Does the rear hatch (not the power version) swing up on opening?
Discussion in 'Gen 5 Prius Technical Discussion' started by Nntw, Nov 10, 2023.
  1. Nntw
    Nntw Active Member
    398
    248
    Toronto
    2023 Prius Prime
    So the rear hatch on my XSE stays at whatever angle I pull it open to.
    It doesn't swing all the way up, like I'm used to.
    Is this a 'feature' or something wrong with my car's gas struts?
    In some ways I don't mind- means it doesn't hit the garage door if I open it and forget to hold on.
    Thanks!
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,352
    981
    Monument, Colorado USA
    I've found those OEM struts aren't the best things....I've replaced all four in our 2017 and 2021 with aftermarket ones. If you have the Prius with the wipers, you just have to make sure the new struts are made for that...just needs extra power to lift up the extra weight.
    Toyota wants $33 for one lift-gate support (gas strut) but I tried the "Tuff Support" struts sold on Amazon, $33 for two, and they are fine.
  3. Mendel Leisk
    42,351
    When brand new our gen 3 hatch went all the way up, once partially lifted. Worked thus the first few years. 13 years on I have to help it.
    52,860
    i have to think that at some point in the lifting process it starts to go up on its own. they always have in the past
  5. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    I like the OEM struts. When closing, after pushing it down a certain distance, gravity takes over and finishes the job. No chance of slamming it down and damaging any part of it. With stronger struts, you're gonna have to use more force to close I would think.
  6. Mendel Leisk
    42,351
    Only thing is they start out ok, but given a few years start to crap out.
  7. bisco
    52,860
    after 11 years, mine still worked fine in decent weather, but when cold, would stop half way up.
    banged my head more than a few times, probably explains some things...
    Alessandro_Ibi and ColoradoBoo like this.
  8. Argyros
    Argyros Active Member
    275
    142
    2023 Prius
    My 2023 doesn't lift on it's own; I have to help it....it actually helps when I'm detailing and don't have to hold the hath from lifting too far. I don't mind lifting it... its a huge glass area which is very heavy.
    Nntw likes this.
  9. Nntw
    Nntw Active Member
    398
    248
    Toronto
    2023 Prius Prime
    thank you!
  10. priusdriver223
    84
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, the hatch lifted all the way up without much help in the beginning of my ownership but 3 months later, it suddenly stopped doing that. Now I have to manually help it and it's quite alot of work compared to what I was used to when I just got the car. Hope this cleared some confusion, cheers!
  11. CooCooCaChoo
    962
    544
    Cow-lee-fornia
    2023 Prius
    I think its because its cold. Come spring, should be fine again. I noticed mine needing assistance to open the hatch up.
    Sedril likes this.
