Does windshield have UV protection?
Discussion in 'Gen 5 Prius Main Forum' started by daisy555, Nov 1, 2024.
  1. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    Those of you who already own a Gen 5 Prius…
    Does the windshield state it is UV protected? I have someone telling me the windshields do not have UV protection. His side windows are labeled as UV protected but not the windshield which doesn’t make sense. Thanks!
  2. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    Sense or $$$$ would be my first guess. Know anything about eye glasses with that special UV protective coating? In my experience that coating make lens last about 1/3 as long as lens without the coating and when they become hard to see out of they look like lens that have been through a sandblaster. Just guessin.
    Everyone that needs glasses no matter what age, needs excellent eye care insurance or else $$$$ !
  3. daisy555
    1,729
    716
    CT
    Yes, I know about the protective coating on glasses. Mine aren’t scratched but it’s rippling on the edges which was very disappointing.
    When I did some google searching I read that the UV protection on windshields is not on the surface of the glass.
  4. vvillovv
    4,336
    1,518
    NY
    OK where is the windshields UV protection? And where did you read about it? I'd like to learn more about it too. ;)
  5. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I wear "photo gray" glasses that darken when exposed to UV energy. They do not darken when I drive my Prius as UV doesn't get through the windshield.
    JeffD
    mountaineer and daisy555 like this.
  6. Hammersmith
    Hammersmith Senior Member
    2,439
    2,502
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Windshield blocks 99% of UV, and front side windows block 90% or 99% depending on trim level. LE/SE/XLE/XSE block 90%(because they're single layer tempered glass with a UV coating) and LTD/XSE+ block 99%(because they're laminated glass like the windshield with a UV-blocking plastic layer).
    daisy555 likes this.
  7. Trollbait
    12,799
    Glass itself is a good UV blocker. IIRC, it blocks most of the A and some of the B before the addition of additional UV filters.
  8. Hammersmith
    2,439
    2,502
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Windshield gets 99% protection from the treated plastic layer in the middle of the laminated sandwich. The front side windows get 90% protection from a coating on the inner surface, plus some UV absorbing materials in the glass itself.
    Here's a Toyota press release from 15 years ago when they introduced the new side windows:
    New Toyota Glass Technology Cuts UV By 99% - Toyota Media Site
    daisy555 and Gorgonzola like this.
  9. daisy555
    1,729
    716
    CT
    Multiple websites stated there is UV protection laminated between the glass layers.
  10. daisy555
    1,729
    716
    CT
    Wonder why they don’t label the windshield as UV protected. Maybe because it’s not UV coated like the side windows?
  11. Trollbait
    12,799
    Or it is simply marketing to hype the 10% more filtering over the old side window glass.
  12. bisco
    52,751
    i wonder why the sides are only 90%. cost or technical issue?
  13. Hammersmith
    2,439
    2,502
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Both. The ability to go to 99% comes from the lamination layer. The 90% on the sides is just an applied coating to the glass. In order to get to 99% on the sides, they'd have to go with laminated glass instead of tempered(which they do on the LTD and XSE+). They can't go laminated all the way around because that can be a safety hazard if the car goes underwater or if emergency responders need to get the occupants out quickly.
    Prius Maximus and bisco like this.
  14. vvillovv
    4,336
    1,518
    NY
    Thanks for the link @Hammersmith . For me, sometimes, the older the release the better I like it ;)
    @daisy555 , sorry to be a pest by not being a Gen 5 owner and posting anyways. It now makes more sense to me that someone might have mentioned that the front side glass is marked as UV glass and the windscreen is not.
    I've been following the NA EUVL tech and it's more than a little hard to follow, especially the UV part of it. Though that has nothing to do with what you asked about either.:notworthy:
  15. bisco
    52,751
    if you googles sun screen in the car, they recommend it. but the studies seem to be older, and idk what th uv glass protection was at the time. they don't get into it in any articles i found.
  16. AndersOne
    AndersOne Active Member
    345
    200
    Europe
    2023 Prius Prime
    Perhaps because its kinda standard*? Side windows slightly less
    Having people (still) getting skin cancer from driving a lot is really not good for marketing though
    * Apparently there are much stricter UV regulations for cars in the EU (and Japan even more) but not in the states.
  17. daisy555
    1,729
    716
    CT
    Absolutely not a GEN 5 owner yet and posting as much as I want to. If you don’t understand what I’m saying, either ask for clarification or let others answer the question. I don’t know the auto regulations but a coating might require labeling and a built in layer might not.
  18. priusdriver223
    84
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, I tinted all my windows the first day I got it, simple fix and makes the car look better. If you don’t like the dark tints, there are clear tints too! Cheers!
