Does your battery charge to maximum level?
Discussion in 'Gen 3 Prius Fuel Economy' started by carlosfpr, Apr 16, 2013.
  1. carlosfpr
    carlosfpr Junior Member
    I have my Prius for about a month now and I noticed that my battery does not fully charge:
    Is this normal?
    Thank you!
  2. cmezriczky
    cmezriczky Junior Member
    34
    Austria
    This is normal. Loading to full level will decrease the traction batteries durability and will therefore not be done by your Prius. Full level charge happens only if you are regenerating too much...
  3. cmezriczky
    34
    Austria
    Standard Load is between the lower two bars and should go up to below the uppermost two bars. Everything more or less will add to the traction batteries memory effect.
  4. fuzzy1
    10,682
    For flatlanders, this is normal. Most of us see the battery fill up only with a significant amount of regenerative braking while descending hills. Once we reach flat land, the car burns off the top two bars fairly quickly.
    This pattern keeps some room available to harvest the 'free' energy of downhill slopes, which would otherwise be thrown away as heat in the friction brakes. And this improves battery longevity. Battery life is longest when the average state of charge (SOC) is somewhere in the middle, neither full nor empty.
    Merkey and JimboPalmer like this.
  5. walter Lee
    1,126
    376
    Maryland
    The highest SOC that I've achieved while monitoring the HV battery with the SGII is about 78% - after
    stopping or slowing down from a very steep downhill grade...
  6. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    What you are seeing (6 bars) is normal. The car will try to maintain 6 bars throughout operations.
  7. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    To add a little more details and information.
    The State of Charge displayed on the dash is actually close to between 40% and 60% State of Charge. Toyota established many years ago that allowing a battery to fully charge and fully discharge shortens the lifespan of the battery. So they keep it in the mid-range sweet spot.
    Some manufacturers widen the range to 30-70 or even 20-80. I think someone actually allows a full-range charge/depletion cycle. Those in the know are closely watching to monitor their long-term durability.
    Like everyone said, you will rarely see a full SoC display and when you do, it's neither good nor bad. It just is.
    On the other side of that coin, I hope for your sake that you never see a completely empty SoC display. That's a whole other discussion.
    Merkey likes this.
  8. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    nope.. never to full.. but I haven tried to use as much as possible.. only got down to half.
  9. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    Very rarely that happened to me with the 2010 and maybe once with 2012 in the last 6 month.
  10. Ardentity
    Ardentity Junior Member
    CA
    Saw it happen for the first time yesterday in my 2013 Prius Three (charge to max level). But it quickly dropped by 1 bar again. :)
  11. bjdrums
    bjdrums Junior Member
    Temecula, California
    I've only had my Prius for 3 weeks and saw the battery attain a "full" charge twice now (not for very long though maybe 5 minutes or so). Should I be concerned?
  12. Sfcyclist
    1,621
    376
    SF, CA
    Take that back... just had to go to complete full yesterday for short time. At the same time, I have noticed it cycles much deeper though. I guess that is a good thing, use more battery = less gas.
  13. Muzzman1
    Muzzman1 Member
    82
    42
    So Cal
    The battery Indicator posted by the OP actually indicates an actual SOC of 40%-80%. So when that gauge reads full the actual battery charge is 80%. Never more. Toyota did this to preserve the life of the NiMH batteries.
    I live at the top of a 3-4mile hill. I regularly see the gauge indicate "full" although in reality I have only once ever actually filled my batteries to exactly 80% coming down from Big Bear. (I have a ScanGauge2 that tells me exact real SOC)
    It is not harmful in any way to send that gauge to full because the car's computer will never let any harm happen to the high voltage battery pack.
    Ardentity likes this.
  14. vday
    vday Member
    312
    Israel
    Go down a long steep hill and it will hit the top in no time 3 miles the most - happens to me daily
  15. Drafty01
    Drafty01 Junior Member
    42
    Auckland, New Zealand
    My '06 charges up to about 82.5% pretty much daily, when it starts to actively discharge. I live at the bottom of a 900ft steep hill, so it gets a charge like this every day.
    Is this harmful or beneficial for the battery?
    I have the Torque App, which has a state of charge indicator, so it's easy to monitor on the descent.
  16. Clay2013
    Clay2013 Junior Member
    28
    Brandon, Florida
    I have not seen mine full yet either!
  17. Jamesb93612
    Jamesb93612 Member
    133
    69
    Clovis, Ca
    I finally took my 2008 Prius to San Diego from Fresno, Ca. When coming back over the Grapevine, I noticed that my battery filled up for the first time (going downhill). I wasn't sure what to do, if anything. I was surprised that I was able to go for a good distance in the valley before it went back down one bar. I was able to drive in EV mode for a while at 70mph (I assume that I was in EV because I only saw the yellow arrows coming from elec. motor, but I could be wrong)
    iPad ? HD
  18. szgabor
    994
    175
    Oceanside NY
    where did you get this ??? this is a myth .. mostly because what you see is first non-linear second the whole range is is somewhere btw 40%-60% of the REAL SOC of the battery ... it sounds like a waste but this is designed for last.
    The most important for the battery is the number of cycles it takes .. but Toyota figured out that keeping the battery in this range is optimal ... but there is NO memory affect issues.
    Sorry just realized someone already said this..
  19. cmezriczky
    34
    Austria
    I get this information from my car: It starts loading via ICE when below the 2 lowest bars and does not load any more via ICE once it reaches the third highest bar...
  20. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You may have trouble finding a long steep decline in Florida. Should you vacation in the Great Smokies you may find a downhill long enough to fill the battery. (You may also be able to fill the battery with gradual braking from the top speed of your Prius, but I can't advise this)
    Once you do 'fill' the HV Battery, the Prius will try engine braking to help the friction brakes.
