Does my 2012 Cylinder #1 look OK?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DavidinNevils, Mar 7, 2026.
  1. DavidinNevils
    DavidinNevils Junior Member
    42
    Georgia
    QUESTIONS ...
    1. Does it make sense to invest in a replacement head gasket in a little engine with 235,000 miles that may also need "updated pistons ... and rings", and/or some other significant repair/upgrade?
    2. Who do we trust - from whom to acquire a 'rebuilt' or 'updated' engine - or to have this one rebuilt, and what's the going price?
    3. Here in SE-Georgia, USA - who to trust to remove the old engine, and then to install/reinstall the rebuilt/replacement, and adjust everything, correctly?
    Our mechanic is semi-retired (in his 40's) due to service-related injuries, and significant arthritis (doctor says he has the skeletal system of an 80 year old). He can't do engines or transmissions any more and we've previously wasted thousands on incompetent mechanics in shops in the area. (I'm 70 and am not a mechanic, nor do I play one on tv.)
  2. BiomedO1
    BiomedO1 Senior Member
    4,635
    2,433
    Left Coast
    IMHO; at that oil consumption rate; I'd be looking for a fully rebuilt engine with factory recommended modifications/updates. At this point, a head gasket job is ONLY a band-aid to a much larger issue. That oil burn is slowly choking-off your CAT. If you haven't been flushing out, replacing your brake fluid every 5 years, the ABS pump and valve assembly would be vulnerable - another known expensive repair for gen3's.
    It may be time to start looking for another car.
    Sorry...
    #22 BiomedO1, Mar 9, 2026
  3. DavidinNevils
    42
    Georgia
    Sorry...[/QUOTE]
    Given the absurdly high cost of a newer vehicle I see little financial advantage in replacing, vs repairing this one. A used vehicle could bring all manner of 'hidden' expensive failures - on top of the expense to buy it, and new is out of the question.
  4. Mendel Leisk
    42,364
  5. BiomedO1
    4,635
    2,433
    Left Coast
    I hear where your coming from. I do wrench on cars and there are a lot of older, reliable, gas only cars that are cheap and easy to fix. That old mechanic friend of yours may be able to give you some pointers. I'm partial to Toyota's and Honda's; but got a really good deal on an old GMC Envoy 4x4 that gets 17 mpg. It's pretty much a tank and drinks gas like one - but it was free and great for hunting, fishing, and camping. Just a set of coils and passenger side wheel bearing @ 250K miles. Toyota n Honda will be in the low to mid 30 mpg. I've crunched the numbers since I live in one of the most expensive gas states here. Even for me the hybrid break-even point is past 5-6 years, so you shouldn't rule out a straight gasser. The newer the car, the better the mpgs. The only reason I'm in a Prime is because of the major discounts and incentives given during COVID - otherwise I'd be in a gas-only Corolla or CIVIC. That's what I was looking for, when someone totaled-out my daily driver. All those discounts and incentives brought the car's price down to those gas-only; so the extra mpgs was just a bonus for me.
    Hope this helps....
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,981
    Texas Hill Country
    Knowing exactly where you are helps when asking for "who" to use advice.
    1. Does it make sense to invest in a replacement head gasket...
    In my situation, no. But your situation is different. Personally I like to have a newer reliable car if I keep an old one.
    JDM used in Japan engines from a JDM engine distributor, ideally picked up and inspected rather than shipped. A rebuilt shipped from a reliable source like Hybrid Pit in Southern California. But I would not do either unless I had a hybrid shop to lead the decision making at your age and skills.
    The hybrid system really does not need "adjusting" with an engine replacement. Its actually less technically challenging than a head gasket job where valve train and timing is removed and has to be reinstalled accurately. Replacement is within the scope of most shops as long as they don't dump coolant in the ac compressor's connectors and are not irrationally afraid of the orange cables.
    This is where I always recommend finding a smaller hybrid shop even if it means driving an hour or more.
    In many situations, finding another car makes sense especially if your car has not replaced the hybrid battery or brake booster yet. The oil consumption problem won't go away either and could take out the catalytic converter or even seize the engine unexpectedly if the 4 quarts total were used up. Which could happen within a 5k mile oil change interval.
    Hopefully someone here knows a good shop in Georgia or North Florida. I hear about Tampa Hybrids (4 hours from Waycross) and see videos from Royalty Auto Service in Kingsland Ga (probably dealer pricing but perhaps good advice if local to you). Or have a dealer quote something (but it will be a new short block and rebuilt head in most cases). I have seen them suggest a US salvage used engine in situations with financial stress. That should be a hard no.
    #26 rjparker, Mar 9, 2026
  7. DavidinNevils
    42
    Georgia
    I own an '86 Suburban 6.2 diesel. Our other 3 vehicles are 2008, 2011, and this 2012 Prius'. Fuel mileage, hatchback transport convenience, versatility as a 'generator' (via an inverter), and paid-for, mean that we plan to keep all three.
  8. DavidinNevils
    42
    Georgia
    Kingsland is a 4 hour round-trip. That's 'doable'. I'll check that out. Thanks!
  9. DavidinNevils
    42
    Georgia
  10. Hayslayer
    Hayslayer Active Member
    539
    331
    The photos in post 1 show liquid in the cylinder. You can see it beading on the walls. Unless your sparkplug well was full of water when you pulled the plug, it's likely from the head gasket. Here's the next thing to think about for this repair. Often, not every time, but often, this results in a bent connecting rod. The top of this piston at TDC will be slightly lower than the other three pistons. Often times, especially in DIY situations, it goes unnoticed. Until the 'repair' is finished and a week later the rod goes through the side of the block. If you decide to go with a HG job, make darn sure the TDC height of all pistons are compared to deck height to verify whether a rod is bent or not. If it's bent, you're getting into a rabbit hole. Sometimes you're better off with a replacement engine, but it's a lot of work to toss in a used power plant that may have the same issue in its near future.
  11. DavidinNevils
    42
    Georgia
    I'm pretty much resolved that we need to buy a guaranteed rebuild from a fully accountable source. I've asked a local mechanic (shop) what they will charge to do the work and what the entire cost will be. I'm waiting to hear back.
  12. DavidinNevils
    42
    Georgia
    The shop (Kreider Repair in Metter, GA) says they can't find a source for a guaranteed-rebuilt engine to swap in. Since it looks like $7,000-$10,000 to make such a swap (were an engine to be found that meets their standards) it makes sense to spend a few hundred for them to assess whether or not to rebuild this one, instead.
  13. rjparker
    11,125
    6,981
    Texas Hill Country
    #33 rjparker, Mar 10, 2026
  14. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    You could get the short block from Toyota.
    Or, the Hybrid Pit rebuilds them. You could get a re-manufactured one from them.
    I haven't heard of anyone complaining about them.
