Does your battery EVER show full??
Discussion in 'Gen 2 Prius Main Forum' started by bagwell, Jan 5, 2010.
has your battery ever shown FULL!?!?!?
Poll closed Feb 21, 2012.
  1. Yes
    52 vote(s)
    81.3%
  2. No
    12 vote(s)
    18.8%
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    It should if it is doing one of the following:
    1) Generating heat for itself, the catalytic converter, or the cabin.
    2) Recharging the battery.
    Most likely it was doing both, in addition to putting along at less than 35 mph.
    Tom
  2. wfolta
    wfolta Active Member
    366
    146
    Washington DC
    2018 Prius
    Probably only once or twice a week in warmer weather... Now that it's cold, it happens all the time, since the engine runs much longer to warm up. (Both for its own sake and because I'm running the heater, I guess.)
  3. SilverSurfer
    SilverSurfer New Member
    26
    Western North Carolina
    Re: Does your battery EVER show 100% full??
    My 2007 with 25.5K typically runs in the green most of the time with just one empty bar at the top. It occasionally goes to blue, but right back to green. I do a combo of flat and rolling hill driving about 30 miles a day running errands. Avg 47.5 mpg.
    Hope this is not a bad thing?
  4. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    it's rare, but it does happen. as PATRICK says, going down a hill for miles will charge my batteries to absolute full.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    I see 7 green bars at the end each way every day on my 20 mile commute but in the flatlands of Clearwater Florida I have never ever seen 8 green bars. THis car has never seen a big hill. Most of commute is a steady 50-60.
    Also the traction battery on my 07 stays charged pretty good. I can store the car for a week at a time and the traction battery will always stay at the bar I stored it on either green or blue.
    Life time of 46-47 mpg's.
  6. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    well I finally got mine to show 100% full -- started up in 28 degrees F and just let the ICE warm up for about 2 mins...when charging stopped I dropped in D with my foot on the brake applied a little gas = more charging, 1 minute later the battery was 100% full....first time ever for me!!
  7. patsparks
    10,664
    567
    Adelaide South Australia
    Worth noting the battery is never 100% full, the indicator shows full when it is at 80% capacity and the HSD system will do whatever it takes to keep the charge below 80%. I believe the systen tries to maintain 60% charge but will go 20% either way (40% - 80%). This is why the battery lasts so long.
  8. desertrider2215
    156
    usa
    alllllll the time here. probably 3 or 4 times a day
