Does the OBD have any information about the engine oil?
Discussion in 'Gen 2 Prius Technical Discussion' started by donbright, Jul 29, 2020.
  1. donbright
    donbright Active Member
    241
    151
    33
    oklahoma
    Hi there.
    Does anyone know if there is any OBD data that can be read with an app like Torque about the engine oil itself?
    I have tried reading oil temperature and it came out as a constant "1". Perhaps I setup something wrong in Torque?
    I also couldn't really find any other readings - there is no oil pressure sensor or anything like that?
    Thanks.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    When I had a Gen 2, the oil pressure was a switch. It was either good enough or it wasn't.
    Gen 3 or Gen 4 could have changed that, but I doubt it.
  3. fuzzy1
    10,720
    ... or the sensor and feature aren't implemented in the Prius, so the ECU just returns a fixed default value?
