Does regenerative braking trip the brake lights?
Discussion in 'Gen 2 Prius Main Forum' started by tom1l21, May 13, 2009.
  1. Tideland Prius
    16,643
    The lights won't turn back on. It's only if the driver's door is never opened (e.g. if you're in the garage and you turn the car to IG-ON and then off. The lights stay on until the battery is drained if you're not careful.
    The new one is linked to a timer (thank goodness)
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Yup, and just to be clear, several owners -HAVE- exited their car from the passenger side, due to close parking in underground lots etc. Some have even damaged/destroyed the 12V battery doing it.
    One owners son drove him/her to a store and waited in the car, listening to the stereo, until shopping was done. The 12V battery was fully depleted (which makes me think it was a her as most men can't shop that long ;) ). They thought it was the stereo, but the lights didn't go out, and they draw a lot more than the stereo (unless, of course, you happen to have a boom box car). ;)
  3. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    Im kind of confused on this. If I turn the car on with the first power on stage and listen to the radio for say 30 mins (or whenever the car automatically shuts off), then start the car back up, It seems like the battery doesn't go down at all. However, If I press the power button two times and listen to the radio, it looks like the battery goes down much quicker (this is without AC on). What else is being turned on that will eat the battery much faster with the second power on? Sometimes I find it kind of annoying with what you are allowed to do on the power on stages. If I am listening to the radio on the first power on and want to put the windows down, I have to power on again (2nd stage), lower the windows, then power off and power on again to get back to the first stage. Am I doing something wrong or is this the only way to do this?
  4. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    Hello Tom:
    As far as I can see you are correct: to get the windows down or up, you need to cycle from "accessory" to "on"; then to "off", and then back to "accessory", to get back to only playing the radio.
    It's just that "accessory" on the Prius may do less than current "regular" autos, such as not be able to put the windows up or down. The other big difference is that there is no "rotary key switch" on the Prius, so instead of switching from "on" back to "accessory, you have to first cycle through "off". That sort of bothers me also. Buy I've gotten used to it.
    As far as why the battery goes down more quickly (and I assume that you are referring to the SOC meter for the traction battery): my observation is that most everything is energized in "on" mode that would be energized in "Ready" mode, except that the ICE cannot run. Maybe someone here knows better and can enlighten us on this.
    Anyway, in "on" mode, I assume that there are other system functionalities that are drawing electrical power (such as the cabin fan, traction battery fan, etc), which eventually comes from the traction battery. Included in this would be the 12v battery, which gets is power from the traction battery (I think).
    Best wishes,
  5. Patrick Wong
    18,210
    6,515
    The various Prius power states that you can enter are similar to the power states that you can select with a normal automobile that has a key ignition. With a normal vehicle, you can select accessory position to listen to the radio or ignition on (where the engine has not started and where electrical drain is quite high).
    Here is a list of the four Prius power states:
    IG-OFF: all systems turned off
    ACC-ON (first push of POWER button w/o depressing brake pedal): MFD is on, you can turn on the stereo system, no dashboard lights are on. 12V battery drain is relatively minimal here.
    IG-ON (two pushes of POWER button w/o depressing brake pedal): Most dashboard warning lights are on, you can raise and lower windows. As you discovered, do not leave the car in this state for any significant period of time as 12V battery drain is quite severe. This is because the powertrain electrical systems are consuming power but since the vehicle is not READY, the 12V battery is not being charged.
    READY (depress POWER button while brake pedal is depressed): The car can be driven.
    There's nothing wrong with the procedure that you indicated for lowering the windows.
  6. Tideland Prius
    16,643
    The battery we're talking about is the 12V battery. The battery you're talking about is the high voltage battery (Also known as traction battery). In IG-ON mode, everything is powered so you can operate the fan and the power windows etc. This also means the traction battery is also "on" (or connected if you will) so the battery will be drained.
  7. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    By now I think you've received all of the info you need, though I don't know that anyone has answered this question within your post. The real issue addressed in the series of posts above is that you can drain the 12V battery, pretty easily in fact, by leaving the lights on. The headlights, in particular, draw a significant amount of juice from the little 12V battery in our cars. If you leave the headlights on, they will be turned off automatically after you exit the car -- but you have to open the driver's side door to make this happen.
    So, if you sit listening to the radio for 20 or 30 minutes while in the On position, and the 12V battery is in good shape, you should have no problem. If the headlights also are on this entire time, you'll be placing a heavy drain on that 12V battery. If you draw it down far enough, you'll damage the battery. Eventually, you would get to the point where the car will not start. Worse, of course, is if you walk away from the car, leaving the headlights on. It will do more than kill the 12V battery!
  8. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    +1 on what Patrick said -- he's Da' Man on technical stuff like this :cheer2:
    I'll add this for the sake of completeness, :) or overkill :rolleyes:
    In the following, the voltages come from my ScanGauge, which will
    read voltage even in IGN-OFF. :rockon:
    IGN-OFF: On a strong 12v battery, readings in the mid-high 12's are to
    be expected.
    ACC-ON: readings in the low-mid 12's.
    IGN-ON: again, readings in the low-mid 12's, but relatively quickly
    dropping into the high 11's. Note: this means that 12v battery is not
    being sustained/refilled by the HV battery, same as in IGN-OFF and
    ACC-ON.
    READY: readings in the high 13s-low 14s are typical as the HV battery
    is keeping the 12v battery topped off. Note: Only in this state will the
    HV battery, the green/blue/purple bars on the batery mimmic,
    decrease over time, and the 12 v battery stays topped off. The good
    news is that should the HV battery go "into the red," actually purple,
    the ICE will start-up and typically run until the first blue bar is
    showing.
    Again the readings come from my ScanGauge. Here is another
    excellent reason to get one. You can listen to the radio in ACC-ON with
    the least 12v battery drain, yet monitor the status of the battery and
    at some preselected voltage, for me 11.5v, put the car in READY to
    top off the 12v battery from the HV battery.
    If this keeps you from running the 12v battery down to the dangerous
    level of 10.5v even once, you may have saved the cost of a premature
    12v battery replacement... which costs about as much as the SG, with
    which you also get the on-going benefits of higher FE, and error code
    reading and resets.
    You can get your ScanGauge at the PriusChat Store. :)
