Does your Prius shock you?
Discussion in 'Gen 2 Prius Main Forum' started by [email protected], Apr 19, 2007.
  1. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    When humidity is low, you'll generate more static electricity.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Yes there is something you can do about it. As I mentioned before. Your clothes are heavily static'ed charged from the clothes dryer. Don't you ever notice the static cling? Use one sheet of Bounce ANTI-STATIC. In the dryer. No more shock. Its purpose in life is to REMOVE THE STATIC CHARGE from your clothes. Your clothes will no longer store a charge. I never ever get shocked and I live in Florida.
    All the sun.
  3. MariaEvri
    MariaEvri Member
    122
    Limassol - cyprus
    get it all the time, not just with my car but with other stuff as well.
  4. patsparks
    10,664
    569
    Adelaide South Australia
    It's your tyres.
    I got shocked all the time until I put new tyres on the Prius and since then no more shocks. I had Michelin Energy XM1 tyres on it which were factory standard but when I had Michelin Energy XM1+ tyres fitted there were no more shocks, well apart from the price of the things.
    Try a static strap under the car.
  5. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Pat,
    Most LRR tires replace some or all of the carbon black in the rubber compound with organo-silicates. Non-LRR tires will slowly drain static electricity to ground since carbon black is electrically conductive. Organo- silicates are not electrically conductive so LRR tires will allow a higher build-up of a static charge.
    I had noticed the same shocking effect with Michelin MXV4+ "Energy Saving" tires. My Nokian WR tires seem to not exhibit as much of this effect.
    JeffD
  6. nitewolfgtr
    nitewolfgtr Junior Member
    61
    Owasso, OK
    Those static straps look retarded!
    Anyways, I always get shock too.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Or a blind pedestrian. :D
    Tom
  8. patsparks
    10,664
    569
    Same thing isn't it? Can't you buy them on ebay too? But I hear you have to buy the bolt kit separately.
  9. qbee42
    18,058
    3,081
    Northern Michigan
    They aren't as durable as a grounding strap, so they have to be replaced more often.
    Tom
  10. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Static strap .... what happens in a lightning strike event? I'm just thinking of the innate safety of a steel body car structure eg Faraday Cage Effect
  11. Qlara
    Qlara New Member
    488
    It's not Prius-specific to shock you. I got shocked by any car/object I touch sometimes. It's the dry humidity and clothes you're wearing to generate these static charges.
  12. patsparks
    10,664
    569
    Lightning in the top out the bottom, no different.
  13. qbee42
    18,058
    3,081
    Northern Michigan
    ...dirty underwear.
    Tom
  14. DickPhillips
    DickPhillips Member
    89
    58
    Mount Vernon, WA
  15. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    I'm surprised at this in a not-so-dry environment... is it what you're wearing? Whatever, if you keep in touch with a metal part of the car as you get out, the charge will transfer slowly and you won't feel it and the voltage will never build up.
  16. richard schumacher
    7,683
    1,066
    United States
    Yep, keep a hand on the door frame as you slide out. The only other solution is to have the seat covered with leather.
    When fueling any car *do not* start the pump and then get back in the car! Stay at the pump nozzle. If you leave and return you can acquire a static charge, and if you discharge it near the nozzle you can start a fire, as in this video:
    [ame=http://www.youtube.com/watch?v=b3x-8tj49ac]YouTube - Gas Pump Fire[/ame]
  17. rfelley
    rfelley Junior Member
    42
    Oregon
    I get zapped by my 93 Voyager worse than my Prius. Develop a habit of always keeping one finger in contact with a metal surface as you get out of the car. This keeps your body from developing a potential static charge as you scuff along the seat while getting out.
  18. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I've been zapped in nearly all the cars I've owned that had cloth seats. I never really noticed it in the Trans am or Corvette both of which had leather seats.
