Does this look like a leak in my engine area?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by going red baby!, Feb 9, 2017.
  1. going red baby!
    going red baby! still a n00b
    610
    96
    Los Angeles
    So I was checking fuses and charging my dead battery and noticed that the black thing on top near the front of the car looked soiled. I can't tell if it's oil or if it's maybe just wet? A year and a half ago I took pics of that area because of another issue and it didn't look like it was soiled.
    Here are pics from today:
    And here is one from July 2016:
    Any thoughts?
  2. Mendel Leisk
    42,202
    Pop off the 3 fasteners with a small flat-blade screwdriver and see what it looks like underside; good opportunity to wipe it clean too. I don't think you're going to discover much though: I had a look at ours, and nothing obvious underneath that could be doing that.
    Are you getting service at dealership or some other pro's. Just guessing someone's overzealous lubing the hood release hinge, or spraying some sort of armor all product? Strangely uniform though.
    IIRC you're street parking? How many miles? Any engine underpanel missing? Can't believe how ravaged that engine bay looks. I snapped a pic when I checked ours just now. Very clean in comparison. Low miles and garage stored though.
    going red baby! likes this.
  3. going red baby!
    610
    96
    Los Angeles
    Street parking and it's been raining a lot lately if that makes any difference. And I'm in a big city. Less than 50,000 miles on it. Only had it serviced at dealer except for the very first oil change.
    I thought it seemed kind of dirty too, then I saw it was dirty in the older pic as well. I took that one when I had inverter issues.
  4. Mendel Leisk
    42,202
    I think repeated overnight condensation, coupled with dust raised by passing traffic.
  5. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    You could always Go for the good old inverter cover, like mine:
  6. Kenny94945
    Kenny94945 Active Member
    861
    437
    Sausalito
    2016 Prius v wagon
    FWIW I don't think it is a leak...from any engine compartment component.
    Note the front seal...also looks discolored.
    I also agree that it may be a chemical reaction from a lubricant or detail spray or a soap.
    Removing that front plastic panel and looking for moisture under the panel could aid in finding the cause is also a good and easy idea.
    Perhaps it is road salt residue, and if so, then I would look to the hood seal and hood alignment.
    Perhaps the lower plastic inspection panel is removed and the "salts are coming from the bottom of the car by air flow turbulence.
    Anyway, good luck finding the cause.
  7. going red baby!
    610
    96
    Los Angeles
    Thanks everyone! Couldn't get all the clips out to check completely, but was able to look underneath a bit and it's very sooty, but not greasy.
  8. maurices
    maurices Member
    128
    37
    Sartell, Minnesota
    The Prius engine can be washed at a self serve car wash. I wash mine probably once a month, engine compartment still looks like new. You'll have to overlook the Cusco FTB, the intake modification and the wiring harness cover, though..(y)
  9. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    I get a lot of dust under there, which is the main reason I wash under the hood when I wash the car, but only when I wash it in the backyard. Never use a pressure washer underhood! If you're not careful water can be forced into electrical connectors. I'm talking about the "sealed" ones. They are no match for pressure washers! You could use a pressure washer from 2-3 feet safely though.
    A coolant leak will be festive! Purple/pink danglers everywhere. Had that with Pearl. Usually an oil leak won't spray everywhere, just seep down from the leak spot. A few on this forum have seen that with the "front" of the engine (timing chain cover). I'd say someone doing service spilled a bit, trying to be fast, probably. ;) They wouldn't take the time to clean it up properly. Just a quick wipe will give you what you see.
  10. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    I bought my car new and have had it since August of 2015. I lightly spray wash the entire engine using the "spot free rinse" mode every two months. Keeps it looking new. I plan on keeping the bottom cover and replacing it should it ever become damage or I lose it.
  11. going red baby!
    610
    96
    Los Angeles
    I don't know what you are talking about. ;) Do I need to cover anything up or just make sure I don't get it too wet or wet at all? I'd love to give it a clean after I get the body work done. Get it back to almost new since I plan on keeping it until it dies completely.
    So a spray nozzle on a garden hose is fine, right?
    Is that a mode at the self serve car wash?
    Do you guys use anything on it to clean? Like something you spray on then rinse off?
    Maybe I can have the body shop do it. I think they detail the car as part of the repairs.
    Speaking of water... when I looked at my 12v battery today to decide if I should have the dealer swap it or just do it myself, there was a pool of water under it in that corner. The car was rear ended so somehow water got in there. I used an old kitchen towel and it soaked up full about 4 times. I'm kind of worried about that. Going to push my insurance company to deal with my repairs faster but in the meantime I guess I need to line the inside corner with plastic to keep any water off the battery... Is this extremely dangerous? It's been raining a lot here (a lot for L.A.) and I hadn't looked in there so that could be an accumulation from several rainy days. I'll keep an eye on it until I get the body work done.
    #11 going red baby!, Feb 9, 2017
  12. Mendel Leisk
    42,202
    That too bad, the leak around 12 volt. Hatch not sealing?
  13. Rebound
    3,996
    2,645
    Portland, OR
    It's very easy to get amazing results:
    1) Buy engine degreaser at your local auto parts store. I like the stuff that comes in the purple spray bottle.
    2) Good if your engine is warm, but NOT hot. Don't spray liquids on a hot engine.
    3) Pop the hood and spray that degreaser all over the engine, all the plastic stuff, way down low... spray really generously, soak the thing. Avoid the paint, although I don't think it eats paint.
    4) Wait 10-15 minutes
    5) Soak it off with a garden hose.
    6) If you want it really shiny, spray Armor All on all the hoses and plastic surfaces.
    You'll be TOTALLY amazed at the result. Seriously, it will blow you away.
  14. Mendel Leisk
    42,202
    What's weird: I've done next to squat with ours. Use a leaf blower or wet-dry vacuum on blow sometimes, dust it off a bit with a paint brush, and push a duster wand through all the gaps. But this is maybe 3 times in 6 years.
    I think a big part of it is garage storage, it's never covered in dew in the mornings, well rarely, just on road trip vacations. And only 65K kilometers on the odometer. Also, I pushed these tube insulation pieces over the seams along top of fender. Maybe keeps the dust down:
    #14 Mendel Leisk, Feb 9, 2017
  15. David Beale
    5,963
    1,989
    Edmonton Alberta
    Or you live in place there the rain washes the dust away from the roads all the time. ;)
    Keep in mind if you drive in heavy rain it gets spayed all over the engine compartment (eventually). It's "water resistant". So as long as you don't use a pressure washer you can wash everything under there provided you don't remove any covers. i.e. the air filter is left assembled, the fuse box cover is on etc. I use a garden hose and nossle on hard spray with no issues.
    The engine mounts on Pearl had no paint on parts of them and they rusted before I noticed. A little "rust converter" solved that issue. It's a "paint" that converts rust into a more permanent anti-corrosion coating. Found at Home Depot, for example.
    Oh, and I've got to get around to installing Mendel's side seals someday. Maybe this spring. Pearl S sleeps in the garage and also has low mileage but gets dusty anyway. Kind of like "Pigpen". ;)
    going red baby! and Mendel Leisk like this.
  16. Mendel Leisk
    42,202
    How many miles? We are pretty low 65K km's.
    I use those side seals mostly to help hold the heat in, in winter. I was leaving them in year 'round, but last summer thought better of it, took them out in late spring.
  17. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Not "dangerous," but you really should get that leak looked at. I'm guessing whoever did your body work didn't get something sealed or aligned right. That water will lead to rust in the battery area. Not good, long term, even in L.A.
  18. going red baby!
    610
    96
    Los Angeles
    The bumper is askew from being rear ended. Maybe the light assembly area is off?
    Haven't had the body work done yet. Will do so in the next couple weeks.
    Mendel Leisk and jerrymildred like this.
  19. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    All I'm going to say, is I'm NOT a big recommender of using a Pressure Washer to spray clean your engine.
    Why?
    Well when I was younger, I actually damaged a vehicle of mine doing it. Unknowingly knocked loose wires.
    When I was older? I lived for a while down the street from a coin operated pressure wash place and I lost count of how many times I'd drive by, and see someone with the hood up and pressure washing their vehicle's engine, then later I'd pass by to see them frantically trying to get the vehicle started and/or a tow truck present.
    With all the electronics and components in a vehicle today? Just doesn't seem worth it.
    I actually think routine careful maintenance is the best.
    I can pretty much keep my engine compartment looking clean if I just occasionally open the hood and carefully wipe things off by hand.
    So my only advice is IF you do decide to use a pressure washer to clean your engine.
    Be very, very careful.
    Yes it works...but maybe try "Low Pressure" and a conservative approach.
    Mendel Leisk and Raytheeagle like this.
