Does Reverse Beep Go Back to Default Setting After Battery Disconnect?
Discussion in 'Gen 3 Prius Main Forum' started by nmrickie, Feb 23, 2013.
  1. nmrickie
    nmrickie Member
    200
    New Mexico
    I had the reverse and seat belt beeps changed by the dealer before I took delivery. Now I want to install some mods which would entail disconnecting the 12-volt battery. With pre-2010 Prii the beeps would go back to the default settings. Will this happen on the 2010+? I don't want to make another trip to the dealer. Thanks!
  2. armoredsaint
    armoredsaint Anti-Eco Company Car
    92
    28
  3. nmrickie
    nmrickie Member
    200
    New Mexico
    Thanks good to know
  4. Netbook
    Netbook Junior Member
    47
    17
    That is not true. I have a 2010 and I ran the car battery down twice, took that battery out once to get checked, and months later a replaced the battery. Reverse beep keep the setting (off) that I did when I bought the car.
    I am shocked when people post incorrect info. If they are not sure they should say I think yes.
  5. nmrickie
    nmrickie Member
    200
    New Mexico
    Even better! Thanks
  6. The Dude
    The Dude Member
    197
    32
    Phoenix
    This is true as it is a software programming concern, not like the radio or clock which immediately resets once power is cut off.
  7. Netbook
    47
    17
    I am not sure what you are trying to point out. The question the OP asked is "Does Reverse Beep Go Back to Default Setting After Battery Disconnect?"
    The answer is no it does not reset to the default setting that is ON. It keeps the last programmed state. In my case it was OFF.
  8. David Beale
    David Beale Senior Member
    5,963
    1,974
    Edmonton Alberta
    The GII did revert to the default state. Looks like they may have changed that in the GIII from the above report.
  9. The Dude
    The Dude Member
    197
    32
    Phoenix
    If you quoted the reply I quoted, it would make sense...:eek:
  10. Netbook
    47
    17
    I have a hard time understanding both your posts. The answer to this thread is 'No, it does not go back to default'
  11. RobH
    RobH Senior Member
    2,369
    976
    70
    Sunnyvale, California
    2004-2009 Yes. 2010+ No.
Loading...
