Does the brake software fix work?
Discussion in 'Gen 3 Prius Technical Discussion' started by Dark_matter_doesn't, Feb 5, 2010.
  1. brad_rules_man
    brad_rules_man Hybrid electric revolutionizer
    716
    76
    Effingham
    Exactly, I want to hear some replies on this one. Does the regeneration seem to be just as strong? What does the efficiency meter say? I can't wait to hear from some of the veterans that really track their mpg's and watch things obsessively. :) If I get confirmation that it's ok then I will get it updated.
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I too have concerns about the effect on regeneration and the control of regeneration with the brake pedal. I have decided to wait a while and see what others discover. Once it's done there is no going back.
  3. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    As far as I'm concerned the regeneration slowing the car down is stronger then it was on the 2007. I can feel a significant difference. Accelerating or decelerating using Cruise Control also has a noticable stronger effect--but I don't think this is regeneration--just something I noticed. Is the acceleration/deceleration rate with the CC adjustable? If you use the CC to speed up or slow down does it figure best fulel economy to your new speed?
  4. bwilson4web
    16,533
    No.
    It is a speed control only. I have not accurately measured the cruise control acceleration rate in the ZVW30 but this is what I found resume speed does in the NHW11:
    There were some questions about pulse and glide in the ZVW30 at speeds above the hybrid mode, 46 mph, and I recorded some data. Unlike my GPS mouse that reports data in 1 second intervals, this data comes from a Garmin nuvi which uses a larger, variable reporting rate. This makes an accurate record of the acceleration rate difficult. My memory was the acceleration rate was constant on each "pulse:"
    The only way I found to change the acceleration rate was to modulate the accelerator to hold a target HSI power setting:
