Does tpms tire sensor need to be activated by a tool?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jeffrimerman, Feb 4, 2023.
  1. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    I returned a new tpms sensor since it showed "n/a" after it was input into the ecu with the techstream software. I re-input all 4 sensors over and over in different orders and it always showed as "n/a". The seller said "
    sensors need to be activated by the OBD tool". Is there another step that is needed? I've programed them in my IS250 but they were used so were they already activated? I've never seen a different step in all the videos. Thanks in advance.
  2. PriusCamper
    PriusCamper Senior Member
    13,250
    5,357
    Pacific Northwest, USA
    There's the usual button under the steering wheel on Gen2 to do this but don't know about Gen 3. But in general if you have the right TPMS sensors they're compatible with Gen2 and Gen3 and probably most other Toyotas of similar age.
    For example I bought a set of worn out tires on some Gen3 wheels that had been sitting for years for my Gen2 project car and they sat for a year at my place as well and then I had new tires put on them a month ago and put them on my Gen2 and went on a road trip with no tire pressure warning light at first. After about an hour into the trip the light came on, but after road trip was over warning light went away after car not driving much.
    Then soon as I drove lots of freeway miles in a single day it came back, then went away after that. I assume that's failing battery electrolyte that's impacted by too much centrifugal force, but perhaps the worst problems to deal with on a car are the ones just intermittent enough to get you to procrastinate.
    And yes I do have techstream and plan to diagnose which wheel when it comes back and get some huge tire irons and follow the Youtube videos on replacing it myself, which I'll post about... But more to the point, you don't have to program anything and TPMS is standardized across most Toyota vehicles of similar age, but once they get old, you'll have problems.
    #2 PriusCamper, Feb 4, 2023
  3. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Thank you, that's what I was thinking. Yes mine was coming on and off before it permanently stayed on from a failing battery. I do have that button under the steering wheel also but wasn't sure if I was doing something wrong when I pressed it. Nothing changed when I pressed or helded it for a few seconds. I didn't see the light blink or anything. Maybe since I'm already having a warning light then it won't do it's mumbo jumbo?
    PriusCamper likes this.
  4. PriusCamper
    13,250
    5,357
    It's one of those things you can DIY fix by buying one for $10 online if you have the tools to do it. Or go to place that did your tires for you and have them charge you $50 or more... What I learned from this thanks to PriusChat a month ago is TPMS have their batteries embedded inside the plastic & you can't simply replace the battery, but have to buy a new TPMS.
  5. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    I'll use the scissor jack under car method to change it myself. I saw a video someone showed how to change the battery but seemed too messy to save $10 for a sensor and a bunch of work. I'm just wondering if I used my regular 12v tire pump will it be too slow to get the tire to bead again. Maybe I'll need to goto the gas station.
  6. PriusCamper
    13,250
    5,357
    I like to use a hand pump for the exercise when adding air to car tires... Also, do you have a link to the you tube video you watched? I haven't got around to researching it...
  7. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    I saw a couple but here is one of them. He also mentions the battery inside and talks about changing that. If one doesn't have the software or wire and no computer skills it might be a good option for someone.
  8. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Did the one in question come with the ID? On a piece of paper maybe? (I have been buying Dorman units that are pre-programmed with and ID but they did not include the ID).
    I would say you got 3 good ones, and now 2 bad ones, (the seller replaced a defective one with another defective one), since you got 3 to work so should the fourth….
  9. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Near a Walmart? They have pretty reasonable tire service pricing. I believe it takes 40 PSI for the bead to seat, usually beyond a 12V tire pump’s capability (while air is seeping past the bead)…
  10. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Yes it had the ID on it so that's what I input. The 3 working ones were the original ones. Just one went bad so far so I bought just one. I got a refund so all good. I ordered another from a different seller just to be safe. It should have the ID printed on the outside. If it doesn't work then I'll just buy a used one that came out of a working car. That's what I did before for my Lexus. They all worked perfect. I see them on craiglist so worst case I can drive there and input into my car and see right then if it works.
    I'm sure you're right but I can goto the gas station tire pump if I get some gas. Those pump really fast.
    jzchen likes this.
  11. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Some sensors are universal and may come blank, without an ID. (I have not gotten my hands on one yet)…
    I hope you get a new one programmed in soon…
  12. Tombukt2
    Tombukt2 Senior Member
    13,674
    2,478
    Durham NC
    Pacific is the brand on you're car new . E bay and Amazon have this brand . They also make the center caps and trims for most of the wheels that Toyota sells look on the back of the center caps of your Prius and it will say the word Pacific show the word specific. The logo has green and red in it but if you look for the Pacific logo in eBay or Amazon you will be shown that logo that company is the same company that made the original sensors in your Prius when it was shipped from the factory.
    jzchen likes this.
  13. mr_guy_mann
    mr_guy_mann Senior Member
    4,107
    2,008
    NJ-USA
    It's really helpful to have a tool that can "ping" a TPMS sensor to confirm that it works. You enter the year make & model so the tool can send the correct "wake up" signal and read the response.
    The sensor you received might be the wrong one, defective, or might might be not programmed correctly. (Universal sensors need "to be told" what frequency, ID#, and message type they should use.)
    The fancier ($$) tools can program their own sensors (example- autel tools can program the autel MX sensor). The high end ones have a OBD2 cable to automatically enter the ID's into the car's ecu.
  14. ChapmanF
    18,771
    The button under the steering wheel doesn't have anything to do with waking up the transmitters in the tires. What the button does is tell the ECU inside the car that whatever pressures are in the tires right now are the pressures you want, and it sets its warning thresholds to be so many % below those. So the only time you would have a reason to press that button would be when you have changed your mind about what tire pressures you like. (Or when you have rotated the tires, if you keep different pressures front to back, because it will remember the pressures you liked before according to the transmitter IDs, not according to where they are on the car.)
    There are various ways of waking up a transmitter so it will transmit its signal. To maximize battery life, they generally stop transmitting if they aren't moving and the pressure isn't changing quickly, or if the pressure is just atmospheric (like when the transmitter hasn't been installed yet). One should start transmitting if there's been a sharp change in the pressure, or if the tire rolls down the road a ways.
    Or, as mr_guy_mann mentioned, there are some tools that can send the sensor a signal that wakes it up.
  15. qdllc
    qdllc Senior Member
    1,377
    400
    Do you mean “a piece of equipment designed to perform a specific task” or “an donkey?”
    There’s no shortage of people who are tools. :rolleyes:
  16. Tombukt2
    13,674
    2,478
    Durham NC
    In hand no signal . In tire with pressure it's signal transmitting ready . Movement or pressure changes wakes transmitter.
  17. Tombukt2
    13,674
    2,478
    Durham NC
    Anything else you own in said frequency. Will wake the transmitter too. A ham type radio tuned correctly etc.
  18. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Oh ok, maybe that's why the other ones worked fine in hand since they were used they were "woke" already. I wonder how much movement or pressure. Since they go in tires maybe it's a ton of centrifugal force and/or at least 20 lbs of pressure. I didn't want to have to install just to check but maybe I'll have to. Maybe I can use the spare to do it if that stem can come out.
    Tombukt2 likes this.
  19. Tombukt2
    13,674
    2,478
    Durham NC
    Get an old pressure cooker The kind with the locking top drill four holes in the top of it and mount the TPMS sensors to the lid Lock the lid down the two pieces together and then squirt 30 lb of air into one of the valve stems pumping up the old pressure cooker. I imagine you could do this and carry the pod out to the car and boot the car up with the pot sitting on the front floorboard see if it detects the sensors or something like that. That just sounds like it'd be easy because to find an old pressure cooker It wouldn't be an issue and then you could just have that around test TPMS sensors I guess kind of funny but it might work then again most people just pay the $39 with the four with new batteries
  20. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    This is a new one so battery must be good. I bet the one I returned was good also but nobody mentioned they needed to be under pressure or detect mostion to activate. Still not sure which is needed or is both needed motion and pressure. In the "100" videos and articles I read it was never mentioned until I googled "activate" then saw one youtube video. Are you saying most people buy new ones but then those would not be activated so they would have to pressurize them and do the thing you said or are you saying most people buy used ones so they just pay $39 then they are already working? I happen to buy used ones for $40 and as you said they just worked as soon as I used techstream. It never occurred to me that tpms sensors would not work until you install them.
    This is the video that seems to explain what needs to be done. So basically if you buy the 4 for $39 then you need to do as you said and use a pressure cooker to activate them outside of installing otherwise one needs to install them and then fill them with pressure and then let some pressure out. They probably designed them that way so that static pressure doesn't activate them but I'm just guessing.
    #20 Jeffrimerman, Feb 6, 2023
