Does the C have a cabin air filter ?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by sam spade 2, Oct 20, 2018.
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    The wife and I both think that the air flow from the dash vents is much lower than it used to be.....'17 C4.
    Is there a cabin air filter behind the glove box in the C like some other models have ??
    The fan display goes all the way UP and you can hear the fan speed up.......but the air flow just isn't there.
    Still under warranty so the shop will likely get it next week.
  2. zen_
    zen_ Junior Member
    29
    Midwest
    2014 Prius c
    Yes, and you can easily check it yourself in a few minutes. If it's dirty, that's not something the warranty covers (normal wear item like oil, wipers, tires, etc.).
  3. rjdriver
    rjdriver Active Member
    411
    172
    Rhode Island
    Behind the glove box as you suspect, and as Zen said, very easy to replace. Also much cheaper if you buy it at an auto parts store and do it yourself. Surprised the dealer hasn't suggested replacement already, whether you needed it or not :).
  4. PriusCamper
    PriusCamper Senior Member
    13,288
    5,372
    Pacific Northwest, USA
    Cabin air filters are 1/3 the price on Ebay compared to stores... Make sure to get one w/charcoal in it and not cheap white paper ones.
  5. bisco
    52,621
    i can't find anything in the owners manual(n)
  6. PriusCamper
    13,288
    5,372
    That's because you've been hypnotized to think PriusChat is always the only solution...
  7. bisco
    52,621
    ommm....
  8. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    LOL!!!!!! (y) :ROFLMAO:
  9. sam spade 2
    7,035
    2,804
    2017 Prius c
    I'm just a bit over 10K miles.
    And I'm not in a dusty area......but it might be clogged with love bugs. :eek:
    Really I doubt that's the problem but won't know until I check it.
    Thanks for the replies.
    PCSpaceShip likes this.
  10. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    I've never once replaced these things. I just pull them out when the air gets restricted and close it back up. :)
  11. PriusCamper
    13,288
    5,372
    If you want to protect the lungs of yourself and your loved ones you need to replace these every 6 months with charcoal activated filters and keep it on recirculate so as to avoid breathing car exhaust from other vehicles.
    It's important to take the health of your lungs seriously! It's the primary limit to longevity in old age because lung capacity starts to decline in your mid-20's. What's worse is prolonged exposure to air pollution has been found to lower intelligence and induce lethargy.
  12. bisco
    52,621
    i replace it because there's alway tree detritus and etc one it. better there than going through the fan and jamming a vent door
  13. PriusCamper
    13,288
    5,372
    Maybe if you put your old filter in the forest and water it you can re-use to grow more trees? The world needs way more trees!!!
    ztanos likes this.
  14. bisco
    52,621
    i just planted 3!:)
  15. bisco
    52,621
    29238ADA-F5A1-4767-91AE-160187608224.jpeg Tulip tree
    Doesn’t look like much now, but wait until spring!
    ztanos likes this.
  16. ChapmanF
    18,822
    My first Prius was also the first car I owned that had a cabin-intake filter. Everything else just sucked in whatever Mother Nature served up, and blew it into the A/C evaporator, which is usually moist during operation, so it makes a pretty good debris trap.
    Dry leaves were especially good. Would get converted into fine leaf confetti on their way through the blower, then get packed very densely into the A/C evaporator fins with blower pressure behind them.
    Solution I found was to take out the evaporator and soak it for several days in a tub of warm water with a cupful of the bacteria/enzyme gook you can flush down to digest stuff in septic tanks. Then a trip to the U-spray-it car wash to use the pressure wand to spray the digested leaf gook out of the fins. All clean and shiny, no harsh chemical damage to the aluminum, and both the heat and A/C worked waay better afterward.
    It's faster to change a cabin filter though.
    -Chap
  17. PriusCamper
    13,288
    5,372
    you don't need to change the cabin filter that often...
  18. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Man, those tree detritus's grow fast. :D
    Think it'll start growing cabin filters in the spring?
  19. sam spade 2
    7,035
    2,804
    2017 Prius c
    First, recirc still allows in about 20% outside air.
    Second, I've never heard that the cabin air filter does anything to reduce gaseous contamination in the air.
    I think you are stretching a point here.
    dubit likes this.
  20. bisco
    52,621
    i like the charcoal filter, offers some protection from smells
    PriusCamper likes this.
