Doesn't switch to EV mode for a while after startup.
Discussion in 'Prius c Technical Discussion' started by kittiepie, Sep 19, 2012.
  1. kittiepie
    kittiepie New Member
    Montreal, Quebec
    Hi everyone, I'm new and I just got my beautiful PriusC about a month ago. I'm no car person so I'm sorry if I don't use any technical terms or sound like a dork.
    I've recently noticed that every time I start up the car and drive, no matter how slow I go the car's engine running... and loudly. It seems to be revving high and low for at least 5-7 minutes into the drive even though it should be in EV mode at the speed I'm going and even when I stop. The battery is always juiced up too btw.
    Maybe this is normal and I haven't noticed before but I was looking through the forum and found a post about bad batteries. That issue seems to have only been for older cars that have driven quite a few KMs but mine has no more than 2000 KMs and is a brand new PriusC 2012.
    Am I worried over nothing? Is this normal behaviour?
    Thanks for your help guys.
  2. DoPeY5007
    DoPeY5007 Member
    122
    17
    Before the car can run in EV mode, every thing need to fully warm up.
    Mine does the same, but not for 5-7 minutes (I am in a warm area)
  3. kittiepie
    Montreal, Quebec
    It IS getting colder here (Montreal, QC) so maybe that's why I've only just started to notice it. Thanks so much. I was worried that I got a lemon or something...
  4. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    ECO mode reduces the temperature tolerance of the engine coolant in the regular Prius from 145°F to 114°F, meaning the engine will shut off sooner. I suspect Prius c has the same shut off point.
    It's one of the benefits of ECO not realized until the cold season arrives.
    Tracy likes this.
  5. RocMills
    RocMills Active Member
    789
    276
    Las Vegas, Nevada
    When the morning temperatures here in Vegas dropped from low 90s to low 70s, I noticed a marked change in the way the motor reacted for the first few days. I guess the car had gotten used to the higher temperatures in the mornings and once that started to decline, it took longer for the ICE to disengage entirely. However, after a few days it went back to "normal" behavior.
  6. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    Interesting, I didn't realize that was an aspect of ECO mode... May have to keep that in mind as it cools down. Does that have any negative effect on efficiency? (I.e. Not warming the engine as much as would be typical)
  7. Mik1
    Mik1 Member
    333
    Houston, TX
    Try to surf and read more about engine block heater. It will keep your engine warm in the mornings so it's not going to work so hard in order to warm up.
  8. john1701a
    12,749
    5,243
    57
    The only negative would be if you wanted the heater blazing hot, since ECO hangs on the comfortable side. So... no driving naked in the winter. :)
    Coolant will still continue to heat up to the normal level (195°F) but only if you don't stop. You can speed up that process by blocking the grille, a common practice from days long ago that's also quite handy now too.
