dog hair and battery failure
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by [email protected], Jun 28, 2014.
  1. jjones811@hotmail.com
    [email protected] Junior Member
    2006 prius, 112,000 miles, maintained according to factory recommendations. TheBattery was showing problems with one of the cells, and toyota dealership recommended replacement. When they removed the battery, the dealership found dog hair on the battery, and wondered if this didn't create the problem with the battery. $3100 later (Toyota dealership also added a filter when they replaced the battery, meaning that they recognized this was a problem with this generation) and I am reading that the generation II prius' did not have a filter in front of the 12V battery and fan. Neither did Toyota recommend regular maintenance/monitoring of the fan, which would have taken care of this situation? One other person posted a similar problem (dog hair, dust, dirt found on battery), and need for battery replacement. Have others experienced this issue? and why hasn't this become a recall issue?
    Sorry if this was posted previously- I couldn't find the original post, and am not really remembering how to post questions and concerns.
  2. Epiphany2000
    Epiphany2000 Member
    126
    San Francisco Bay Area, CA
    Yes, this is a known issue. Those who often have dogs in their cars need to either (A) install a filter in the HV battery air intake vent and clean the filter regularly and/or (B) inspect and clean the HV battery fan as part of their regular maintenance. Doing task (A) will likely prevent a lot of cleaning of the HV battery fan that would otherwise need to be done.
    Some hybrid shops (usually not dealers) will inspect the HV battery fan as part of a major service, but this is probably the exception as opposed to the rule. Hence, owners that often transport dogs in their cars need to be aware of this issue & take steps to keep the fan and HV battery clean.
    Personally, I don't see this as a potential recall issue, rather, a matter of how an owner chooses to use their car and act accordingly. The car is designed for human passengers. If you are going to transport other things (e.g., animals, cargo that is particularly dusty/dirty) on a regular basis, it is the owner's responsibility to assess the impact of said usage and take appropriate steps to mitigate it.
    #2 Epiphany2000, Jun 28, 2014
    52,820
    do you have a dog?
    [email protected] likes this.
  4. Epiphany2000
    Epiphany2000 Member
    126
    No, nor do I expect dog owners to necessarily see this issue the same way I do. :sneaky:
  5. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    Most of the cars that I have replaced the HV battery have either pet hair or a large amount of dust in the fan. In my small sample I would guess that is the leading cause of battery failure. On the rare occasions when I have replaced a battery and the fan is clean, it has been a low mileage older car (ie 04-05 with 50-80k) which I would assume the car sat for extended time. We have a lot of snow birds in Florida.
    wjtracy likes this.
  6. bisco
    52,820
    if you don't own a dog, do you think they were lying about the fur? where else would it come from?
  7. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Thanks for the heads-up on this one. I plan to have a large dog and live near the beach once I retire. :)
    Bill the Engineer
  8. bisco
    52,820
    mexican hairless?
  9. JC91006
    16,936
    8,647
    I just cleaned out a 2007 Prius with tons of dog hair in the car. It was really gross and yes it did end up in the fan. The ducts had lots of dust and when I got to the fan, it had layers of dust and dog hair. Good thing I clean it out now or else it was sure to end up to be another battery failure statistic.
  10. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    There are other things that Toyota could recommend looking at, but don't, such as transmission fluid. Since your car made it to 100K miles, then that is as good as it needs to be as far as T is concerned. Recalls are mainly about safety, and battery fan clogging is not a safety issue.
    That's why enthusiast sites like this exist, as all the data that comes through makes the collective intelligence better than any dealership. A little proactive research goes a long way, if one has the time for such.
    Epiphany2000 likes this.
  11. jjones811@hotmail.com
    Yes, I, the owner of the fur covered battery do have dogs. I just wish that I had known that this was a maintenance item. It seems only fair to include it as recommended maintenance, when battery failure can result from particles (dust, dirt and dog hair) getting into the fan/battery.How was I to learn of this if it was not part of the maintenance schedule? I am guessing that Toyota figured this out, as they began making filters for the battery / fan for the next generation.
  12. jjones811@hotmail.com
    I also have cancer, and some of that hair could have been mine....bad luck I guess.
  13. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I have to say...Yes and No to this response.
    For those of us that hang around Prius Chat or perhaps are more aggressive and diligent about seeking out information, the dog hair, battery fan intake, and failure possibility- is a known issue. But I would say it's not necessarily a commonly known issue with anyone simply not informed. And I don't think Toyota warns or recommends cleaning the intake on a regular basis, which I think they should. And since the problem can be mitigated or lessened considerably with simply the addition of a filter, I do think it is a potential issue for either recall...or perhaps more realistically, better design in the future.
    Yes...the car is designed for human passengers, but as a hatch back, one in which Toyota themselves in their own glossy brochures pictures transporting bags of potting soil and plants...it's not unreasonable to expect that the vehicle can be used to transport pets. There is no warning from Toyota about NOT transporting pets.
    I doubt this becomes a recall issue, if only because of the cost. But periodic maintenance and inspection of the fan and intake SHOULD become part of the maintenance recommendations for all Prius. And the addition of a filter? Might be a really good idea for future incarnations of Prius.
  14. jjones811@hotmail.com
    Thanks for the clarification, and numerous viewpoints. I am hopeful that Toyota will be responsive and send out recommendations for upkeep to their batteries. But that might be admitting liability? Looking at transmission fluid is a given- But is there a list of what we need to be looking for that is not mentioned with the Toyota formal maintenance plans? Even When I went in to the Toyota Dealership a couple of months ago (having just moved to this area and not knowing a mechanic in Seattle) and asked for a copy of their recommended maintenance items, nowhere did the list include battery maintenance. sad.
    So, what else should I be monitoring, now that my extended warranty has expired, and I am at 112,000 plus miles?
    Thanks for any further recommendations-
    And are there any recommendations for a good prius mechanic in the north end of Seattle?
  15. jjones811@hotmail.com
    Perhaps I should have kept the dogs in their carriers on top of the car....not that this has never been done before....
  16. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    Wouldn't there be a way, maybe with one of those video bore scopes, to take a look at the squirrel cage blower and ductwork to ascertain whether a more thorough disassembly and cleaning would be in order? It could be a quick and easy addition to a 50K service (more often for pet owners) and possibly avert the expense of warranty and especially non-warranty HV pack replacement. Or does that make too much sense?
  17. JC91006
    16,936
    8,647
    That won't make as much sense as charging you for a cleaning......then to discover you don't need it and still get charged.
  18. bisco
    52,820
    it would have been nice if the o/p had been warned in the owners manual along with the warning to keep the vent clear of obstructions. or given a partial good will warranty on the battery. i guess that's the advantage of hanging out here from time to time.
  19. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I don't have a dog in the fight. But the other issue on Gen2 batt failure is running the HV battery down when you run out of fuel. So far Gen3 which have the filter and do not let the batt run down on loss of fuel, seem to have better batt reliability than Gen2.
    I always have to ask my wife when our dog died to convince myself he never got a chance ride in our Prius. Ours was a Marley equivalent who lived near and about the same time as Marley...must've been related.
    Yes I keep looking at the $25 scopes on Amazon for this purpose...have not tried it yet.
    #19 wjtracy, Jun 29, 2014
  20. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    I wonder what sort of dimensions we are talking here. How far in from the back seat intake port is the fan? What length of bore scope would be required? I would assume that based on the direction of air flow through the duct work, the view of the squirrel cage presented from this approach would be best. I wouldn't want to go poking around in the HV box, for sure. Amazon offering a color scope for $25? I could find plenty of other uses for a tool like this.
