Does the USB or AUX port charge phones on a Prius 2016
Discussion in 'Gen 4 Prius Audio and Electronics' started by Azmi, Sep 29, 2020.
  1. Azmi
    Azmi New Member
    Jordan
    does USB &AUX port charge the phone .
  2. Tideland Prius
    16,074
    USB - yes
    AUX - no
  3. alanclarkeau
    alanclarkeau Senior Member
    7,041
    7,580
    near Brisbane, Australia
    But - like almost all cars (some real recent ones are better), the output of USB means it's VERY slow charging. And if you're in a low-signal area, or the phone is busy doing other things, it might well go backward. From memory, car USBs are only about ½ an amp.
    If you need to charge, get a phone charger and plug it into 12 volt.
  4. StarmanUK
    StarmanUK Junior Member
    Essex, UK
    Business Ed. Plus
    A standard USB port is rated at 500mA but I believe the ones in a 2016+ Prius are rated at 2.1A but that is shared across the 2 ports so may lead to slower charging depending on what is plugged in.
  5. alanclarkeau
    7,041
    7,580
    Maybe it's a regional thing - I'm fairly sure mine is only 500ma. I rarely plug my phone in - but when I did early on, I also had Bluetooth running - after ½ hour, the charge on the phone had barely changed (was still nearly empty).
    I did see a car with 2.1a - but from memory, it was marked "2.1" on the cover.
    StarmanUK likes this.
  6. StarmanUK
    Essex, UK
    Business Ed. Plus
    I'll confirm in the Prius later but I know my '19 RAV4 says 2.1A.
  7. Tideland Prius
    16,074
    Those are the separate USB charging ports (the 2.1A ones). The USB port that is connected to the audio system is much lower, perhaps the 0.5A one you speak of).
    alanclarkeau likes this.
  8. alanclarkeau
    7,041
    7,580
    This is KIA Sorento 2021 - only that lower one (front) is connected to the AUDIO - though KIA don't mention amperage, they're only for charging:
  9. Tideland Prius
    16,074
    Looks like one of the three "1st row chargers" is the USB input. That's a typical setup.
    Again, the USB Audio input does charge but usually at a lower amperage than the dedicated charging ports.
