, 2018.
  1. wjtracy
    wjtracy Senior Member
    11,367
    3,608
    Northern VA (NoVA)
    All you can do is look at Amazon comments etc., bottle quality ratings if you have some idea what they mean, but I am just saying I'd be a little weary of cheaper, small off brands unless there is some reason to believe they are up to quality standards.
    If Mobil-1 High Mileage is missing the ILSAC rating, that could be a valid reason to pick another brand. Knock on wood I have not had the problem yet.
    #21 wjtracy, Jan 28, 2018
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    I don't think that they recommend any such thing......at least not because of the different oils.
    Different change intervals are recommended for different models........and they just coincidentally recommended slightly different oils too.
    It might have something to do with 0W oils being available only in a FULL synthetic and not a blend but I doubt that.
  3. Mendel Leisk
    41,402
    They do actually, well I think they do:
    Oil change in the US schedule is at 10K miles, and then there's this cryptic note in the 15K service:
    And then if you go to footnote 1:
    The whole thing sounds like it was written by a committee, and the one or two poor schmucks who actually knew what's what were overridden: makes you want to light your hair afire and run.
  4. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    I suspect it is because of exactly this--non-synthetic oils have to contain more viscosity index improvers to run a low "W" number; VIIs break down in use and change the viscosity range of the oil more quickly than a synthetic with little or no added VIIs.
    m.wynn and mjoo like this.
  5. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Preeeus likes this.
  6. wjtracy
    11,367
    3,608
    Northern VA (NoVA)
    Spent a few minutes in Walmart checking out labels-
    High Mileage/Synthetics/ 5W-30:
    Mobil-1 High Mileage ACEA A1/B1 (no mention of ILSAC GF-5)
    Valvoline ILSAC GF-5 (no mention of ACEA A1/B1)
    Pennzoil ILSAC GF-5 (no mention of ACEA A1/B1)
    Castrol Edge has both ACEA A1/B1 and ILSAC GF-5
    In the past I paid more attention to the ACEA A1/B1 which I assume to be a good rating. Castrol has both ratings. It is hard to know if lack of the ILSAC GF-5 rating in the High Mileage Mobil-1 is a shortcoming, or an outcome of what they are trying to accomplish with the oil-leak minimization, older car formula.
    PS- I'll say the High Mileage formulations are fairly popular...lots of choice there on the Walmart shelves. Looks like they now have 5W-20 High Mileage now too.
    PPS- I see my Walmart now carrying Mobil-1 filters in the store, after several years absence. I bought 2 but was a bit shocked they were about $10/each when I got home and saw my receipt. Anyone know why the added "A" as in M-103A? I'd like to buy a vowel too.
    #26 wjtracy, Jan 29, 2018
  7. Mendel Leisk
    41,402
    Could it be some manufacturers just neglect to mention? I took a look at some bottles of Toyota oil I have: the 0W20 synth has the ILSAC GF-5, but a 5W20 non-synth does not.
  8. orenji
    orenji Senior Member
    5,887
    3,488
    Mobil 1 0W40 is the only pure synthetic oil made by Mobil. All other Mobil 1 oils have Dino oil as a base. I have been using Mobil 1 0W40 oil and the ICE is running fine. No issues and stil getting the mid 50's in MPG. I would be concern with your mechanics knowledge of motor oil.
    m.wynn and StarCaller like this.
  9. padroo
    padroo Senior Member
    2,763
    2,252
    There is really no need to complicate this, pick a brand that is the right weight and meets or excedes Toyotas specifications
    Change it according to their recommendations and your engine will run a long time.
    I have lost two engines in my life, one oil related and it was my fault.
  10. orenji
    5,887
    3,488
    The right weight is the wrong weight.
  11. padroo
    2,763
    2,252
    For that discussion I will gladly bow out and you can contact Toyotas engineers because I really don't know as much as them.
  12. orenji
    5,887
    3,488
    Have you heard of CAFE? 0w40 is used in other parts of the noncafe world for Prius.
  13. padroo
    2,763
    2,252
    No I haven't, do you drive in extreme heat?
    What is your background?
  14. orenji
    5,887
    3,488
    Yes I do. But that is not the reason to use 40 weight oil. I see you have been a long time member. You need to research motor oil and CAFE standards that is being dictated to all auto manufacturers and shorting the lives of our vehicles. You can do as you wish with your car, but if you want to make it last you will change your oil at 5k miles and use a thicker oil as the vehicle ages.
    m.wynn, paprius4030 and StarCaller like this.
  15. padroo
    2,763
    2,252
    Thank you I will check into it.
    I don't plan on keeping my new Prius as long as I did the old one, but I do all my own work, always have.
    orenji likes this.
  16. orenji
    5,887
    3,488
    There are a few threads on this issue and you will see that only in the US are we being told we must use 0W20 oil.
    paprius4030 and Dxta like this.
  17. padroo
    2,763
    2,252
    I have heard a similar story on another forum about oil. Ford changed their requirements on oil to a lighter weight but not just on new cars but even older cars. I don't remember all the details.
  18. wjtracy
    11,367
    3,608
    Northern VA (NoVA)
    Of course years ago Mobil lost the court battle when the US legal system allowed Castrol refined oils to be called "synthetic". So now it is hard to say what is synthetic, thanks to the lawyers.
    Did you see the new Mobil-1 1-year drain oils? Almost $40 at Walmart vs. $25 for the normal versions for 5-quarts.
    Merkey and Mendel Leisk like this.
  19. Mendel Leisk
    41,402
    The sceptic in me thinks: maybe it's the same oil?
    paprius4030 likes this.
  20. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    Ha, me too but VOA shows add pack differing from other flavors of M1. Said add pack does nothing to point out what makes Advanced Protection such a long drain oil. This leaves base oil open to speculation and, of course, M1 isn't talking. So goes the oil game.
    VOA = virgin oil analysis
    Raytheeagle and Mendel Leisk like this.
