Does my battery need charging or can it be charged?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DougsPrius, May 6, 2017.
  1. DougsPrius
    DougsPrius New Member
    Right now these are the readings I'm getting off each module of a hybrid gen 2 battery.
    Would you consider charging any of these individually, as a whole or just install as is?
    (*********) indicate modules I might concerned about.
    closed = 12v bulb load on individual modules during testing.
    1. 5.78 open circuit, 4.18 closed circuit **********
    2. 7.46 open, 7.2 closed
    3. 7.46 open, 7.3 closed
    4. 6.24 open 5.1 closed **********
    5. 7.46 open, 7.2 closed
    6. 7.45 open, 7.15 closed
    7. 7.36, 7.20 ************
    8. 7.44, 7.20
    9. 7.15, 6.98 ************
    10. 7.44, 7.20
    11. 7.44, 7.20
    12. 7.44, 7.25
    13. 7.44, 7.15
    14. 7.44, 7.31
    15. 7.44, 7.22
    16. 7.43, 7.30
    17. 7.44, 7.30
    18. 7.45, 7.33
    19. 7.45, 7.20
    20. 7.45, 7.25
    21. 7.30, 7.00
    22. 7.44, 7.20
    23. 7.43, 7.20
    24. 7.46, 7.35
    25. 7.46, 7.30
    26. 7.45, 7.20
    27. 7.46, 7.20
    28. 7.20, 7.00 ***********
    Thanks for your help!
    #1 DougsPrius, May 6, 2017
    52,863
    if it is working okay, i would get a grid charger from prolong and exercise it regularly.
  3. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    #1 & #4 look like they have dead cells. #7 & #9 are clearly out of balance, but might be usable after full rebalancing.
    m.wynn and Patrick Wong like this.
  4. DougsPrius
    Can the dead cells be charged to be good again?
    Merged posts, use multi quote
    Is rebalancing the same as charging?
    #4 DougsPrius, May 6, 2017
  5. Patrick Wong
    18,210
    6,526
    No.
    Rebalancing implies that the two modules in question are charged so that they demonstrate similar behavior as the other good modules.
    m.wynn likes this.
  6. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Are positive results better seen when rebalancing a battery pack with a Prolong charger, or would it be best to remove the cells/modules and rebalance them individually before reassembly and reconditioning at the pack level?
    How does one know when to only rebalance a battery pack (including the soaking charge) verses reconditioning a battery pack by rebalancing and then discharging to different voltage levels (.8v, .5v, .1v) multiple times.
    Thank you! :)
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    It looks to me like two bad cells. Whether you replace them or not, it should be grid charged. I would first do a full reconditioning with the Prolong grid charger and then recheck the cells. If they still look bad, replace them and recondition again with the grid charger. It will get your voltages very even if you use it properly and will be a whole lot faster and easier than taking the battery apart for individual charging. Still, plan one or two weekends for it.
