Does my Auris Hybrid warn me when the brakepads need replacement
Discussion in 'Gen 3 Prius Technical Discussion' started by Bibster, Jun 12, 2020.
  1. Bibster
    Bibster Junior Member
    28
    România
    Does the car let me know in any way that my Brake pads need replacing? If not, how can I check this myself. Thanks.
  2. ASRDogman
    ASRDogman Senior Member
    8,069
    4,091
    Yes, when you press the brakes and you hear metal to metal and you don't stop!
    You can look through the wheels and see how much pad is left.
    Or, the better way is to remove the wheel so you can look at them.
    Bibster likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Most pads these days have a "wear indicator" on them.......that is supposed to make a screeching noise when they get worn down.
    Other than that, no warning.
    Bibster likes this.
  4. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    Technically two wear indicators. One is visual, you need to take a wheel off and look for it.
    The other is a back-stop, that's the "squealer" sam referenced above. It's usually a little tab of metal bent to face the rotor. When the pad material is consumed past a certain point, the tab contacts the rotor and makes an annoying squeal as you apply the brake.
    That is pretty much your last chance warning before bad things happen.
    Really the best thing is annual inspection of the visual indicator or a simple depth measurement of the pads.
    fuzzy1 and Bibster like this.
  5. Bibster
    28
    România
    Wow, thanks a bunch for the quick and in-depth answers. Mine does make a squealing noise but not when braking normally, but when I'm depressing the brake pedal to start from a standstill while at a stop, for example.
  6. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    Hybrid power system means the brakes aren't always used to stop the car- this can change the pattern for when you hear the squeal.
    The bigger point is, if you're already hearing something like that it is officially time to do a wheels-off visual inspection, or pay to have one done.
    Ed Beaty likes this.
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    IF.....you are starting to move from a stop......why is the brake pedal still depressed ?
    On most all cars, if you are skilled enough, you can partially release the pedal to a point where the vehicle just BARELY starts to move and the brakes will make a "funny" noise. Sometimes a squeal, sometimes a growl. even with perfectly good brakes and that does NOT indicate a problem.
    Bibster likes this.
  8. Bibster
    28
    România
    Sorry, it was a language mistake on my part. I thought depressed meant "released", but I was wrong. That's exactly the noise that I'm talking about: when the car barely starts to move and it makes a funny noise. I was concerned it was a sign that the pads were on their way out. Thanks
    2012 Prius v wagon 3 likes this.
  9. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    All true info above. I'll add that sometimes that little tab thing that is supposed to contact the rotor to give you an audible warning will be misadjusted.
    Once I got that noise (different car), so I took the wheel off, all ready to do a brake pad change, and found that there was plenty (5mm) of pad left and the bendable warning thing was bent too far towards the rotor. So in that case, I bent it back to be properly adjusted and am still driving on those pads.
    I now make sure to confirm that tab is properly adjusted whenever I work on brakes.
    I wonder if the tab thing had been purposely mis-adjusted by the same bad mechanic that stabbed holes in my CV joints, trying to drum up some business.
    Bibster and Ed Beaty like this.
  10. Bibster
    28
    România
    I've changed my front disks and pads and I can confirm that the small creaking noise that occurred when just barely moving from a standstill or when going slowly into a full stop, is now gone. The brake pads were indeed Very worn but not quite to the point where the disk would scratch that metal piece and really start to scream.
