Does Toyota recommend "Engine block heater" on Prius ??
Discussion in 'Gen 4 Prius Main Forum' started by reddogpatch, Jan 23, 2018.
  1. Mendel Leisk
    42,355
    Just got this back from local dealership:
    As it stands most block heaters are currently not available for any new Toyota. Due to complications with quality from the manufacturer that makes the block heaters for Toyota. Toyota is working hard to rectify this situation but it will take time. Hopefully by the end of the summer or if not sooner we will have block heaters available for purchase. Thank you for the inquiry and once again, any further questions you may have feel free to contact me. Have a great day Mendel!
  2. Timi
    Timi New Member
    Technology
    Hi Leo, the cable that you see under the hood is probably the heater for the battery coolant and not a block heater
  3. Prodigyplace
    12,716
    11,848
    Central Virginia
    What car are you talking about? Certainly not any Prius that I am aware of.
    The 12 volt battery under the hood is just a plain lead acid battery with no coolant. The traction battery pack is air cooled with no coolant.
    #23 Prodigyplace, Aug 12, 2018
    alanclarkeau likes this.
  4. Tideland Prius
    16,681
    This new thing for Gen 4 cars with Li-Ion batteries so that, I'm guessing, it can be sold nationwide. (Recall that the 2016 and I think part of 2017 Prii with Li-Ion batteries were only sold in Toronto, Montreal and Vancouver metro areas)
  5. Prodigyplace
    12,716
    11,848
    Central Virginia
    OK, so that is a Canadian thing and a Canadian thought they may have a block heater.
    Fair though. Those of us in the US get easily confused ;).
    RCO and Tideland Prius like this.
  6. Tideland Prius
    16,681
    I probably would've too if it wasn't for a new member that made us aware that Toyota Canada added this new battery heater (there was no announcement or press release)
    RCO, Prodigyplace and alanclarkeau like this.
  7. Mendel Leisk
    42,355
    This thread?
    New Prius (2017) enhanced with a hybrid battery heater? | PriusChat
    The "more information on page 84" of the Owner's Manual is pretty terse:
    #27 Mendel Leisk, Aug 13, 2018
    RCO and alanclarkeau like this.
  8. Tideland Prius
    16,681
    alanclarkeau and Mendel Leisk like this.
  9. Michael Shafer
    Michael Shafer New Member
    Table Rock Lake, Branson, Missouri
    Having a wife from MN and in-laws in North Dakota, an EBH is pretty common. The issue of concern I'd have if I lived there with a Prius is battery degradation. Unless someone could show me data to the contrary, as an Electrical Engineer, and someone whose read quite a few white papers on the lengths Tesla has gone to maintain optimal battery temperatures, the extreme cold temperatures will likely impact the life and effectiveness of your battery far more than the start up viscosity of your zero weight oil. A Tesla will actually heat its batteries, taking tons of energy, when its cold outside, and cool when hot. I'd love to see a table of data of the MPG and car longevity of Prius owners from Northern states and High heat states vs more temperate climate states. Batteries ideal temp is roughly 75 F
  10. bisco
    52,863
    anecdotally, we have seen many more failures in the south than in the north.
  11. Mendel Leisk
    42,355
    Nissan Leaf battery deterioration was happening more in Southern States? The displayed state-of-charge was "absolute", and as the batteries peak charge started dropping, the display would no longer light the the top "pip" after the battery was charged.
  12. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Focus should be on stress, not ideal.
    For cold, that begins at temps below freezing. It's only mild compared to getting cooked in heat through and the battery-warning system takes care of that but is only beneficial for high draw.
  13. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    An engine block heater is typically recommended at 5°F (-15°C).
  14. Mendel Leisk
    42,355
    I can't recall it ever getting that cold here. FWIW, we use ours year 'round, winter and summer. Where's this typical recommendation, a manufacturer, or?
  15. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    #35 BruceInOKC, Sep 24, 2018
  16. Timi
    Timi New Member
    Technology
    Can someone tell me what is the wattage for the block heater and for the battery coolant heater? Just had the block heater installed at the dealer and they had it installed on the same plug with the heater for the battery coolant. I would like to know the Amps that these combine will draw
  17. Mendel Leisk
    42,355
    The engine coolant block heater is 400 watts I think. That's the case for 3rd gen, anyways.
    I'm confused by "battery coolant heater": there's two coolant circuits under the hood, one for engine and one for inverter. Is the Prime hybrid battery also liquid cooled??
    padroo likes this.
  18. padroo
    padroo Senior Member
    2,763
    2,253
    I tried to get a EBH for my Gen 2 but had to order it from Canada. I never installed it and gave it away. The heater in my Gen 2 wasn't one of its strong points. Lol
  19. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    Colder temperatures degrade currently available capacity of the high voltage battery. But they they also improve the overall life span of the battery.
    The main killer of Prius's high voltage batteries is heat.
    Preheating batteries during winter allows them to accept higher charging currents (quicker charging) and increases the current capacity of the battery. That's why all better electric cars have thermal management of their batteries which includes heating during winter. But beware, heat also reduces the lifespan measured in years.
    As the Prius is a hybrid, there is less pressure to precondition the battery with heating during winter, as the energy cost of doing so would be greater then the benefits of the battery getting maybe 100 Wh more available capacity.
    The main priority of Prius's battery heat management is to prevent overheating.
  20. Prodigyplace
    12,716
    11,848
    Central Virginia
    @Timi lists a Gen 4, not a Prime.
    For a Gen 4, a "battery coolant heater" would be a cabin heater, possibly located close to the battery. :D
    The Prime is air cooled. I know i offers to run the heat pump to keep the battery cool while charging. It may offer to run the heat pump for heat while charging if it is too cold.
