Does Prius refuse to go into N above 42 mph?
Discussion in 'Gen 2 Prius Technical Discussion' started by RhythmDoctor, Mar 9, 2010.
  1. MD_Silver
    MD_Silver New Member
    Maryland
    Here's the money quote on this James Sikes guy:
    Neibert told Sikes after the CHP caught up with him to shift to neutral but the driver shook his head no. Sikes told reporters he didn't go into neutral because he worried the car would flip.
  2. wiselady
    wiselady New Member
    bloomington
    I took my spouses Prius to the auto car wash and when they told me to put it into neutral, I could not get the Prius to do it. After 3 minutes of frustration and even the car wash guy trying it, we could not get it into neutral, which shut down the car wash with alarms and the car ahead of me being stuck in the washer. Then I FINALLY got it into neutral!
    You have to HOLD the stick in the neutral position for a FULL ONE OR TWO SECONDS, before it responds and does so! Simply pushing it and releasing the stick or batting it to neutral DOES NOT WORK! I did that a dozen times! This is why people say they cannot get their runaway Prius’ to shut off or go to neutral. You have to have the presence of mind while going 90 mph to let go of one hand on the steering wheel while standing on the brakes and then HOLD the stick in the neutral position! At 100 mph, this is would be an eternity to have only one hand on the wheel! I rarely drive my spouse car. It has gotten older and the shifter often does not "spring" back into the center position and at times it seems to get confused as to what position it is in, but fortunately this usually happens when first starting the car. I am convinced these people are telling the truth because having to HOLD the stick in the neutral position for a second or two is not intuitive when you ar ein a panic.
  3. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    There is no regen in neutral.
  4. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    It's a half second or less for the neutral timeout, which at 90
    mph is all of 66 feet. Less than a truck length.
    _H*
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    And Park or R will do it instantly.
    Once again, drivers need to learn how to operate a particular car. I won't fly an unfamiliar aircraft, nor will I drive off in a car that I don't understand.
    Tom
  6. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    SURVEY SAID! What is the fastest way to shift to NEUTRAL?
    #1) PUSH THE PARKING BUTTON?
    #2) SHIFT TO NEUTRAL?
    #3) SHIFT TO REVERSE?
    answer from the gurus........SHIFT TO REVERSE OR HIT THE PARKING BUTTON.
  7. dogfriend
    7,512
    1,189
    Carmichael, CA
    Yes, I actually scared the dogs because I yelled at the TV when he said that.
    My GF who is no technophile said "Isn't it common sense to shift into neutral?'' and I yelled Yes!, scaring the dogs again.
  8. RhythmDoctor
    RhythmDoctor Member
    135
    Swarthmore, PA
    Wow, that's a little condescending, don't you think? Maybe I won't come around here again.
    I did some research, and it said don't go over a certain speed in neutral. So I asked my question. The simulator that I linked showed the same thing you mention - except when the ICE is disconnected from the gear box (i.e., in neutral), it is not clear to me that its RPM is relevant at all.
  9. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    I the ICE never disconnects from the planetary carrier. When you select N it disconnects electrical connections from MG1 and MG2, field windings I think. Everything inside the the transaxle stays mechanically connected at all times, no clutch, no torque converter, no shifting gears, etc.
  10. Yossarian
    Yossarian New Member
    17
    Atlanta
    Yeah, it was probably easier to dial a cell phone and reach under the dash to grab the accelerator pedal.
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I think this goes with the Darwin comment in page 2... I dont have a manual, but it only took me 2 tries when I first got the car to realize I have to hold it there. So even if you have never had to or wanted to go into neutral, it shouldn't have taken a sane person more than 3 seconds to figure this out.
    I also find it funny how these incidents are increasing in frequency now that people think it is an epidemic. I dont think your family Prius watches the news and consciously thinks "if they are doing it, I might as well too"... Even if you believe it happens at all, you can't deny that there are just way too many reports of idiotic drivers doing stupid things and then trying to blame their cars for their stupidity.
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    No problems with shifting to N at 100mph and full throttle.....
  13. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    Yikes! when going to N at 100, does the rpm spike or just drop?
  14. autoxic
    autoxic Commuter
    111
    Richmond, VA
    At 90MPH, in a 2004 Prius, shifting to N at full throttle produces no jolt or engine sounds for me. The engine speed drops and the car coasts. Sorry, I have not tested above 90 MPH.
  15. qbee42
    18,058
    3,076
    Northern Michigan
    Drops. You can't get the RPMs to spike on the Prius, other than making the ICE work hard. Even then the RPMs are limited to something like 5,000.
    Tom
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    It just drops off. It feels almost identical to the sensation of simply letting off the throttle. Very smooth with zero lack of control issues. I then used the brakes to slow down to 65mph, put the gear shift in Drive and continued on my way.
  17. Sheepdog
    1,125
    Sanford FLorida
    You can go into drive at 65? cool! Even after 2 years of Prius bliss I still find myself thinking conventionally about things like this. I would not be comfortable doing stuff like this in any other car.
  18. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Yup, and it is as smooth as silk. :)
    I'm used to doing things like shifting in and out of gear at high speeds due to my racing background but I've been reluctant to try hitting the park button at those high speeds. I'll have to try it someday but since I know the other methods work and are easy to perform I am satisfied for now. :)
  19. 2009Prius
    2,705
    511
    63
    Hopefully even at high speeds this would bring the car into neutral as others posted earlier (for lower speeds presumably).
  20. qbee42
    18,058
    3,076
    Northern Michigan
    It works at all speeds above a crawl. At very low speeds it shifts into Park.
    Tom
