Does "throttle body cleaning" help milage?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cosgrove, Aug 12, 2012.
  1. Toppcat
    Toppcat Member
    223
    69
    Northern California
    If your burning oil ! Yes ! If your not! Change oil offen use good quality top tier gas! No issue with performance of engine then NO!
    Tbkilb01 likes this.
  2. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    Possible "rough engine transition"? Meaning? As its accelerated from stop? Or as battery voltage is burned off from 6 to 2 bars? I feel the drop! I can tell when it happens.
    No drop in MPG.s
    But then again, really want to give the prius a really good work over. I think its deserving!
    #22 Tbkilb01, Sep 11, 2016
    Raytheeagle likes this.
  3. Tbkilb01
    218
    187
    Louisiana
    Thanks!!
    Not burning oil...
    Always mobile1...
    Always exxon...
    But at 150 miles a day, using tank a week
    What about the Techron additive?
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    On my 2010 Prius II, I noticed it on startup and at lower speeds (say under 25). The rough transition would cause the car to rock more than I would say was normal. I did the egr system, intake. Seemed to help. Recently, I have added 2 different BG Products to the Prius: 44K to the gas and EPR prior to the last oil change.
    I have a round trip of 80 miles a day going 70-75 mph averaging 44-46 mpg. Have a slow oil drink of a quart every 6500 miles. Since doing the BG Products additives, I have seen an increase in mpg(actually got 49 mpg on the last tank) in the same driving conditions. Too soon to tell on the oil consumption, but I continue to monitor;).
  5. Mendel Leisk
    42,343
    Try first taking off the EGR connection pipe, check it's degree of clogging, it's the "canary in the coal mine".
    An end-to-end cleaning of the EGR as Ray has done is a really involved undertaking: the EGR connection pipe connects to the EGR valve proper, which connects to the "cooler", which is the final link, bolting to the exhaust manifold. That last component is the toughest to access and remove, has coolant lines connected, and can be near-hopeless to clean, easier to just replace.
    Then there's the intake manifold...
  6. Tbkilb01
    218
    187
    Louisiana
    Well I guess that rules out the EGR service, at least for now...maybe after I grab that second prius so 2010 can have some down time.
  7. Toppcat
    Toppcat Member
    223
    69
    Northern California
    Techron is good stuff proven to work! Look like you will easily get 250,000 plus miles from your Prius!
    Have the spark plugs pulled and inspected! This will. Clearly show which cylinder is using oil then a compression test wet\dry and then a valve leak down test this will give you data on the condition of your engine.
  8. Toppcat
    Toppcat Member
    223
    69
    Northern California
    Don't Scare the poor guy! Just tell him it's difficult!
    Tbkilb01 and Mendel Leisk like this.
  9. Scottyboy24
    Scottyboy24 Junior Member
    33
    Pensacola, Fl.
    Knock on some wood!!!!!!---- but I just hit 106k on my 2011 and all i have done is change the oil every 10k miles and add a bottle of Lucas fuel treatment every other month or so! This has been one good car! Just got her paid off toooooooo! And still runs like the day I bought her with 11 miles on her! wooooo-hooooooo! Toyota is the bomb.com, IMO!
  10. qdllc
    qdllc Senior Member
    1,377
    400
    Run a can/bottle of B-12 Chemtool or Seafoam in your tank every now and then. It cleans the entire fuel system, is perfectly safe, and it will clean ANYTHING involving the fuel system (if it gets sprayed there). Some have cleaned EGR systems by flushing or soaking the EGR valve in the chemical.
